MX Sizing Guide & Principles
This document serves as a guide for the architecture and design of networks incorporating MX firewall appliances. This document aims to help determine the appropriate MX model to evaluate, understand how the performance of devices can vary with different features enabled, and compare MX models with those from other vendors.
Click 日本語 for Japanese
Use of This Document
Current Firmware Version: MX 19.1x
This document is to be used to assist in the architecture and design of networks in which MX firewall appliances will be present. Key questions which this document is designed to help answer are:
  • How do I decide which MX model(s) I should evaluate?
  • How does device performance vary by features enabled?
  • How do MX models compare against other vendors?
It is highly recommended to leverage this document with a proof of concept for further validation of design and implementation as each network environment is unique.
With the release of each major MX firmware version throughput; feature specific data, or flow and session specific data may change. This document will provide guidance on these MX performance metrics in a variety of scenarios and environments.
Note that each network environment and traffic profile is unique. It should be taken into account that the numbers presented in this document are obtained during testing in a vacuum where no detrimental network or traffic profile behavior is present.
The Performance metrics detailed in this document are based on the Current Firmware Version listed above. It should be noted not all platforms can support the most recent stable firmware, more details surrounding this can be found here.
Portfolio Capabilities
Cisco Meraki MX Security and SD-WAN Appliances provide unified threat management (UTM) and SD-WAN in a powerful all-in-one device.
Choosing the right MX depends on the use case and deployment characteristics.
For detailed sizing and capabilities of vMX devices please review the vMX specific data sheet.
Below is a breakdown of the MX; Z-Series, and vMX Portfolio's hardware capabilities.
MX-Series
For MX67(C/W) devices, dual WAN is available via a convertible LAN interface.
For models without integrated cellular, cellular failover is available when leveraging a MG cellular gateway.
Dual power supply models have an active/standby redundant power supply and do not provide combined power.
MX68 and MX75 PoE+ capabilities are available for LAN ports. MX85, MX95, and MX105 PoE+ capabilities are available for WAN ports. PoE/PoE+ is provided to an MG via these ports is supported. Please refer to product-specific data sheets for additional details.
HTTPS Inspection is available natively on indicated platforms via Cisco Umbrella SD-WAN extension, or via a third-party provider reachable via VPN.
  MX67
(C/W)
MX68 (W/CW) MX75 MX85 MX95 MX105 MX250 MX450
Dual Active WAN
Yes Yes Yes Yes Yes Yes Yes Yes
3G/4G Failover  Yes Yes Yes Yes Yes Yes Yes Yes
Built-in LTE Modem* Yes Yes No No No No No No
Built-in Wi-Fi** Yes Yes No No No No No No
Built-in PoE+ No Yes Yes Yes Yes Yes No No
WAN Fiber Connectivity No No SFP SFP SFP+ SFP+ SFP, SFP+ SFP, SFP+
Dual Power Supply No No No No No Yes Yes Yes
Form Factor Desktop Desktop Desktop 1U 1U 1U 1U 1U
HTTPS Inspection Yes Yes Yes Yes Yes Yes Yes Yes
Advanced Malware Protection (AMP) Yes Yes Yes Yes Yes Yes Yes Yes
Intrusion Detection and Prevention (SNORT IPS/IDS) Yes Yes Yes Yes Yes Yes Yes Yes
* - Only if the MX model has a C. Ex: MX67C, MX68C
** - Only if the MX model has a W. Ex: MX67W, MX68W
Z-Series
  Z3 (C) Z4 (C)
Dual Active WAN No No
3G/4G Failover Model Available Yes Yes
Built-in LTE Modem Model Available Yes Yes
Built-in Wi-Fi  Available Yes Yes
Built-in PoE (LAN Port) Model Available Yes (802.3af, PoE) Yes (802.3at, PoE+)
Advanced Malware Protection (AMP) No Yes
No
No
vMX-Series
  vMX-Small vMX-Medium vMX-Large
Dual WAN
N/A N/A N/A
3G/4G/5G Failover N/A N/A N/A
Built-in LTE Modem Model Available N/A N/A N/A
Built-in Wireless Available N/A N/A N/A
Built-in PoE+ Model Available N/A N/A N/A
WAN Fiber Connectivity N/A N/A N/A
Dual Power Supply N/A N/A N/A
Form Factor Virtual Virtual Virtual
HTTPS Inspection N/A N/A N/A
Advanced Malware Protection (AMP) N/A N/A N/A
Intrusion Detection and Prevention (SNORT IPS/IDS) N/A N/A N/A
Use Case Recommendations
A use case recommendation is based off of the device throughput; available feature set, and maximum flow table capacity. In this calculation, each client is considered to consume up to 50 flows.
MX-Series
  MX67 MX68 MX75 MX85 MX95 MX105 MX250 MX450
Recommended Maximum Device Count 50 50 200 250 500 750 2,000 10,000
Maximum Routes 10,000 10,000 10,000 10,000 10,000 10,000 17,000 17,000
Z-Series
  Z3 (C) Z4 (C)
Recommended Maximum Device Count 5 15
Maximum Routes 5,000 5,000
vMX-Series
Recommended Maximum Device Count 500 2,500 10,000
Feature Specific Data
The following items should be noted:
  • Max site-to-site VPN tunnels are based on lab-testing scenarios where no client traffic is transferring over the VPN tunnels.
  • Recommended max site-to-site VPN tunnels are based on lab-testing scenarios with client traffic transferring over VPN tunnels.
  • Load balancing for client VPN can be utilized if more than 500 connections are required.
  • Criteria must be met prior to WAN; dynamic path selection, or tunnel failover times occurring.
MX-Series
Maximum Site to Site VPN Tunnel Count 50 50 75 200 500 1,000 3,000 5,000
Recommended Maximum Site to Site VPN Tunnel Count 50 50 75 100 250 500 1,000 1,500
Maximum Number of Client VPN Tunnels  50 50 75 100 250 250 500 500
Maximum Number of AnyConnect Sessions 100 100 250 250 500 750 1000 1500
WAN Failover < 5 Sec < 5 Sec < 5 Sec < 5 Sec < 5 Sec < 5 Sec < 5 Sec < 5 Sec
Auto VPN Tunnel Failover Sub-second Sub-second Sub-second Sub-second Sub-second Sub-second Sub-second Sub-second
Dynamic Path Selection Sub-second Sub-second Sub-second Sub-second Sub-second Sub-second Sub-second Sub-second
Z-Series
  Z3 (C) Z4 (C)
Maximum Site to Site VPN Tunnel Count 10 10
Recommended Maximum Site to Site VPN Tunnel Count 4 8
Maximum Number of Client VPN Tunnels  1 2
vMX-Series
Maximum Site to Site VPN Tunnel Count 50 250 1,000
Recommended Maximum Site to Site VPN Tunnel Count 50 250 1,000
Maximum Number of Client VPN Tunnels  50 250 500
WAN Failover N/A N/A N/A
Flow and Session Data
It is important to understand the number of flows, or open sessions, supported by each appliance. For purposes of sizing, a flow is any transmission on an open socket within the last 5 minutes.  Note that this is not a recommended flow capacity number, but instead these values are to be maximums.
MX-Series
Maximum Concurrent Sessions 25,000 25,000 50,000 125,000 200,000 250,000 500,000 1,000,000
Z-Series
  Z3 (C) Z4 (C)
Maximum Concurrent Sessions 5,000 10,000
vMX-Series
Maximum Concurrent Sessions 25,000 125,000 1,000,000
Performance Data
Industry-standard benchmarks are designed to help you compare MX appliances to those from other vendors. These tests assume perfect network conditions with ideal traffic patterns. When measuring maximum throughput for a certain feature, all features unless otherwise noted below are disabled. Actual results will vary.
The following items should be noted during review:
  • Firewall Throughput tests have the following configuration applied:
    • Layer 3 Firewall enabled
    • QoS
    • DPI (NBAR)
  • Advanced Security Throughput Tests are performed for MX-Series devices with the following configuration:
    • QoS
    • DPI (NBAR)
    • IPS Ruleset: 'Connectivity'
    • AMP enabled
    • Content Filtering enabled
    • IPS Mode in Detection or Prevention configuration
  • Single & Multi-Tunnel VPN Throughput tests have the following configuration applied:
    • QoS
    • DPI (NBAR)
  • Secure Teleworker Throughput Tests are performed for Z-Series devices with the following configuration:
    • QoS
    • DPI (NBAR)
    • AMP Enabled
Note: Testing performed leverages multiple clients (sources) and multiple servers (destinations). Multi-flow and single-source testing methodologies may provide results lower than those present in this guide.
MX-Series
Firewall
Throughput
RFC2544 - 1518 Byte
700 Mbps 700 Mbps 1 Gbps 1 Gbps 3 Gbps 5 Gbps 7.5 Gbps 10 Gbps
Firewall Throughput
EMIX
700 Mbps 700 Mbps 1 Gbps 1 Gbps 3 Gbps 5 Gbps 7 Gbps 10 Gbps
NGFW Throughput
(Advanced Security - Prevention)
EMIX
300 Mbps 300 Mbps 500 Mbps 500 Mbps 1.5 Gbps 2 Gbps 2 Gbps 5 Gbps
NGFW Throughput
(Advanced Security - Detection)
EMIX
400 Mbps 400 Mbps 1 Gbps 1 Gbps 2 Gbps 2.5 Gbps 3 Gbps 7 Gbps
VPN Throughput RFC2544 1400 Byte
400 Mbps 400 Mbps 1 Gbps 1 Gbps 2.5 Gbps 3.5 Gbps 4 Gbps 6.5 Gbps
VPN Throughput EMIX 300 Mbps 300 Mbps 1 Gbps 1 Gbps 2.5 Gbps 3.5 Gbps 3.5 Gbps 6.5 Gbps
Note: NGFW = next generation firewall, EMIX = enterprise mix
Z-Series
  Z3 (C) Z4 (C)
Secure Teleworker Throughput NA 500 Mbps
Firewall
Throughput
RFC2544 - 1518 Byte
200 Mbps 500 Mbps
Firewall Throughput
EMIX
200 Mbps 500 Mbps
75 Mbps 250 Mbps
VPN Throughput EMIX 50 Mbps 250 Mbps
vMX-Series
NGFW Throughput
EMIX
200 Mbps 500 Mbps 1 Gbps
Firewall
Throughput
RFC2544 - 1518 Byte
250 Mbps 500 Mbps 1 Gbps
Firewall Throughput
EMIX
VPN Throughput
RFC2544 - 1400 Byte
VPN Throughput EMIX 250 Mbps 500 Mbps 1 Gbps
Features, benefits, and performance impact
Features and Benefits
Each feature provides advanced benefits tailored to specific use cases. Below is an elaboration on a feature; its use case, and a recommendation for sizing appropriately for deployment or implementation.
Cisco Advanced Malware Protection (AMP)
Cisco Advanced Malware Protection (AMP) is an industry-leading anti-malware technology, integrated into MX Security Appliances.
Consider disabling this feature for guest VLANs and leveraging firewall rules to isolate guest VLANs. Also consider disabling if clients within the network are secured via a full malware client, such as AMP for endpoints.
Content Filtering
Content filtering, powered by Cisco TALOS, allows you to block certain categories of websites based on your organizational policies.
Consider blocking only necessary categories while aligning with your organization's security guidelines.
Web-Safe Search
MX Security Appliances have the option to force all web searches to use Web search filtering.
Must be deployed in tandem with "disable encrypted search" option to be effective.
Cisco IPS/IDS (SNORT)
Intrusion Detection and Prevention, powered by Snort, monitors and protects your network from malicious activity.
Rulesets other than 'Connecitvity' have a larger performance impact. Additionally, consider not sending IDS/IPS syslog data over VPN in low-bandwidth environments.
HTTPS Inspection
HTTPS Inspection enhances Advanced Security features by enabling them to inspect and act on HTTPS traffic.
Use of Cisco Umbrella SD-WAN extensions to offload processing from edge or concetrator devices will reduce performance impacts to MX devices.
Number of VPN Tunnels
Auto VPN creates VPN tunnels between sites in an automated, seamless fashion.
Consider using split tunnel VPN while deplyoying security services at the edge of your network environments.
FIPS Mode
FIPS Mode enables the use of only FIPS compliant mechanisms for MX devices.
Consider engaging your account specialist for appropriate sizing and network architecture when planning to leverage this feature.
Performance Impact Breakdown
Feature Name Performance Impact
Cisco Advanced Malware Protection (AMP) Low
Content Filtering Low
Web-Safe Search Low
FIPS Mode (Non-VPN Services) Low
Cisco IDS/IPS (SNORT) Medium
HTTPS Inspection (On device, not offloaded) High
Number of VPN Tunnels High
FIPS Mode (VPN Services) High
