Accelerated Navigation with Search
With Accelerated Navigation via Search, you can search for a page using a list of designated keywords, in addition to the page title.
Navigation Search
1 - Scroll to the bottom of the left navigation panel, below the menu section.
2 - Click on Find in Menu, and a search bar will appear.
You can also open the Accelerated Navigation search box using the keyboard shortcut Cmd + K for Mac or Ctrl + K for Windows.
3 - The search feature allows you to use designated keywords indexed for a page, not just the page title. When you enter keywords in the search bar, any page matching those keywords will appear in the results. You can search for all features and pages accessible in the current network and organization.
4 - Search results will be displayed in the format of a page navigation breadcrumb. Use the up and down arrow keys to navigate through the results. Press Return or Enter to select a result, and the tab will update accordingly. If no matches are found, "No matches found" will be displayed.
5 - To close the search box, click outside of it or press the Esc key.
Benefits of Navigation Search
- Improve feature findability by allowing you to find features based on various keywords, in addition to page name.
- Accelerate time to start tasks by showing all relevant features in one place.
- Increase dashboard learnability, usability, and scalability.
* The Accelerated Navigation feature is currently available in English only.
