How to Change the Theme in the Dashboard
Overview
Cisco Meraki offers a dark mode theme option for the Meraki dashboard. This option lets you switch the dashboard's visual theme to a darker color palette. Some users prefer the darker palette to reduce eye strain and improve readability in low-light conditions.
Step-by-step instructions
The theme is a user-specific preference. Your selection persists across all of your sessions and devices, and across every Meraki organization that you access. The theme setting does not affect the dashboard view for any other users in your organization.
To enable or disable Dark Mode
  1. Select the user profile icon in the top right corner of the Meraki dashboard. The icon typically looks like a person's silhouette.
  2. In the dropdown menu, locate the Theme setting.
  3. Select one of the following options:
    • Light: This is the default dashboard theme with a light background.
    • Dark: This option applies the new dark color palette to the dashboard.
    • System theme: The Dashboard automatically detects and applies the theme preference configured in your web browser. For guidance on configuring your system's theme preference, refer to the documentation for your web browser.
The dashboard theme updates immediately after you select an option. clipboard_e1bc8e06a0829ff5917ad97dc1fc5c529.png
Troubleshooting
If you encounter issues with contrast, readability, or other visual aspects while using dark mode, open a case with Meraki Support.
