Systems Manager Enrollment Supported Operating Systems
Japanese(日本語)
Overview
Meraki Systems Manager supports a variety of operating systems for enrollment from Apple, Google, and Microsoft. This document lists the supported versions of each operating system family. Note that this list changes over time as new operating systems are released for each platform.
List of Supported Operating Systems
Operating System
Supported Versions
Notes
Android
10.x
11.x
12.x
13.x
14.x
15.x
List of recommended Android Enterprise devices by Google can be found here.
Android Go does not support Android Enterprise.
iOS, iPadOS, tvOS
10.x
11.x
12.x
13.x
14.x
15.x
16.x
17.x
18.x
26.x
iPadOS first appeared as a separate OS with iOS 13.
Apple has deprecated some device management features in versions ≥ 26.x. These have been replaced by Apple with DDM (Declarative Device Management) features. Systems Manager does not support DDM, some features may no longer function on these versions.
macOS
10.10 Yosemite
10.11 El Capitan
10.12 Sierra
10.13 High Sierra
10.14 Mojave
10.15 Catalina
11.x Big Sur
12.x Monterey
13.x Ventura
14.x Sonoma
15.x Sequoia
26.x Tahoe
The minimum supported agent version is 3.8.3.
Windows
Windows 11
Windows 10, version 1703+
Windows Server 2016+
The minimum supported agent version is 3.7.2.
Windows Server is no longer supported on Agent versions 4.2.0 please see THIS community post for more context. The recommended Agent version for Windows Server 2016-2019 is 3.7.2, and the recommended Agent version for Windows Server 2022 is 4.1.1.
ChromeOS
(G Suite for Enterprise)
N/A
This OS is updated continually by Google.
Older Operating Systems
Some older versions of these operating systems are known to function properly with Systems Manager but are no longer fully supported by Meraki. We do not prevent SM from running on devices using these older versions, and can only provide “best effort support" if issues arise. There is no warranty or guarantee that SM will continue to function on these operating system versions as we release new updates to SM agents or SM dashboard features.
  • Android versions 5 - 9 (these versions can no longer be enrolled, existing enrollments will have limited functionality)
  • iOS, tvOS 9
  • macOS 10.9
  • Windows 7
  • Windows 10 — build versions older than 1703
  • Windows Server — 2008, 2008r2, 2012
  • Windows Long-Term Servicing Channel (LTSC) (formerly Windows Embedded)
  • Was this article helpful?
