MR 32.1.7 Release Notes
MR 32.1.7 includes fixed issues and known issues.
Release summary
This release includes 26 documented fixed issues and 7 documented known issues.
Fixed issues
Issue
ID
Confirmed affected models
Confirmed affected versions
Multi-gigabit APs report receive-length errors for valid padded Ethernet frames
MR-71160
MR46, MR56, MR57, CW9176
R31.1: 31.1.5, 31.1.7
Wi-Fi 7 APs stop sending 802.1X/EAP MPDUs on 5 GHz radio when using 40 MHz channel width and minimum bitrate of 36 Mbps or higher
MR-73374
CW9176I, CW9178I
  • R31.1: 31.1.7.1
  • R32.1: 32.1.3 to 32.1.6
  • R32.2: 32.2.1, 32.2.2
APs source some ICMP related management traffic with SGT of 0 instead of the configured value
MR-73616
All APs
  • R30: 30.7.1
  • R31.1: 31.1.8
  • R32.2: 32.2.1
MR46E limiting TX power for 2.4 GHz band radio in the FCC regulatory domain
MR-75464
MR46E
  • R31.1: 31.1.8
  • R32.1: 32.1.4 to 32.1.6
AP does not contain a block list SSID if operating on a DFS channel and meshing is disabled
MR-76025
All APs
  • R31.1: 31.1.1 to 31.1.8
  • R32.1: 32.1.1 to 32.1.6
AP sends EoGRE tunnel traffic not sourced from its management IP
MR-77464
All APs
  • R31.1: 31.1.8
  • R32.2: 32.2.1
APs send wildcard (::) NAS-IPv6-Address AVP intermittently
MR-77838
All APs
  • R31.1: 31.1.8
  • R32.1: 32.1.1, 32.1.2, 32.1.4 to 32.1.6
  • R32.2: 32.2.1
MR57 configured for LACP causes MAC flap events after a failover by sending traffic out both of its uplinks
MR-78007
MR57
  • R31.1: 31.1.8
  • R32.1: 32.1.5, 32.1.6
Wi-Fi 7 APs ignore some ACK frames sent by Epson UB-R05 Wireless Interface (802.11ac) chipset
MR-78054
Wi-Fi 7: All APs
  • R31.1: 31.1.8
  • R32.2: 32.2.1
Large Adaptive Policy configurations may not be applied
MR-78486
All APs
  • R31.1: 31.1.7.1
Wi-Fi 7 APs don’t forward mDNS traffic out wireless interface when using named VLANs
MR-78546
Wi-Fi 7: All APs
  • R32.2: 32.2.1
RRM channel and power changes occur every 30 minutes
MR-80052
All APs
  • R32.2: 32.2.1 to 32.2.3
Wi-Fi 6E APs experience unexpected reboots in Gabon when booting on affected UNII-2c channels
MR-80831
All APs
  • R31.1: 31.1.8
  • R32.1: 32.1.2 to 32.1.6
  • R32.2: 32.2.1
Wi-Fi 7 APs don’t capture client wireless latency if at least one active SSID is using GCMP256 and/or SAE-EXT and 802.11be is off
MR-81748
CW9176I, CW9178I
ESL application may remain offline after a connectivity loss
MR-82957
CW9164I
  • R31.1: 31.1.7, 31.1.7.1
  • R32.1: 32.1.6
Wi-Fi 6 APs experience false positive DFS events
MR-82994
MR46, MR86
  • R31.1: 31.1.7.1
APs may reboot when RADIUS accounting servers do not respond on open SSIDs
MR-83126
All APs
  • R30: 30.7
  • R32.1: 32.1.6
Wi-Fi 6 APs requesting PoE class 4 (802.3at) instead of class 3 (802.3af)
MR-83144
MR28, MR78
  • R31.1: 31.1.8
Wireless devices unable to reach wired devices on same VLAN when using adaptive policies and connectivity is allowed between them
MR-83304
All APs
  • R31.1: 31.1.6 to 31.1.8
  • R32.1: 32.1.6
Named VLAN does not assign the expected VLAN
MR-85803
All APs
  • R32.1: 32.1.6
  • R32.2: 32.2.2, 32.2.3
CW9162I, CW9163E models experience unexpected reboot
MR-63328
CW9162I, CW9163E
Wi-Fi 7 APs experience unexpected reboot
MR-74129
CW9171I, CW9172I, CW9174I, CW9174E
  • R31.1: 31.1.7.1, 31.1.8
  • R32.2: 32.2.1
MR-75384
MR57
  • R31.1: 31.1.8
MR-82236
CW9162I, CW9163E, CW9164I, CW9166I, MR57
MR-84684
CW9162I, CW9163E
  • R32.1: 32.1.6
MR-85768
CW9176I
  • R32.2: 32.2.2
Known issues
Issue
ID
AP wireless captures unable to fully decode some Rx data traffic due to split-off/truncated bytes
MR-89089
CW9178I
  • R31.1: 31.1.8
  • R32.1: 32.1.6, 32.1.7
Access points stop sending probe responses and 802.11 open authentications on all bands (radios)
MR-81231
MR28, MR46, MR56, MR76 CW9162I, CW9164I, MR57 CW9171I, CW9172I, CW9176I, CW9178I
APs not honoring TX power on 6 GHz in the US / FCC regulatory domain
MR-86535
CW9166I, CW9179D1
  • R32.2: 32.2.3
Wi-Fi 6 APs report "Config fetch error" alerts daily after firmware upgrade
MR-84223
MR44
MR-86484
CW9176I
  • R32.2: 32.2.3
Wi-Fi 6 and Wi-Fi 6E APs experience unexpected reboot when running a packet capture manually from Dashboard
MR-88741
MR28, MR36, MR44, MR46, MR56, MR76, MR86 CW9164I, CW9166I, MR57
  • R32.1: 32.1.7
  • R32.2: 32.2.3
  • R33.1: 33.1.1
MR-88886
CW9166I, MR57
Fixed Issue Details
MR-71160 - Multi-gigabit APs report receive-length errors for valid padded Ethernet frames
Potential symptoms
The AP's wired-interface statistics may show an increasing receive-length error counter. This can be mistaken for a cabling problem or packet loss, although the reproduced discovery frames were received successfully and were not dropped by this mechanism.
Conditions
The issue occurs on affected multi-gigabit AP Ethernet interfaces when a connected switch sends valid padded 802.3 LLC discovery or keepalive frames whose length field describes a payload shorter than the minimum Ethernet frame transmitted on the wire. It was observed with MR46, MR56, and MR57 APs connected to MS150 switches and with CW9176 APs connected to MS355 switches.
Resolution
The Ethernet receive handling now accepts these valid padded 802.3 frames without incorrectly incrementing the receive-length error counter.
Workarounds
No workaround is required for connectivity when only this counter is increasing, because the reproduced frames were received successfully. Connecting the AP to a switch that does not generate the affected frame format can prevent the misleading counter increase, but may not be operationally practical. Contact Meraki Support if the AP also shows confirmed packet loss or client-impacting symptoms.
  • R31.1: 31.1.5, 31.1.7
Back to release summary
MR-73374 - Wi-Fi 7 APs stop sending 802.1X/EAP MPDUs on 5 GHz radio when using 40 MHz channel width and minimum bitrate of 36 Mbps or higher
Potential symptoms
Clients may fail 802.1X authentication and be deauthenticated because the AP stops transmitting EAP frames over the air.
Conditions
Wi-Fi 7 AP using 5 GHz with 40 MHz channel width and a minimum bitrate of 36 Mbps or higher. The issue is not known to occur with 20 MHz or 80 MHz channels or with minimum bitrates of 24 Mbps or lower.
Resolution
Updated firmware corrects transmission behavior at 40 MHz with higher minimum bitrates, allowing EAP frames to be transmitted normally.
Workarounds
Use a 5 GHz minimum bitrate of 24 Mbps or lower, or use a 20 MHz or 80 MHz channel width instead of 40 MHz. A 24 Mbps minimum bitrate is recommended because IEEE 802.11 defines it as the highest mandatory OFDM rate.
  • CW9176I, CW9178I
  • R31.1: 31.1.7.1
MR-73616 - APs source some ICMP related management traffic with SGT of 0 instead of the configured value
Potential symptoms
Some AP-generated ICMP traffic may carry SGT 0 instead of the configured SGT value, which can cause that traffic to be handled by an unexpected Adaptive Policy rule.
Conditions
Adaptive Policy is enabled. AP-generated connection-monitor pings and replies to pings sent to the AP management address can carry SGT 0 instead of the configured infrastructure SGT. Dashboard-initiated ping tests are not affected.
Resolution
AP-generated connection-monitor traffic and ICMP replies now retain and apply the configured infrastructure SGT.
Workarounds
No AP-side workaround is known. If the security policy permits, rules can temporarily account for SGT 0 on AP-generated ICMP traffic.
  • All APs
  • R30: 30.7.1
  • R31.1: 31.1.8
  • R32.2: 32.2.1
MR-75464 - MR46E limiting TX power for 2.4 GHz band radio in the FCC regulatory domain
Potential symptoms
The 2.4 GHz radio may operate at 16 dBm even when a higher transmit-power limit is configured.
Conditions
MR46E using an MA-ANT-3-B6 antenna in the FCC regulatory domain. Earlier firmware used a worst-case antenna gain instead of an antenna-specific power profile.
Resolution
Antenna-specific radio power profiles now account for MA-ANT-3-B6 gain, allowing MR46E to use the permitted transmit power.
Workarounds
No configuration workaround is known. Account for the lower 2.4 GHz transmit power in coverage planning until the AP is upgraded.
  • MR46E
  • R31.1: 31.1.8
MR-76025 - AP does not contain a block list SSID if operating on a DFS channel and meshing is disabled
Potential symptoms
Air Marshal may detect a blocked SSID without transmitting the broadcast deauthentication frames needed to contain it.
Conditions
The blocked SSID is on the same client-serving channel, wireless meshing is disabled, and containment must use a client-serving VAP. The issue is most visible on DFS channels because the scanning radio cannot provide fallback containment there.
Resolution
Containment transmission selection now retains an available client-serving interface when no mesh interface exists, allowing deauthentication frames to be transmitted with meshing disabled.
Workarounds
Enabling wireless meshing allows a mesh interface to transmit containment frames. Changing the mesh setting disrupts AP service and should be scheduled during non-critical hours. On non-DFS channels, the scanning radio may also provide containment.
  • All APs
MR-77464 - AP sends EoGRE tunnel traffic not sourced from its management IP
Potential symptoms
EoGRE client traffic may stop forwarding because tunnel packets use a stale source address rather than the AP's current management address.
Conditions
An SSID uses an EoGRE concentrator and the AP management address changes, typically following a DHCP renewal or address change.
Resolution
AP management-address changes now refresh the EoGRE tunnel source address, preventing use of a stale encapsulation source address.
Workarounds
Using a stable management IP avoids the triggering address change. Rebooting the AP after its management IP changes temporarily refreshes the EoGRE tunnel source address, but interrupts wireless service and should be scheduled during non-critical hours.
  • All APs
  • R31.1: 31.1.8
  • R32.2: 32.2.1
MR-77838 - APs send wildcard (::) NAS-IPv6-Address AVP intermittently
Potential symptoms
RADIUS Access-Requests may contain a wildcard NAS IPv4 or IPv6 address, which can affect server policy matching, logging, or authentication handling.
Conditions
A RADIUS-enabled SSID is active while the AP management address changes and wireless authentication restarts during the brief interval in which the NAS address is unavailable.
Resolution
RADIUS-authenticated SSIDs now wait for a valid NAS address before starting authentication services, preventing unspecified addresses from being sent.
Workarounds
Use stable AP management addressing where practical. After changing an AP management address, confirm that RADIUS requests contain the expected NAS address before relying on address-based server policy.
  • All APs
  • R31.1: 31.1.8
  • R32.2: 32.2.1
MR-78007 - MR57 configured for LACP causes MAC flap events after a failover by sending traffic out both of its uplinks
Potential symptoms
An upstream switch may report MAC flapping and client traffic may be disrupted because an AP sends traffic through both uplinks after failover recovery.
Conditions
MR57 with AP-side LACP configured, connected to switch ports that are not configured for LACP, after an uplink fails and later reconnects.
Resolution
The AP now returns traffic to the primary uplink after it reconnects, preventing simultaneous forwarding across both links in this configuration.
Workarounds
Where the network topology permits, configure a supported end-to-end LACP connection. Otherwise, using a single AP uplink avoids MAC flapping after failover but removes uplink redundancy.
  • MR57
  • R31.1: 31.1.8
MR-78054 - Wi-Fi 7 APs ignore some ACK frames sent by Epson UB-R05 Wireless Interface (802.11ac) chipset
Potential symptoms
Epson printers using the UB-R05 wireless interface may fail association or authentication while the AP retransmits frames despite over-the-air acknowledgements.
Conditions
Wi-Fi 7 AP with an Epson UB-R05 802.11ac client, particularly on 5 GHz. For OFDM operation, IEEE 802.11 specifies a 16-microsecond Short Interframe Space (SIFS) before an acknowledgement response. The client begins transmitting acknowledgements before that interval, outside the specified timing.
Resolution
Older-generation Wi-Fi radio handling had already adjusted receive timing to accommodate similar client behavior reported by multiple enterprise equipment providers. Those adjustments were not applied by default to the newer Wi-Fi 7 chipset firmware, whose receive path remained disabled during much of SIFS to limit false packet detections. Updated Wi-Fi radio handling starts receive processing earlier and aligns receive-window timing across radio generations, allowing these early acknowledgements to be recognized.
Workarounds
No confirmed AP configuration workaround is available. Contact Meraki Support if affected clients cannot associate reliably.
  • Wi-Fi 7: All APs
  • R31.1: 31.1.8
  • R32.2: 32.2.1
MR-78486 - Large Adaptive Policy configurations may not be applied
Potential symptoms
Adaptive Policy rules or bindings may not be installed, allowing traffic that the configured policy is intended to deny.
Conditions
Adaptive Policy is enabled and the valid policy configuration exceeds the previous 64 KB processing limit. This was observed with approximately 75 KB of policy data even though individual ACL and binding counts remained within supported limits.
Resolution
Firmware now accepts larger valid Adaptive Policy configurations, allowing supported ACL and binding counts to be applied when their combined data exceeds the previous limit.
Workarounds
Reduce the number or complexity of Adaptive Policy ACLs and bindings so the combined configuration remains below the previous size limit. Confirm that the reduced policy still provides the required access controls.
  • All APs
  • R31.1: 31.1.7.1
MR-78546 - Wi-Fi 7 APs don’t forward mDNS traffic out wireless interface when using named VLANs
Potential symptoms
Wireless clients may be unable to discover services from other wireless clients because mDNS multicast traffic is dropped.
Conditions
A Wi-Fi 7 AP uses named VLAN assignment for clients that use multi-link operation. mDNS traffic can be compared against the wrong client VLAN and dropped.
Resolution
Firmware now associates mDNS traffic with the correct client data path and named VLAN, allowing multicast service discovery to be forwarded.
Workarounds
Use numeric VLAN IDs instead of named VLAN assignment on affected SSIDs. This requires an SSID and RADIUS configuration change.
  • Wi-Fi 7: All APs
  • R32.2: 32.2.1
MR-80052 - RRM channel and power changes occur every 30 minutes
Potential symptoms
APs may change channel or transmit power approximately every 30 minutes, causing repeated client connectivity interruptions.
Conditions
Meshing is enabled. The AP can treat its own mesh transmissions as strong external interference, causing RRM to make unnecessary channel or transmit-power changes during periodic optimization.
Resolution
Firmware now filters the AP’s own mesh-interface observations before they reach the Radio Resource Management calculation, preventing them from driving unnecessary channel or transmit-power changes.
Workarounds
Disable wireless meshing on the affected network when mesh connectivity is not required. Changing the mesh setting, including disabling or re-enabling it, disrupts service on the AP and should be performed only during non-critical hours.
  • All APs
MR-80831 - Wi-Fi 6E APs experience unexpected reboots in Gabon when booting on affected UNII-2c channels
Potential symptoms
The 5 GHz radio may fail to start and the AP may repeatedly reboot.
Conditions
APs operating in Gabon. The Meraki cloud regulatory policy allows affected UNII-2c channels, including channel 104, but the AP's separate regulatory database omits them. When one of these channels is included in the AP's boot configuration, the wireless service rejects the channel during its standard startup checks and exits. The AP health monitor then reboots the AP because the service is no longer running, creating a reboot loop. If the AP first boots on a locally allowed channel and is later asked to use an omitted channel, it rejects the channel change but continues operating.
Resolution
The AP regulatory database now includes the same permitted UNII-2c channels as the Meraki cloud policy for Gabon. This keeps the two independent regulatory enforcement mechanisms aligned and allows wireless service startup to complete.
Workarounds
Use manual channel assignment to select a channel accepted by the AP's local regulatory database, or exclude the affected UNII-2c channels in the RF profile. If channel selection cannot otherwise be constrained, avoid dual-5 GHz mode by disabling the second 5 GHz radio. This also prevents the reboot loop but reduces radio capacity. Channel or radio changes disrupt wireless service and should be scheduled during non-critical hours.
All APs
  • R31.1: 31.1.8
  • R32.2: 32.2.1
MR-81748 - Wi-Fi 7 APs don’t capture client wireless latency if at least one active SSID is using GCMP256 and/or SAE-EXT and 802.11be is off
Potential symptoms
Dashboard wireless-latency values may be zero, unavailable, or shown as insufficient data on client, AP, and Performance Health pages.
Conditions
A Wi-Fi 7 AP has at least one active SSID using GCMP-256 or SAE-EXT while 802.11be is disabled. A radio-software change incorrectly treated the control used to enable latency capture as a Wi-Fi 7-only setting. When the AP operated in Wi-Fi 6 mode, the radio rejected the enable request and latency collection did not start.
Resolution
Radio software now handles the latency-capture control independently of Wi-Fi 7-specific controls, so the enable request is accepted in both Wi-Fi 6 and Wi-Fi 7 operation.
Workarounds
Enable 802.11be, or avoid GCMP-256 and SAE-EXT on active SSIDs while 802.11be is disabled. Changing radio mode or SSID security can disrupt clients and should be scheduled during non-critical hours; use alternative security settings only when permitted by the organization's security policy.
  • CW9176I, CW9178I
MR-82957 - ESL application may remain offline after a connectivity loss
Potential symptoms
The Electronic Shelf Label (ESL) application may remain offline after the AP loses and regains cloud connectivity.
Conditions
After a connectivity failure causes the ESL application to stop, incomplete cleanup can leave the stopped application container in place and block its restart.
Resolution
Firmware now completes cleanup of a stopped application container, allowing the ESL service to restart normally.
Workarounds
Rebooting the AP clears the stopped application state and restores the ESL application temporarily. The reboot interrupts wireless service and should be scheduled during non-critical hours.
  • CW9164I
  • R32.1: 32.1.6
MR-82994 - Wi-Fi 6 APs experience false positive DFS events
Potential symptoms
APs may report excessive false Dynamic Frequency Selection (DFS) events and repeatedly leave DFS channels even when no radar is present. This can concentrate radios on UNII-1 channels, increasing co-channel interference, reducing client throughput, and disrupting clients during channel changes.
Conditions
MR46 or MR86 operating on DFS/UNII-2c channels.
Resolution
Updated Wi-Fi radio handling improves radar-event detection so non-radar activity is less likely to trigger an unnecessary DFS channel change.
Workarounds
Enable AI Channel Planning in Dashboard. It monitors DFS hits per AP and channel and temporarily places frequently affected channels on a per-AP Channel Avoid List. This can reduce repeated use of channels producing false DFS events. Alternatively, manually exclude affected DFS channels in the RF profile. Either approach reduces available 5 GHz spectrum and should be used only where the resulting channel plan is acceptable.
  • MR46, MR86
  • R31.1: 31.1.7.1
MR-83126 - APs may reboot when RADIUS accounting servers do not respond on open SSIDs
Potential symptoms
The AP may reboot after a client joins the affected SSID. It can enter a reboot loop if clients reconnect before RADIUS accounting service is restored.
Conditions
An open SSID uses RADIUS accounting without RADIUS authentication, all configured accounting servers are unreachable, and a client associates. After the AP exhausts its accounting-request retries, the wireless service attempts to record the failure using authentication-server information that is not configured on an accounting-only SSID. This causes the wireless service to exit, after which the AP health monitor reboots the AP.
Resolution
Firmware now selects the configured accounting server when processing accounting failures and the configured authentication server when processing authentication failures. An unreachable accounting server therefore no longer causes the AP to reference missing authentication-server information or reboot.
Workarounds
Restore reachability to at least one RADIUS accounting server, or temporarily disable RADIUS accounting on the affected open SSID. Disabling accounting prevents accounting records from being sent. If the AP is already in a reboot loop, temporarily disable the affected SSID until an accounting server is responding; this disconnects clients and prevents use of that SSID.
  • All APs
  • R30: 30.7
  • R32.1: 32.1.6
MR-83144 - Wi-Fi 6 APs requesting PoE class 4 (802.3at) instead of class 3 (802.3af)
Potential symptoms
An MR28 or MR78 may request PoE class 4 power (25.5 W) instead of its expected class 3 power budget.
Conditions
MR28 or MR78 connected to PoE infrastructure that reports or allocates power according to the requested class.
Resolution
MR28 and MR78 now request their correct 12 W power requirement, corresponding to PoE class 3.
Workarounds
No operational workaround is required. Until upgrade, ensure the PoE infrastructure has sufficient budget for the higher power reservation.
  • MR28, MR78
  • R31.1: 31.1.8
MR-83304 - Wireless devices unable to reach wired devices on same VLAN when using adaptive policies and connectivity is allowed between them
Potential symptoms
A wireless client may be unable to reach a wired client on the same VLAN even when the configured Adaptive Policy permits the traffic.
Conditions
Adaptive Policy is enabled and a wireless client communicates with a wired client on the same VLAN under a protocol-specific policy. Address-resolution traffic can be denied before the allowed IP session begins.
Resolution
Address-resolution traffic is now handled separately from protocol-specific IP policy checks, allowing same-VLAN communication while preserving policy enforcement for subsequent traffic.
Workarounds
Place the wired and wireless clients on different VLANs, where routing occurs before the Adaptive Policy check. This changes network segmentation and may require corresponding routing and policy updates.
  • All APs
  • R32.1: 32.1.6
MR-85803 - Named VLAN does not assign the expected VLAN
Potential symptoms
A client may be assigned to the wrong VLAN even though RADIUS returns the expected named VLAN.
Conditions
Named VLAN assignment is supplied by RADIUS and the Dashboard control "Enable Named VLAN for use with RADIUS" is enabled, but the separate named-VLAN tagging setting on the SSID is disabled. The AP can ignore the VLAN name returned by RADIUS.
Resolution
Named VLAN processing now honors the Dashboard "Enable Named VLAN for use with RADIUS" control and applies the VLAN name returned by RADIUS.
Workarounds
Use a numeric VLAN ID from RADIUS, or enable named-VLAN tagging in the SSID Access Control settings in addition to the RADIUS named-VLAN control. Either option requires an SSID or RADIUS configuration change.
  • All APs
  • R32.1: 32.1.6
MR-63328 - CW9162I, CW9163E models experience unexpected reboot
Potential symptoms
Affected APs may intermittently reboot, temporarily interrupting wireless service.
Conditions
CW9162I and CW9163E APs can experience this issue during normal operation. No narrower network configuration or client trigger is currently known.
Resolution
Updated Wi-Fi radio handling improves control-command processing so sustained radio activity does not trigger an AP recovery reboot.
Workarounds
No confirmed configuration workaround is available. Contact Meraki Support if repeated reboots occur.
  • CW9162I, CW9163E
MR-74129 - Wi-Fi 7 APs experience unexpected reboot
Potential symptoms
Affected Wi-Fi 7 APs may intermittently reboot, temporarily interrupting wireless service.
Conditions
The Wi-Fi radio handling uses a buffer to hold pending control commands sent from the AP software to the radio. This buffer was too small for periods of sustained control activity and could fill before earlier commands completed, leaving the radio unable to accept another request and causing a recovery reboot.
Resolution
Updated Wi-Fi radio handling increases the capacity of the pending radio-control command buffer so bursts of control activity can be absorbed without forcing an AP recovery reboot.
Workarounds
  • CW9171I, CW9172I, CW9174I, CW9174E
  • R32.2: 32.2.1
MR-75384 - Wi-Fi 6E APs experience unexpected reboot
Potential symptoms
Affected Wi-Fi 6E APs may unexpectedly reboot during client authentication.
Conditions
On MR57, a timing-dependent condition can occur when client authorization overlaps encryption-key installation. The condition is intermittent and does not occur with every client authentication.
Resolution
Firmware now completes encryption-key installation before authorizing the client, preventing the event-order race that caused the reboot.
Workarounds
  • MR57
  • R31.1: 31.1.8
MR-82236 - Wi-Fi 6E APs experience unexpected reboot
Potential symptoms
Affected Wi-Fi 6E APs may intermittently reboot, temporarily interrupting wireless service.
Conditions
On the listed APs, certain 6 GHz receive framing errors can leak buffers from the radio's receive-packet pool. Repeated occurrences can eventually exhaust the available packet buffers, forcing a radio recovery and AP reboot.
Resolution
Updated Wi-Fi radio handling flushes and releases receive-packet buffers after these framing errors, preventing the packet-buffer pool from being exhausted and avoiding the resulting reboot.
Workarounds
  • CW9162I, CW9163E, CW9164I, CW9166I, MR57
MR-84684 - Wi-Fi 6E APs experience unexpected reboot
Potential symptoms
Conditions
Resolution
Updated Wi-Fi radio handling improves low-level radio transaction handling to prevent the timeout that caused the reboot.
Workarounds
  • CW9162I, CW9163E
  • R32.1: 32.1.6
MR-85768 - Wi-Fi 7 APs experience unexpected reboot
Potential symptoms
Affected Wi-Fi 7 APs may unexpectedly reboot while processing a client connection.
Conditions
On CW9176I with Wi-Fi 7 multi-link clients, a timing-dependent client-state condition can cause the wireless authentication service to fail.
Resolution
Firmware now validates and handles multi-link client state safely so the authentication service continues operating.
Workarounds
  • CW9176I
  • R32.2: 32.2.2
Known Issue Details
MR-89089 - AP wireless captures unable to fully decode some Rx data traffic due to split-off/truncated bytes
Potential symptoms
AP wireless captures may contain duplicated Rx EAPOL, ARP, DHCP, or DNS traffic represented as additional 802.11 fragments. The more severe malformed/truncated-frame behavior reported on earlier firmware is not confirmed on r32.1.7.
Conditions
On CW9178I, this behavior can occur when proactive packet capture and a manual AP wireless capture run at the same time. It can occur with 20 MHz, 40 MHz, or 80 MHz channel widths.
  • CW9178I
  • R31.1: 31.1.8
Potential workarounds
From Dashboard, navigate to Network-wide > Monitor > Intelligent Capture, open the Proactive PCAP Enablement tab, and remove the affected AP from the devices enabled for automatic capture. This prevents proactive and manual AP wireless captures from running at the same time, but automatic captures for client association and authentication failures will no longer be collected for that AP. Use an independent over-the-air monitor-mode capture when exact frame-level analysis is required.
MR-81231 - Access points stop sending probe responses and 802.11 open authentications on all bands (radios)
Potential symptoms
APs may continue beaconing but stop replying to probe requests and open-authentication frames, preventing clients from discovering or joining SSIDs on one or more radios.
Conditions
The issue is introduced in 32.1.6 and can leave a radio beaconing while no longer transmitting probe responses or open-authentication replies. Reports occurred after roughly 2 to more than 20 hours.
  • MR28, MR46, MR56, MR76
  • CW9162I, CW9164I, MR57
  • CW9171I, CW9172I, CW9176I, CW9178I
Rebooting the AP or changing the affected radio's channel temporarily restores service. Either action disrupts connected clients and should be scheduled during non-critical hours when possible.
MR-86535 - APs not honoring TX power on 6 GHz in the US / FCC regulatory domain
Potential symptoms
A 6 GHz radio may operate below its configured static transmit power.
Conditions
Wi-Fi 6E or Wi-Fi 7 AP in the FCC regulatory domain on certain 6 GHz channels and channel widths. Reports include CW9166I and CW9179D1; the observed limit varies by channel and width.
  • CW9166I
  • CW9179D1
  • R32.2: 32.2.3
Try a different 6 GHz channel or channel width where coverage planning permits, because the observed limit varies by channel and width. Channel changes disrupt connected clients and may affect coverage or capacity. Contact Meraki Support if reduced power continues to affect coverage.
MR-84223 - Wi-Fi 6 APs report "Config fetch error" alerts daily after firmware upgrade
Potential symptoms
Dashboard may report a Config fetch error that later clears after the AP retries and successfully downloads its configuration.
Conditions
On MR44 APs after a firmware upgrade, a transient secure configuration-download failure can raise the alert, but a later retry normally succeeds. The issue is not confirmed on other AP models.
  • MR44
The alert generally clears after the AP retries without intervention. Contact Meraki Support if it persists or configuration changes are not applied.
MR-86484 - APs experience unexpected reboot
Potential symptoms
An affected AP may unexpectedly reboot, temporarily interrupting wireless service.
Conditions
CW9176I can continue to experience unexpected reboots after upgrade to r32.1.7. Additional reports remain under investigation, and no configuration trigger is currently known.
  • CW9176I
  • R32.2: 32.2.3
No confirmed workaround is available. Contact Meraki Support if repeated reboots occur.
MR-88741 - Wi-Fi 6 and Wi-Fi 6E APs experience unexpected reboot when running a packet capture manually from Dashboard
Potential symptoms
Starting or running a wireless packet capture may disconnect clients and cause the AP to unexpectedly reboot.
Conditions
Affected Wi-Fi 6 and Wi-Fi 6E models while taking a packet capture. Reports often involved active traffic and 10 or more associated clients; both short and longer captures have reproduced the failure.
  • MR28, MR36, MR44, MR46, MR56, MR76, MR86
  • CW9164I, CW9166I, MR57
  • R32.1: 32.1.7
  • R32.2: 32.2.3
  • R33.1: 33.1.1
Avoid AP wireless packet captures on affected APs when possible. If a capture is required, contact Meraki Support before starting it.
MR-88886 - Wi-Fi 6E APs experience unexpected reboot
Potential symptoms
Affected Wi-Fi 6E APs may unexpectedly reboot, temporarily interrupting wireless service.
Conditions
MR57 and CW9166I can experience this issue during normal operation. No specific configuration, client type, or traffic trigger is currently known.
  • CW9166I, MR57
