Packet Capture Overview
如欲查看中文版本,请点击 这里
Click 日本語 for Japanese
The packet capture utility observes live network traffic passed by Cisco Meraki devices. Captures provide a live snapshot of traffic on the network and are useful for diagnosing and troubleshooting network issues. This article outlines how to remotely take a packet capture in the Meraki dashboard.
Meraki support seeks prior written permission from a customer’s organization administrator or network administrator before initiating a packet capture on behalf of a customer.
Once a capture is complete, the data is accessible only through the selected output. To ensure privacy and security, traditional packet capture data is not stored in the Meraki cloud.
Packet capture is available to administrators with full organization or full network access, and to Switch Port Manager admins only when the custom role has Allow packet capture enabled. Read-only and monitor-only admins (including org read-only and network read-only) cannot run packet captures.
Learn more with this free online training course on the Networking Learning Hub:
Packet captures
Packet captures allow you to make copies of frames passing through a network device for inspection. This is useful for troubleshooting or forensic analysis. This section covers traditional Meraki packet capture utility, which is available for MX and MS product lines under Network-wide > Monitor > Packet Capture. An additional dropdown allows you to select which type of device to perform the capture on, based on what is present in the network.
Capture options
The packet capture tool provides multiple options for selecting which packets to capture and on which interface. You can also select how to view the capture data.
When performing a packet capture, use the Output > Download .pcap file (for Wireshark) option and open the resulting raw capture in Wireshark. When you select this option, the Verbosity option is not available because all traffic and information is captured.
When you select Output > Download .pcap file (for Wireshark), the capture will stop after 60 seconds if no traffic is captured, regardless of the duration set.
View output in a web browser
If you select View output below from the Output dropdown, it will display basic data about the ingress and egress packets on the selected interface. If more detail is needed, another Output option should be selected.
When you select Output > View output below option, the capture will stop after 20 seconds if no traffic is captured, regardless of the duration set.
Verbosity level descriptions
When you select Output > View output below option, the Verbosity option is used to determine how much detail appears in the output. These options correspond to the following flags in tcpdump.
Low -> (No flag)
Provides basic information about the packet's source, destination, and type.
Medium -> -v
When parsing and printing, produce (slightly more) verbose output. For example, the time to live, identification, total length and options in an IP packet are printed. Also enables additional packet integrity checks such as verifying the IP and ICMP header checksum.
High -> -vv
Even more verbose output. For example, additional fields are printed from NFS reply packets, and SMB packets are fully decoded.
Extra high -> -vvv
Even more verbose output. For example, telnet SB ... SE options are printed in full.
The whole ball of wax -> -X
When parsing and printing, in addition to printing the headers of each packet, print the data of each packet (minus its link level header) in hex and ASCII. Note that use of this flag generates a great deal of output, and should only be used if needed.
Download .pcap
You can download a packet capture file to your local computer by selecting Download .pcap file (for Wireshark). This file can then be opened with a program such as Wireshark seconds that can be specified for the capture length. With MR products, the maximum amount of packets captured is 100,000.
Refer to the Wireshark Wiki for additional information on how to filter and utilize the .pcap file
MX WAN appliances and Z-Series teleworker gateways
The following options are available for packet captures on MX WAN appliances or Z-Series teleworker gateways:
- Security appliances: The MX WAN appliance or Z-Series the capture will run on.
- Interface: Select the interface to run the capture on; the interface names will vary depending on the MX WAN appliance configuration. Examples of interfaces include:
- Internet 1 or Internet 2 - Capture traffic on one active WAN uplink. Internet 2 appears only if there is a second WAN link.
- LAN - Captures traffic from all LAN ports
- Cellular - Captures cellular traffic from the integrated cellular interface. This does not apply to USB modems.
- Site-to-Site VPN - Captures Auto VPN traffic between MX WAN appliances and Z-Series only.
- IPsec VPN - Captures from all Non-Meraki VPN traffic.
- Client VPN - Captures all traffic to or from Client VPN connections.
- AnyConnect VPN - Captures all traffic to or from Cisco Secure Client connections.
- Output: Select how the capture should be displayed: view output below or download .pcap.
- Verbosity: Select the level of the packet capture. This option is only available when View output below is selected as the output option.
- Ignore: Optionally ignore capturing broadcast or multicast traffic. This option is only available when View output below is selected as the output option.
- Filter expressions: Apply a capture filter.
The MX WAN appliance and Z-Series allow users to capture on multiple different interfaces. A capture on the site-to-site VPN interface contains all Meraki site-to-site VPN traffic and does not contain third-party VPN traffic.
Similar to other products, a single packet capture is limited to 100,000 packets.
MX WAN appliances and Z-Series cannot capture traffic that they switch between LAN clients. Only routed traffic, or broadcast and multicast traffic that is flooded on the LAN, will be visible.
An access port is assigned to one specific VLAN and only communicates with that VLAN. If a frame arrives for a different VLAN, the MX filters this traffic at the OS or hardware level depending on the model, so this traffic may not be visible in MX packet captures.
MS switches
This section covers traditional packet captures for switches. Intelligent capture for switches is available for devices running MS 17.1 or above and after enabling the Intelligent Capture feature from the Organization > Configure > Early Access page. Information about Intelligent Capture can be found in the Intelligent Capture section below.
The following options are available for packet captures on switches:
Switch: Select the switch to run the capture on.
Switch ports: Select the switch port(s) to run the capture on.
Output: Select how the capture should be displayed: View output below or Download .pcap.
A switch can run a packet capture on one or more switch ports at a time. Switch port mirroring can also be used for a longer duration capture. Refer to the Packet Captures and Port Mirroring on the MS Switch for more information about switch port mirroring configuration.
Without the 'Intelligent Capture' feature, a single packet capture is currently limited to 100,000 packets. Data is streamed live directly from the switch source interface(s) to the user's browser session (over HTTPS, 443). If there is more traffic being captured than the internet connection allows, the capture may be incomplete. In this case, a switch port mirror (span) is recommended.
Packet captures on access switch ports may show an 802.1q VLAN tag on ingress and egress traffic. This is a consequence of how packet captures are performed on Meraki MS switches.
The Meraki MS120, MS125 and MS130 series switches do not support dashboard based packet captures on network switch ports connected to other MS switches within the same dashboard network.
Intelligent captures
Similarly to traditional packet captures, intelligent captures allow you to make copies of frames passing through a network device for inspection, which is useful for troubleshooting or forensic analysis. This section covers enhancements to previous versions of the Meraki packet capture utility provided by cloud-based packet capture (Intelligent capture).
Requirements and limitations
Intelligent captures are currently supported for Meraki Switches and Access Points. Since the feature is currently in deployment, details are subject to change.
Requirements for Cloud Managed Access Points:
- Intelligent capture: MR 30 or above
- Proactive PCAP: MR 31.1.3 or above using Wi-Fi 6/6e or newer access point models*
- Manual packet capture for MR: MR 27 or above supporting Wi-Fi 5/6/6e or newer access point models*
*excluding Meraki MR45/55 model
Intelligent Captures are enabled by default for networks that are matching the requirements.
By default, Tx Packet capture is activated for all Intelligent Capture actions. if network includes MR 29.x or lower version of firmware AP, Tx packet capture will be disabled.
Requirements for Cloud Monitoring for Wireless Access Points:
- Intelligent capture: IOS XE 17.18.2 or above
- Supported Access Points
- Wi-Fi 7: All CW917X Models
- Wi-Fi 6E: C9136 and All CW916X Models
- Wi-Fi 6: C9130AXI/E, C9124AXI/D/E, C9120AXI/E
Only on demand and scheduled captures are supported. Proactive PCAP is not supported
Requirements for switches:
- Intelligent Capture: MS 17.1 or above; IOS XE 17.15
The current limits of the 'Intelligent Capture' feature, such as duration, file size, and packet count, vary depending on the device and the selected output. These limits can be viewed by hovering over the '(i)' icon next to the 'Duration (secs)' field:
Capture options
Intelligent Capture sends your packet capture data to the Meraki Cloud. To send data to your local browser only, select View Output Live. This works in the same way as traditional packet captures. The Download option will trigger a local file download in addition to sending the capture to the Meraki Cloud. Intelligent Capture also offers several new capture options:
Save to Cloud
Saves packet captures to the Meraki dashboard for storage and later reference. You can find saved captures in Stored Captures tab.
Quick View
This option allows you to review the capture details in your browser once the capture has completed. The capture is saved to the cloud and is available in the Stored Captures tab.
Managing stored captures
The Stored captures tab allows you to view, download, or delete previously stored captures. The table lists the following details about each capture:
- Time of capture
- File name
- Device (and port for switches) the capture was performed on
- The user that created the capture
- Capture Status
- Source
- File size
- Notes
The following options are available to manage each capture:
- Select the file name of the capture to open the embedded viewer.
- Select the capture options button at the far right of the capture entry to view, download a copy, or delete the capture.
This section also stores Proactive PCAPs for access points. The list shows the timestamp of the packet capture, the client that failed, and failure reason that triggered a Proactive PCAP on an access point. Users can also view and download any packet capture file by selecting the … option under the Action column and selecting View or Download. Selecting the packet capture name opens the embedded viewer, as shown in the next section.
Viewing captures
Click on the file name under the Stored Captures tab to open the embedded viewer to view a capture. This viewer allows you to apply filters to quickly identify interesting frames, and select individual frames for detailed inspection.
Enter filter expressions into the filter field and the filter field background will turn light green for a valid expression, or light red when an invalid expression is entered. Once a valid filter expression is entered, select Apply to display in the frame list only the frames that match the filter. Select Clear to remove the filter and display all of the frames from the capture.
Wireshark's Display Filter webpage can be used to find filters to apply to packet captures.
802.11 frames : A starter guide to learn wireless sniffer traces contains more information about what can be found in 802.11 captures, which can be useful when analyzing wireless packet captures.
Expand or collapse the decoded frame info in the bottom left hand pane. Selecting a particular decoded field highlights the corresponding frame bytes in the bottom right hand pane. Click Ok to dismiss the viewer window.
Access Points
Intelligent capture for access points introduces a way to automate the packet capture process. Intelligent capture allows network engineers to initiate and retrieve packet captures on demand remotely. Intelligent capture enabled and replaced legacy Packet Capture. Customer can find it from Network-wide > Monitor > Intelligent Capture (replaces Packet Capture):
The sections below covers licensing requirements, manual captures and proactive PCAP features.
Licensing requirements
MR Enterprise (ENT) license allows storage of up to 10 capture files in the cloud. Each file can be up to 100,000 packet count. When the limit is reached and a new capture is taken, the older capture will be automatically deleted to ensure sufficient space.
MR Advanced (MR-ADV) license is required to use the Proactive PCAP feature and to extend storage space in the cloud for manual captures to 5 GB per network. This license unlocks advanced features, which includes automatically capturing network packets based on predefined triggers or conditions. This capability supports proactive network monitoring and troubleshooting, allowing network administrators to preemptively address issues before they escalate into significant problems. Refer to the MR License Guide for more details
DNA Essentials license allows storage of up to 10 capture files in the cloud. Each file can be up to 100,000 packet count. When the limit is reached and a new capture is taken, the older capture will be automatically deleted to ensure sufficient space.
DNA Advantage license is required to extend storage space in the cloud for manual captures to 5 GB per network.
Creating a capture
The Intelligent Capture page operates similarly to the traditional Packet Capture page for access points. Intelligent capture has been not only refreshed with new visuals and options, but most importantly, it adds the ability to save packet capture files to the cloud. The packet capture file stored in the cloud is available to view, analyze and download for 90 days with no additional cost to the user. The Tx Packet capture function on legacy Packet Capture feature is enabled by default.
A manual packet capture on access point(s) can collect up to 100,000 packets. Once it reaches the limit, the packet capture session will automatically finish.
A Stop capture button is available for the manual packet capture process. This allows packet captures to be stopped at any time. As a result, capture duration can be more precisely managed and the process can be promptly ended as needed.
Scheduled capture
Schedule Capture allows for the following:
- Future packet capture
- Repeated capture session with custom interval and optional end date
Caveats:
PCAP files from Schedule Capture are accessible from the new Scheduled captures tab.
PCAP file from Schedule Capture doesn't have access to Packet analyzer today.
Schedule Capture is available for MR-ENT / DNA Essentials and MR-ADV / DNA Advantage licenses. With the MR-ENT / DNA Essentials, the max limit is 10 files.
Proactive PCAP enablement
In the US region, Proactive PCAP files may be used to train the AI/ML
MR Advanced license is required to use the Proactive PCAP feature. refer to the Licensing Requirements for more information.
Cloud Monitoring for Wireless Access Points do not support the Proactive PCAP feature.
Navigate to the Proactive PCAP Enablement tab and select Enable the auto capture for some devices. You can enable this feature on a per access point basis, by tag, or for all devices, as shown below:
This feature automatically generates packet captures in the event of a client connection failure, Automated packet captures are limited to following reasons below:
- Association failure.
- De-association
- Authentication failure.
- De-authentication.
- DHCP.
- DNS.
- IP address
Users can access Proactive PCAP files at anytime.
When an end device experiences multiple repeated failures of the same type while attempting to connect to an Access Point, only the first failure's proactive packet capture is stored within a 5-minute interval.
Retention time for Proactive PCAP
Packet captures are retained for 7 days. During this period, network administrators can access, analyze, and download the captured packet data to gain insights into network performance and diagnose issues. After the 7-day retention period, the captured data is automatically purged to make room for new captures, ensuring efficient use of storage resources. Packet captures can be accessed from the Stored captures tab as explained in the section below.
Viewing Proactive PCAP
Automatic packet captures taken using the Proactive PCAP feature can be accessed from the Stored Capture tab on the Clients page, as shown below. To access this tab, navigate to Network-wide > Monitor > Clients page and select the client you are troubleshooting from the list.
The file name for a Proactive PCAP is generated using the following components:
- Client MAC Address: Identifies the client device.
- Hash Value: Ensures uniqueness.
- Failure Step: Indicates the process step where the failure occurred.
- Failure Reason: Provides a brief description of the failure.
This systematic approach to file naming enhances the manageability and usability of captured packet data, allowing network administrators to efficiently diagnose and resolve network issues.
For example, imagine a Proactive PCAP is initiated because of an authentication timeout for a client device with the MAC address 00:1A:2B:3C:4D:5E. The hash value generated is "X1Y2Z3", the failure step is "Auth", and the failure reason is "Timeout". The resulting file name may look similar to this:
00:1A:2B:3C:4D:5E_X1Y2Z3_Auth_Timeout
Use Assurance to view Proactive PCAP Taken for clients
Navigate to Assurance > Analytics > Overview and in the clients section select Wireless. A list of wireless client issues appears. Select a type of issue and to view a list of clients affected by this failure type.
Select the client hyperlink under the Name column to open the client details page. This page contains Timeline and Stored Captures tabs. Select the Timeline tab.
The Timeline tab displays a list of all events that have occurred for the selected client. The Timeline tab provides a detailed chronological record of the selected client's connectivity history, including any issues or anomalies that have been detected.
A Packet Capture filter option is available on this page. This filter allows you to refine the displayed events to only those that have associated packet capture files gathered by Proactive PCAP.
Wireless captures properties
Access Points wireless captures have specific characteristics to consider. Traffic from the basic service set identifier (BSSID) of the capturing AP is decrypted, including encrypted BSSIDs. As a result, the Protected Flag is removed to allow decoders to interpret the traffic as clear text. For frames transmitted by the capturing AP, the signal strength and noise level values are set to 0 dBm.
Due to the nature of proactive captures and storage constraints, aimed at capturing association and authentication failures, the captured traffic is filtered to include only the affected client and specific frame types:
Control Frames: None are captured.
Management Frames: All management frames are captured except Beacon frames. Starting with release 32, each capture includes at least one Beacon frame (truncated to 1500 bytes) as a reference for troubleshooting.
Data Frames: Only DHCP, DNS, Address Resolution Protocol (ARP), and Extensible Authentication Protocol over LAN (EAPOL) frames are captured.
Please note that management frames are always captured in Proactive Wireless Captures, regardless of the selected protocol filter.
Switches
MS Enterprise (ENT) license allows storage of up to 10 capture files in the cloud. Each file is limited up to maximum duration of 1,200 seconds or a maximum size of 20MB. When the limit is reached and a new capture is taken, the older capture will be automatically deleted to ensure sufficient space.
Intelligent capture allows you to capture, store, view, and download captures directly in the Meraki dashboard. Start by navigating to the Network-wide > Monitor > Intelligent Capture page:
The sections below cover manual captures and scheduled captures features.
Creating a capture
From the New capture tab, set the following parameters to take a packet capture:
Select the device to perform the capture and enter the port numbers where you want to perform the capture. Ports can be specified as a comma-separated list of ports or port ranges, for example: 1, 4, 5-30.
Select the output for the saved capture. Regardless of which option is selected, the capture will also be saved to cloud for later reference. For more information, refer to the intelligent captures options section
Enter the duration to capture traffic in seconds, up to 300 (5 minutes).
Enter filter expressions, if desired, to reduce the types of traffic that are captured.
Select the View example filters link to review examples of filter expressions.
Use the Copy link to copy any of the sample expressions and paste them into the capture filters field.
Optionally override the automatically generated file name.
Optionally add descriptive notes to attach to the capture.
Once these options are configured as required, select the Start Capture to begin the capture.
Select Start capture to begin the capture. A progress bar appears while traffic is being captured. Select Cancel capture to stop the capture early. Captures that are canceled early are still saved to the cloud.
Once the capture is finished, select View capture or Download capture, create a new capture, or select See all captures to navigate to the Stored captures tab.
To protect critical network services, some frames may not be captured when a switch is under heavy load.
Capturing traffic on multiple interfaces
When troubleshooting problems on the network, isolating hardware that is not handling traffic appropriately is important. Simultaneous packet captures on multiple ports are useful because they allow the user to see a more complete picture of how traffic is flowing.
Dashboard's built-in packet capture tool can be used to observe multiple interfaces of a device and see if traffic is flowing through as expected. Simultaneous packet captures on multiple ports are useful because they allow the user to see a more complete picture of how traffic is flowing.
This section explains how to capture traffic simultaneously on multiple interfaces of a Meraki device, and how to analyze that traffic to detect potential issues.
The MS switch does not support multiple simultaneous captures, but instead allows a single capture to span multiple ports. Please refer to our packet capture documentation for more info.
Capturing Traffic
- Open two web browser tabs or windows.
- In each tab or window:
- In Dashboard, navigate to Network-wide > Packet capture.
- Select the appropriate device type from the top drop-down menu:
- Select the device to take the capture on.
- Select the appropriate Interface for each capture. For MR devices, this will generally be Wired in one window and Wireless in the other. For MX devices, this will generally be LAN in one window and Internet in the other.
- Change the Output to Download .pcap file (for Wireshark):
- Set the duration for the capture. 60 seconds is usually sufficient.
- Fill in each File name field with a descriptive name, like "LAN" or "Internet". This will make it easy to identify which interface the capture was taken on.
- When you are ready to begin capturing traffic, click Start capture on both windows. You may be prompted to specify a download location.
Analyzing Traffic
The following sections describe how simultaneous captures on either an MR access point or MX security appliance can be used to identify problems on the network.
Wired and Wireless Traffic on an MR Access Point
Capturing traffic on both the wired and wireless interfaces of an MR access point can help isolate the source of a network problem. For example, if a client can connect to an MR access point but cannot obtain an address via DHCP, it may be unclear whether the issue is being caused by the AP or the DHCP server.
Comparing the wired and wireless captures can reveal whether the AP is correctly receiving and forwarding the client's DHCP requests. The wireless capture below shows that the client is sending DHCP DISCOVER messages to the AP, but is not receiving a response:
The wired capture below shows that the same DHCP DISCOVER messages are being sent out onto the LAN, but are still not receiving a response:
These captures show that the AP is forwarding traffic correctly, but no response is coming from the DHCP server. Based on these results, it is likely that the issue resides on the LAN or DHCP server.
WAN and LAN Traffic on an MX Security Appliance
Capturing traffic on both the LAN and WAN interfaces of an MX security appliance can help isolate the source of a network problem. For example, if a server on the LAN has a 1:1 NAT rule but is not responding to pings from clients on the internet, it may be unclear whether the issue is being caused by an improperly configured 1:1 NAT rule or an issue with the server.
Comparing the LAN and WAN captures can reveal whether the appliance is functioning properly. In the example below, the MX is configured with a 1:1 NAT rule that accepts inbound traffic on 104.17.32.2, and forwards that traffic to the server at 192.168.128.29. The WAN-side capture below shows that a client at 66.74.83.217 is attempting to ping this server, but is not receiving a response:
The LAN-side capture below shows that the ping requests are being correctly forwarded to the server at 192.168.128.29, but are not receiving a response.
These captures show that the appliance's 1:1 NAT rule is forwarding traffic correctly, but no response is coming from the local server. Based on these results, it is likely that the issue resides on the LAN or local server.
Rolling captures
A "Rolling Capture" is a capture which automatically saves the output to files at set intervals and can break up a large capture into multiple smaller files. This can be extremely useful when trying to run a long-term capture for troubleshooting intermittent troubles, such as choppy audio on Voice over IP (VOIP).
Using Wireshark for Packet Captures explains how to collect rolling captures with Wireshark.
