Adaptive Policy Telemetry
Overview:
The tools discussed in this page will provide users the telemetry and visibility needed to verify and Adaptive Policy enabled network.
Adaptive Policy Hit Counters Live Tool
Available on MS390 and C9300-M platforms.
Adaptive Policy Hit counters live tool allows the user to see SGACL rule hit counts over a 30 second time span. This hit counter will pull the live counters and then poll again in 30 seconds. Search filters are available to use to allow the user to quickly find the SGTs they are looking for in the hit counters table.
NOTE: Remember counters will only increment on the EGRESS switch, as Adaptive policy is an egress enforcement methodology.
To use the Live Tool:
Use of the Adaptive policy Hit counters live tool:
Go to Switches->Select your switch->Tools Tab
Click Run under Adaptive Policy Counters
(Optional): You can filter based on source or destination SGT value
In the above example we are showing the hit counter table filtered on all SGACLs that match source group tag 7.
Adaptive Policy Custom ACL (SGACL) Logging
This feature allows users to configure specific rules in their AdP policy to log the events to the switch and network wide log pages. This is particularly useful for troubleshooting traffic flows and also for security compliance where permit or denies of packets need to be logged.
Configuration
Configuration:
Navigate to Organization-> Adaptive policy
Click Custom ACLs tab
Click the button Add custom ACL
Enter a name for the ACL
Enter a description for the rule
Select the IP Version (any/IPv4/IPv6)
Click the button to add ACL Rule
Select Policy (Deny or Allow)
Select protocol (TCP, UDP, ICMP, or Any)
Enter Source port or Leave ANY
Enter Destination port or Leave ANY
Check the box for LOG
Click the done button
Add Any additional ACL rules following the steps above
Click the button Create
In this example we have created an ACL to Deny ALL traffic and log it to the dashboard.
To view logs from the enforcing/egress switch:
Navigate to switch->select your switch->click the event log tab
To view logs from the network-wide event log:
Navigate to Network-wide->Event log
Adaptive Policy Custom ACL (SGACL) TCP Established
Adaptive Policy TCP established is an option on policy ACLs that when enabled requires a full TCP connection to be set up before information can be transmitted between two endpoints. Enabling this feature eliminates the need for Bidirectional ACL policies between two SGTs.
Configuration
Configuration:
Navigate to Organization->Adaptive Policy
Select protocol TCP
(optional) Check the box for LOG
Check the box for TCP Established
Click the button Create/Update
Additional Adaptive Policy Resources
For additional information on Adaptive Policy, refer to the following links:
Adaptive Policy Overview
Adaptive Policy Configuration Guide
Adaptive Policy for MX/Z Platforms
Adaptive Policy MS Configuration Guide
Adaptive Policy MR Configuration Guide
Adaptive Policy and Cisco ISE
