How to Upload and Align Floor Plans in Dashboard
Overview
This article explains how to upload custom floor plans, align them on the map, and place devices in the Cisco Meraki dashboard.
Maps and floor plans in the Meraki dashboard offer a more visual approach to managing large numbers of devices and tracking their physical locations. Custom floor plans visually organize devices based on their physical locations throughout a building. Once uploaded, you can reuse these floor plans on other dashboard pages that use maps.
Prerequisites
Confirm that image file meets the following requirements:
  • Less than 5 MB in size
  • No larger than 65,448,100 pixels. Any image above 10,000,000 pixels will be compressed down to 10,000,000 pixels.
  • One of the following file types:
    • JPEG
    • GIF
    • PNG
Upload each floor of your building as a separate image. If you encounter issues when uploading an image, confirm that your browser is up to date.
Step-by-step instructions
Upload a custom floor plan
  1. Navigate to Network-wide > Monitor > Maps & floor plans.
  1. Select Add a new floor plan.
Fields to provide information for when uploading a new floor plan to the Meraki Dashboard. This is where a new floor plan is uploaded as well.
  1. Enter a Name for the floor plan.
  1. Enter a Location (address or coordinates) for the floor plan.
  1. Upload your custom floor plan image for your deployment.
  1. Select Next.
  1. Dashboard places the floor plan with an approximated placement based on the address entered. Align the floor plan with Google Maps by clicking and dragging the floor plan. Aligning the floor plan with Google Maps lets devices placed on the floor plan automatically sync with the corresponding location in other map views.
  1. Select Save floor plan and close or Save floor plan and place devices.
Rename a custom floor plan
  1. Select the Edit button next to the floor plan you want to rename.
  1. Replace the Name, Location, or Image at this step. After you change the appropriate details.
  1. Select Next.
Delete a custom floor plan
  1. Select the Delete button next to the floor plan you want to delete.
  1. Select Confirm in the next window.
Place devices on the map or floor plan
You can place devices on the Map, Satellite, or Floor plans views. If you use floor plans and have aligned them, place the devices on the appropriate floor plan.
  1. Choose the appropriate map view in the upper right corner of the page. Map and Satellite use Google Maps, and Floor plans brings up any floor plans you uploaded.
Different map options for viewing network device locations. Uploaded floor plans can be viewed here as well.
  1. Select Place devices on [map name].
  1. Click and drag the device's wireless icon from the list on the right side of the page to the appropriate location on the map.
Remove devices from the map or floor plan
To completely remove a device from a floor plan and the maps view:
  1. Select Place devices on the map.
  1. Hover next to the device you want to remove from the floor plan and select the x sign.
  1. Repeat this process for any remaining devices.
  1. When finished, select Save device placements.
Geoalign floor plans
Geoaligning floor plans lets you better track client location with Meraki APs using both location heatmaps and the Scanning API by giving the floor plan a geolocation.
When you view the location heatmap without geolocation data, dashboard overlays APs, clients, and their positions on the Google Maps view based on the configured geolocation of the APs.
When you geoalign a floor plan, you can select the floor plan on the Wireless > Monitor > Location Heatmap page, which overlays APs, clients, and location data on the floor plan and provides more context to the client location data shown. Geoaligning floor plans also allows dashboard to calculate more accurate location data.
To geoalign a floor plan navigate to Network-wide > Monitor > Map and Floor Plans:
  1. For all new floor plans, enter a geolocation by address or by latitude and longitude when prompted.
  1. For any existing floor plan that does not already have this information, select the Edit button.
  2. Enter the location information of the deployment. This places the floor plan and the APs on the corresponding longitude and latitude in dashboard.
  3. Select Next. Dashboard places your floor plan at the location entered.
  1. Move, rotate, and resize your floor plan to match the site's actual location and orientation.
  1. Select Save floor plan and close in the top right corner of the screen. This ensures that your currently placed APs retain their location on the floor plan.
Select "Save floor plan and close" to keep current Meraki device positions.
Configure map options
When you view the map and floor plans, several options control the additional information displayed. These options are also available in the menu option in the top right corner.
  • Map Type: Choose whether to display floor plans on top of the Map and Satellite views.
Floor plans can be toggled to display over map or satellite views, if desired.
  • Floor Plan: Select the floor plan to display from the list of defined floor plans, and define the opacity of the floor plans on top of the map view.
  • Layers:
  • Neighbors
  • Mesh
Neighbors: show lines between access points that are visible to one another and are on the same channel. Mesh: when hovering over a repeater AP, show the path to that AP's gateway.
Neighbor lines display only between mesh neighbor APs. APs in gateway mode with no repeaters associated do not display any neighbor line.
  • Markers: Manage map marker display options.
    • Markers to display: Displays devices that are checked.
      Map markers from Map & floor plans page
    • Marker value: Controls what displays within the icon for each device:
      • Device type — Displays the device model number.
      • Device name — Displays the device name.
      • Current clients — Displays the number of clients currently connected to the device.
      • Clients for the past day — Displays the number of clients connected to the device over the last day.
      • Usage for the past day — Displays the total data utilization through the last day.
        Marker value options: device type, device name, current clients, clients for past day, usage for past day.
  • Device Status: Shows different colors for each device status.
Device status color key.
Verification
Confirm that your configuration succeeded:
  • After you align the floor plan with Google Maps, devices placed on the floor plan automatically sync to the corresponding location in other map views.
  • After you place a device, its placement syncs between the different views. A device's placement on the floor plan is reflected in the Map view.
  • After you geoalign a floor plan and select it on the Wireless > Monitor > Location Heatmap page, dashboard overlays APs, clients, and location data on the floor plan.
Troubleshooting
  • If you change device placement in the Map or Satellite views and move a device outside the bounds of the floor plan, Dashboard removes the device from the floor plan view.
  • If you encounter issues when uploading an image, confirm that your browser is up to date.
  • If a floor plan does not display neighbor lines, confirm that the APs are mesh neighbors. APs in gateway mode with no associated repeaters do not display neighbor lines.
