MX100 Scheduled Firmware Upgrade Cancellation - 4/27/2023
Note: The MX18.1 firmware release will be the maximum running build for MX64, MX64W, MX65, MX65W, MX84, MX100, and vMX100 platforms. These platforms will not run MX 18.2 and above firmware builds. We recommend you stay up to date with all the latest features with the next-generation hardware platforms. Please consult your sales representative for more information on the latest hardware and software releases.
Overview
Cisco Meraki discovered an issue when performing firmware upgrades on MX100s running deprecated firmware.
Who is affected?
Affected Models
MX100s running firmware lower than version MX 16.16
Affected Versions
MX 17.10.5
MX 18.1.07
What is the result?
If an MX100 with version MX 16.16 firmware or below is upgraded to either of the affected firmware versions listed above, the device will go into an unrecoverable state.
What is Meraki doing about it?
To prevent any further MX100s from being affected, we will be canceling currently–scheduled and future firmware upgrades for MX100s running firmware version MX 16.16 or below.
A solution has been found to prevent the issue and will be included in the next firmware build.
Workaround
17.10.6 and 18.107.1 are available and have the fix for the issue.
For assistance setting up the required 2-stage upgrade, please contact Meraki Support.
