Cisco Meraki
Cisco+ Secure Connect - IdP Azure AD SAML Configuration
Overview
Security Assertion Markup Language (SAML) authentication may be configured for Active Directory (AD) integration, providing individual user and group-based identities for policy enforcement.
Deployment
Go to Secure Connect -> MONITOR -> Users, select your identity provider, click Start under "Bring Your ID Provider".
This will take you to the Umbrella Dashboard.  In this quickstart, you use the Azure Active Directory Admin Center to add an enterprise application (Cisco Umbrella) to your Azure Active Directory (Azure AD) tenant. You will configure Cisco Umbrella as a SAML based SSO provider.
To complete the Azure configuration, you first need to download the Umbrella metadata file
Step  1           On Cisco Umbrella, navigate to Deployments->Configuration->SAML Configuration and click Add
Step  2           Select Azure as your Identity Provide (IdP) and click Next
Step  3           On the resulting screen, select Download the Umbrella Metatdata file and leave this screen open.  You will pick up configuration from this point later.
Step  4           Go to the Azure Active Directory Admin Center and sign in
Step  5           In the left menu, select Enterprise applications. The All applications pane opens and displays a list of the applications in your Azure AD tenant.
Step  6           In the Enterprise applications pane, select New Application.
Note: The Browse Azure AD Gallery pane opens and displays tiles for cloud platforms, on-premises applications, and featured applications. Cisco Umbrella is listed twice in this gallery, however, these listings are not applicable for this use case-SAML authentication of remote access users.
Step  7           Select Create your own application and enter a name that you want to use to recognize the instance of the application. For example, SAML for Cisco Umbrella for RAS.
Step  8           Select Integrate any other application you don’t find in the gallery (non-gallery)
Step  9           Select Create
Step  10        In the resulting Overview screen, select Assign users and groups
Step  11        On the resulting screen, select Add user/group
Step  12        On the resulting Add Assignment pane, select None Selected under Users and groups.
Search for and select the user that you want to assign to the application. For example, user1@yourdomain.com.
Step  13        Select Select.
Step  14        On the Add Assignment pane, select Assign at the bottom of the pane.
Enable Single-Sign On
Now that you’ve selected your users, in the Manage section of the left menu select Single sign-on to open Single sign-on pane for editing
Step  15        Select the SAML tile to continue
Step  16        On the resulting screen, select Upload metadata file.  This is the xml file that you downloaded from Cisco Umbrella from step 3.
Step  17        Once the upload is successful, click Save on the resulting Basic SAML Configuration pane
Step  18        Scroll down to the SAML Signing Certificate section and download the Federation Metadata XML
Step  19        Now upload this Azure metadata xml file to Cisco Umbrella ( where you left off at Step 3 above) and click Next
Step  20        From the Re-Authenticate Users drop-down list, choose how often Umbrella re-authenticates users: Never, Daily, Weekly, or Monthly
Step  21        Click Save
Step  22        To verify that the integration is successful, press the Test Configuration button
A success looks like this:
If you receive a failure, go back to Azure and click the Test button and follow the resolution guidance provided.
Next Steps
see Cisco+ Secure Connect Azure SCIM Integration
  • Was this article helpful?
