Power Settings
Click 日本語 for Japanese
Overview
Power settings page for Wireless includes all settings related to how the access point (AP) consumes power. You can choose a preset profile to control the AP’s behavior when it operates in degraded PoE mode.
Use Case
In PoE negotiation, the AP would request a certain power budget from the switch that is supplying PoE power. If the switch is able to meet the request of the AP, the AP will proceed to enable all of its functionality and assume normal operation. However, if the switch cannot meet the power budget requested by the AP, the AP will turn off certain functions in order to operate within the power budget that is offered by the switch, this is known as degraded PoE mode.
Degraded PoE profiles let users set power-saving options when the AP is operating in degraded PoE mode. Users can apply one profile to all devices of the same model in a network. Each profile is based on device model power constraints. Supported models are CW9178I, CW9176I, and CW9176D1.
Configuration
Degraded PoE Profiles can be accessed via Wireless > Configure > Power Settings.
All networks will have default profiles set for all models initially. Customers have the option to select a different profile depending on their degraded PoE needs and preferred interfaces.
Each tab represents an applicable device model present in the current wireless network. Current options are CW9178I, CW9176I, and CW9176D1. Settings will not be available until a compatible device is added to the network.
Available power profiles:
CW9178I
Profile Name
Interface
Value
Default Profile
2.4GHz
2x2
5GHz-1
2x2 (Quad Radio), Disabled (Tri-Radio)
5GHz-2
2x2 (Quad Radio), 4x4 (Tri-Radio)
6GHz
2x2
Ethernet 0
2500 Mbps
Ethernet 1
2500 Mbps
USB
Disabled
Tri-Radio
2.4GHz
2x2
5GHz-1
Disabled
5GHz-2
4x4
6GHz
2x2
Ethernet 0
2500Mbps
Ethernet 1
2500Mbps
USB
Disabled
Dual Radio, Single Ethernet
2.4GHz
4x4
5GHz-1
Disabled
5GHz-2
4x4
6GHz
Disabled
Ethernet 0
10000Mbps
Ethernet 1
100Mbps
USB
Disabled
Dual Radio, Dual Ethernet
2.4GHz
4x4
5GHz-1
Disabled
5GHz-2
4x4
6GHz
Disabled
Ethernet 0
1000Mbps
Ethernet 1
1000Mbps
USB
Disabled
- CW9176I and CW9176D1
Profile Name
Interface
Value
Prioritize 5 & 6 GHz (Default)
2.4GHz
2x2
5GHz
4x4
6GHz
4x4
Ethernet
2500 Mbps
USB
Disabled
Prioritize 2.4 & 5 GHz
2.4GHz
4x4
5GHz
4x4
6GHz
2x2
Ethernet
2500 Mbps
USB
Disabled
Prioritize 2.4 & 6 GHz
2.4GHz
4x4
5GHz
2x2
6GHz
4x4
Ethernet
2500 Mbps
USB
Disabled
