Service Provider Dashboard Roles
日本語版はこちら(Japanese)
SSID-only Administrators
Overview
Service providers (SPs) can use SSID-only administrators to enable their customers to modify SSID information and see client analytics. Other components of Dashboard will be hidden from the customer, preventing the potential for unwanted changes that could disrupt network performance. SSID-only administrators can specifically access:
- Network > Client analytics
- Network > Location analytics
- Network > Wireless settings.
Not only does this limit the scope of the customer in Dashboard, under Network > Wireless settings, the customer is limited to the following options:
- Set SSID name
- Enable or disable the SSID
- Configure SSID encryption (eg. Open, WPA2, WPA3)
- Set the SSID password if applicable
- Assign either no splash page or a click through splash page
Note: This feature is only available to wireless only networks. Combined networks (wireless in addition to another product line) will not show the UI option.
Note: This feature is only available using the New Version of the Organization > Administrators page.
Configuration
There are two steps to configuring an SSID-only administrator: Defining the SSIDs to be managed, and assigning administration privilege to the customer.
Defining customer configured SSIDs
Under Wireless > SSIDs
- For each desired SSID, locate the SSID Admins dropdown.
- By default, access will be disabled on all SSIDs. Select access enabled from the dropdown to allow customers to modify this SSID.
Note: This can also be done via the Cisco Meraki Dashboard API using the PUT /networks/{networkId}/wireless/ssids/{number} endpoint and updating the ssidAdminAccessible value to true;
Assigning privilege
As an Organization level administrator:
Under the New Version of the Organization > Administrators
- Add or edit an existing admin and click the Assign Role button.
- Select the SSID-Manager role in the fly-out menu and click save.
- Click Assign Scope and select the wireless networks this admin should have access to in the scope fly-out menu, then click Save.
- Click Assign scope component and verify the SSIDs in the selected Networks are correct, then click Save.
Note: This is not where the you will enable which SSIDs the SSID manager will have access to, that is assigned via the Wireless > SSIDs page in each network.
End customer
Overview
The the End customer role (formerly Enterprise Admin) is located under Organization > Configure > Administrators > Roles tab. It enables the end customer admin to control aspects of their specific organization while hiding certain elements that are only available to the service provider (Firmware Upgrades, Licensing, SP Branding, SP Admin Users etc.).
This role also adds the ability for a service provider (org admin) to designate SSIDs that an end customer can access. When the role is enabled, there is an additional toggle under wireless > SSIDs that will allow the SP to delegate this access. A service provider can use this to deploy and configure their own hotspot SSIDs on their customer infrastructure without providing access for the EA to change or reconfigure this SSID. Client info for those connected to the hotspot SSID are hidden from the EA.
Refer to documentation on how to assign role and scope for more information.
End customer vs. Organization Admin
Capability / Functionality |
Organization Admin |
End customer |
All monitoring and reporting views |
Yes |
Most (with the exception of restricted hotspot SSIDs) |
| Summary Report | Yes | No (Unavailable due to complexities around isolating hotspot SSID information) |
| Security Center | Yes | No (Unavailable due to complexities around isolating hotspot SSID information) |
| Location Analytics | Yes | Yes |
| Client List | Yes | Yes (with the exception of hotspot SSID clients) Note: End customer admin cannot modify client names |
| Event Logs | Yes | Yes (with the exception of hotspot SSID clients) |
| Group Policies | Yes | Yes |
Change “SSID Admin” rights on an SSID |
Yes |
No |
Create or modify organization admin users |
Yes |
No |
Create or modify regular admin users |
Yes |
No |
| View the Site-to-site VPN page | Yes | Yes (with the exception of viewing the local subnets or Non-Meraki VPN peers) |
| View the Route Table page | Yes | Yes |
| Client VPN page | Yes | No |
| Changelog | Yes | No |
View and modify SSID settings (access control, firewall, splash page, availability) |
Yes |
Yes (with the exception of restricted hotspot SSIDs) |
Detailed firmware visibility on “Organization → overview” page |
Yes |
No |
Firmware upgrade page |
Yes |
No |
| Manage staged firmware upgrades (Switching) | Yes | No |
Dashboard branding settings |
Yes |
No |
License info |
Yes |
No |
View inventory and claim devices |
Yes |
No |
Organization → settings |
Yes |
No |
Create networks |
Yes |
No |
Access APIs |
Yes |
No |
Configuration sync |
Yes |
No |
Remote packet captures |
Yes |
No |
| Switch and AP status page historical client info | Yes | No |
| Meraki Insight | Yes | Yes |
| Early Access | Yes | No |
| Configuration Templates | Yes | No (includes changes to child networks) |
