IPv6 Support on MX Security & SD-WAN Platforms - Monitoring and Reporting
IPv6 Prefix tab
This is a single place to simply view all of the IPv6 Prefixes on a WAN appliance. This tab will provide you information regarding Manually configured prefixes (If any), Delegated prefixes from your IPv6 enabled ISPs, and which prefixes are assigned to which IPv6 enabled VLANs.
It also provides additional information such as how many prefixes are assigned and available from larger prefix blocks and prefix expiration status.
You can access this tab from the Security & SD-WAN > Monitor > Appliance status page
Ping
The WAN appliance can perform pings to both IPv4 and IPv6 addresses. The type of ping will be determined based on the address given. If a hostname is given, the WAN appliance will default to an IPv4 ping unless the hostname resolves to an IPv6 address only.
Example of an IPv4 hostname resolution
Example of an IPv6 hostname resolution
In addition, the source of a ping can be specified using the Source IP Address dropdown menu. This menu auto-populates based on the available interfaces, and will often include “Default”, “Internet” or “Internet 1/2”, and “VLAN 0” or “VLAN 1/2/3…”. The selected source will not change whether a ping is IPv4 or IPv6, as the actual source IP gets set based on the interface and the IP type of the destination.
Example of populated Source IP Address menu
Traceroute
The WAN appliance supports IPv4 and IPv6 trace routes for troubleshooting purposes. You may use an IPv4, IPv6 or a domain name to perform trace routes. If the DNS record for the domain name contains both IPv4 and IPv6 records a trace route is initiated for both. If it only contains IPv4 or IPv6 records, then the appropriate one will be performed and the other will not yield any results.
Example of a Dual Stack name Record
Example where the name record only contains IPv4
DNS Lookup
The DNS lookup tool will perform a lookup for both the IPv4 (A records) and IPv6 (AAAA records) if IPv6 is enabled on the WAN appliance and display the output as one result. The tool does this regardless of the destination (IPv4, IPv6, or hostname) or the DNS server address.
Example of a Dual Stack Record
Example of IPv4 only Record
Route Table
There are several options for configuring IPv6 Prefixes supported by the WAN appliance. In this section, we will cover the different options available, how to configure them, and how to view available prefixes.
Note:
Currently only IPv6 Local VLANs and Static routes are visible on the table.
Currently IPv6 AutoVPN routes are missing, but will be added in the future.
AutoVPN Participants table
The VPN Participants table was a view only table located in the Site-to-site VPN page; which contained all of the VPN configured Peer and Subnet/Prefix information. This table is being deprecated and a new table has been added in the Security & SD-WAN > Monitor > VPN status page.
You can now Filter, Sort and Search the table allowing you to quickly and easily locate the information you need.
Client Tracking
To view statistics for a particular client, Navigate to Network-wide > Monitor > Clients. Click on the client to open the Client Details page. This page features information about the applications, ports, and content viewed by a particular client. When Hostname Visibility has been enabled, you can view the specific destinations visited by clients. This is shown in the image below. You can see statistics about the specific applications used, transport protocol information, destination hostname or IP address, usage data, amount of traffic sent and received, and number of flows:
Event Log
Duplicate Address Detection (DAD)
DAD events help recognize duplicate address alerts and can be filtered with the following event type:
Addressing/VLAN updates
Prefix starvation
Enhanced Route Table
The new route table will bring added visibility for IPv4 and IPv6, including AutoVPN routes. This new table not only brings more visibility, but you can now sort, filter and search bringing simplicity as shown below:
Examples of the current Route Table:
Uplink Loss & Latency
Loss and latency will be determined over the configured IP address under Security & SD-WAN > SD-WAN & traffic shaping > Uplink statistics. If no IP is configured, these values will be measured against 8.8.8.8 by default. In addition to IPv4, users can now track IPv6 destinations as shown below:
Refer to the main KB: IPv6 Support on MX Security & SD-WAN Platforms [Core Fundamentals]
