Table Summarization - Public Beta
Click 日本語 for Japanese
Overview
Table Summarization uses the AI assistant to summarize tables on the Meraki dashboard pages and also directly in the AI assistant. The AI assistant processes the data from these tables and generates concise, human-readable summaries. The change log, login attempts, and network events all have this feature enabled for beta.
How Can I Access the Table Summarization Beta?
Table Summarization will be accessible with the AI assistant. The AI assistant public beta waitlist will be available by accessing the Meraki dashboard via Early Access. Access to the AI Assistant will roll out gradually; users will be notified directly within the dashboard once the feature becomes available in their organization.
How Can Table Summarization Help You?
Table Summarization highlights key patterns, events, or changes within the data, enabling users to quickly identify important information. By simplifying raw table data into clear summaries, this feature enhances the user's ability to understand and act on network activity more efficiently. This helps quickly spot issues or anomalies and fix them. The AI assistant makes it easier to understand and act on log data without needing advanced expertise.
Providing Feedback
Your feedback is essential in improving Table Summarization. If you encounter an incorrect or incomplete response, or if you have ideas for new features, let us know using the thumbs-up or thumbs-down buttons after an interaction.
- If an answer is incorrect, use the thumbs down to provide feedback.
- If the response is helpful, use the thumbs up.
Provide details on why the response was incorrect or unhelpful. Include additional details if possible:
- What you were trying to accomplish.
- What you expected to happen.
- Any issues or unexpected behavior.
FAQ
How accurate are the recommendations from AI Assistant?
The AI Assistant is designed to provide suggestions by:
- Leveraging pre-trained models tuned for networking-specific tasks
- Integrating with real-time system data when applicable
- Drawing from networking industry best practices and product documentation to help generate responses
While the AI Assistant aims to provide grounded information, it is recommended that you validate its suggestions and actions, especially for critical configurations or troubleshooting.
Is my data being used to train the AI Assistant?
No, your data is not used to train the AI Assistant.
