Enabling WPA2-Enterprise in Windows
Overview
Manually configure Wi-Fi Protected Access 2 (WPA2)-Enterprise for your wireless network profile in Windows. Do not configure the profile while Windows is associating to the SSID, because the configuration does not save correctly. Go to the Step-by-step instructions section in this article for the configuration steps.
Windows Vista/7
- In Windows, navigate to Control Panel > Network and Internet > Network and Sharing Center.
- Select Manage Wireless networks.
- Select Add.
- Choose Manually create a network profile.
- On the next page, enter the following:
- Network name: Enter the SSID name. The SSID name is case sensitive.
- Security type: Choose WPA2-Enterprise.
- Encryption type: Choose Advanced Encryption Standard (AES).
- Check Start this connection automatically if you want Windows to connect to this network automatically.
- Check Connect even if the network is not broadcasting if the SSID is hidden and you want Windows to connect to this network automatically.
- Select Next.
If the wireless client may not trust the RADIUS server certificate, or the wireless client is not a member of the domain where the RADIUS server resides, select Change connection settings on the Successfully added page. - Choose the Security tab.
- Select Settings.
- Uncheck Validate server certificate if the wireless client may not trust the RADIUS server certificate.
- For Authentication Method, choose Extensible Authentication Protocol-Microsoft Challenge Handshake Authentication Protocol version 2 (EAP-MSCHAP v2).
- Select Configure.
- Uncheck Automatically use my Windows logon on name and password if the computer is not on the domain.
.png?revision=2)
- Select OK.
Specify user or computer authentication if the client is part of the domain or if the RADIUS policy requires machine or user authentication. To choose user or computer authentication:
To choose user or computer authentication, from the Security tab,- Select Advanced settings.
- Select the 802.1X settings tab.
- Check Specify authentication mode.
- Choose User or computer authentication. Or choose an alternate option if required.
- Select OK to close the dialogue box.
Windows 10 or Windows11
- Navigate to Control Panel > Network and Sharing Center.
- Select Set up a new connection or network.
- Select Manually connect to a wireless network.
- Encryption type: Choose AES.
- Select Next.
- Select Change connection settings.
- Select Settings.
_is_selected_from_the_toggle_option.png?revision=2&size=bestfit&width=375&height=524)
Under Choose a network authentication method, make sure to select Microsoft: Protected EAP (PEAP). - Uncheck Verify the server's identity by validating the certificate if the wireless client may not trust the RADIUS server certificate.
Under Select Authentication Method, make sure to select Secured password (EAP-MSCHAP v2). - Select Configure.
- Uncheck Automatically use my Windows logon name and password (and domain if any) if the computer is not on the domain.
.png?revision=2&size=bestfit&width=359&height=568)
- Select OK.
Specify user or computer authentication if the client is part of the domain or if the RADIUS policy requires machine or user authentication. To specify the authentication mode: - On the Security tab, select Advanced settings
- Check Specifiy authentication mode.
- Select Ok.
Your computer uses your Windows logon credentials and domain unless you uncheck Automatically use my Windows logon name and password (and domain if any), as shown in the step 12 screenshot.
- WPA2-Enterprise with 802.1X Authentication
https://documentation.meraki.com/MR/Encryption_and_Authentication/Wireless_Encryption_and_Authentication_Overview
- RADIUS: Configuring PEAP EAP-MSCHAPv2
/Wireless_LAN/Encryption_and_Authentication/Enterprise_(802.1X)/RADIUS:_WPA2-Enterprise_With_PEAP-MSCHAPv2_Using_Microsoft_NPS
