How to Manually Change Channels in a Mesh Network
Overview
In a Cisco Meraki wireless deployment, multiple MR access points (with or without connections to wired Ethernet) communicate over their wireless interfaces to form a mesh. Each access point develops a list of neighboring devices and exchanges information. The access points use the exchanged information to calculate the best routes to the gateway or the internet.
When an access point has a wired Ethernet connection and obtains an IP address (through static IP configuration or DHCP), the access point operates as a "mesh gateway." If an access point has no wired Ethernet connection or does not obtain an IP address over the wired connection, the access point operates as a "mesh repeater." A mesh repeater relays wireless traffic through the mesh network, either to a gateway or through other repeaters.
To learn the difference between a mesh gateway and a mesh repeater, refer to the Gateways vs. Repeaters documentation
Access points mesh automatically on the channels with the least interference, using channel selection algorithms. Avoid manually changing channels in a mesh network unless necessary. However, special cases can require you to manually select the specific channels that a group of access points use to mesh.
Step-by-step instructions
Manually changing mesh channels
Access points converge automatically using Meraki routing protocols and mesh network software. Automatic convergence reduces the need for additional configuration, RF planning, and wireless site surveys. If you must manually select the channel that the mesh network uses to serve clients, follow these steps:
In the Meraki dashboard, navigate to Wireless > Monitor > Access Points.
Locate the desired mesh gateway and repeaters in the list.
Note the names of the mesh gateway and the repeaters connected to the gateway.
Navigate to Wireless > Configure > Radio Settings.
Search by access point name or scroll down to locate the desired access point.
You should manually change all repeaters (if any) before manually changing the channel of the mesh gateway. Changing the repeaters first speeds up the wireless network convergence by eliminating the time a repeater is scanning for a gateway.
FOR 2.4GHz
1. Under the Channel column in the table below, select the channel number or AUTO. The channel setting dialogue box appears. Select Change channel setting.
2. Select the specific channel, and then select save in the upper right-hand corner of the dialogue box. The mesh network can take several minutes to re-converge.
FOR 5GHz
1. In the Band drop-down menu, choose 5.
2. Under the Channel column in the table, select the channel number or AUTO. The channel setting dialogue box appears. Select Change channel setting.
3. Select the specific channel, and then select save in the upper right-hand corner of the dialogue box. The mesh network can take several minutes to re-converge.
When selecting a new channel for the mesh network, you need to change only the channel for the mesh gateway. The mesh repeaters automatically mesh again with the gateway without you manually setting the intended channel on them. However, you should manually change all repeaters (if any) before manually changing the channel of the mesh gateway. Changing the repeaters first speeds up the wireless network convergence by eliminating the time a repeater is scanning for a gateway.
