Home > General Administration > Other Topics > Packet Captures on Mobile Devices
Table of contents
Overview
When troubleshooting network issues, the best place to start troubleshooting is with the client device. Often times a packet capture will help quickly narrow down the problem. With regular computers, it's easy to just run Wireshark. But to troubleshoot mobile devices it's not as straightforward to get those captures started. This article can be used as a basic guide to get the packet capture up and running on your mobile device.
Apple Devices
Packet captures for iPhone/iPad must be done directly from a Mac.
1. You'll need to make sure that you have downloaded Xcode from the Mac App Store.
2. Open Xcode
3. Navigate to the Menu Bar > Window > Devices, or use the keyboard shortcut Shift + Command + 2.
4. Make sure that your Apple device is plugged into your computer. Copy the 40-characters-long identifier.
5. Open a Mac Terminal window. Run the following command (replacing the long string with your unique identifier):
rvictl -s 354825d5768de53b8f2e10e26b734f765dxxxxxx
You should get the output that the commanded succeeded (troubleshooting a failure to pair is outside of the scope of this document).
6. Open Wireshark. You can now select the rvi0 interface for your Wireshark capture.
7. Troubleshoot as necessary. Here you can see that an iPhone connecting to meraki.cisco.com was filtered.
Last modified
Tags
Classifications
Explore the Product
Click to Learn More
Article ID
Explore Meraki
Explore Meraki
Contact Support
Open a Case
Ask the Community
Visit the Community
