Dashboard Branding for MSPs
Managed Service Providers (MSPs) can now take advantage of custom branding options within the Cisco Meraki Dashboard. This allows MSPs to customize certain aspects of Dashboard for their users and customers. This article will provide an overview of the options available, how they are applied, and an example.
Configuring a Branding Policy
Note: Dashboard branding options are only available to qualified Managed Service Providers. Please contact Cisco Meraki Support to check eligibility.
In order to apply custom branding to Dashboard, a policy (or multiple policies) must be created that override the default settings. These policies can then be applied to different administrators or groups of administrators.
- Navigate to Organization > Branding.
Note: If this option does not exist and this organization is part of a Managed Service Provider, please contact Cisco Meraki Support. - Create a new policy by clicking Add policy.
- Click on the new policy (which should be highlighted in yellow).
- Enter a Name for the policy.
- Select which users this policy Applies to.
All admins - Applied to all admin users in this Organization.
All admins of networks tagged - Applied to all admin users in networks with the selected tag.
All admins of networks - Applied to all admin users in the selected networks.
All network admins - Applied to all network-level admin users in the Organization. Organization admins are not included unless explicitly granted network-level permissions.
All organization admins - Applied to all organization-level admin users in the Organization.
Specific admins - Applied to the admin users selected.
- Select the desired behavior for each option under Help. To see each of these options in action, explore the Help tab along the left side of the page in Dashboard. Where applicable, behavioral options may include:
Default or inherit - Use the default setting, unless the setting was previously overridden by another matched policy, in which case that setting will be used.
Hide - Do not display this page or option.
Replace - Replace this content with new information. Only available for certain options. When selected, an Edit option will appear in which custom text or HTML can be entered.
Show - Display this page or option. Used to override a policy matched earlier that used either Hide or Replace.
- If desired, change the Dashboard logo (which appears in the upper left corner of Dashboard) by clicking Change.
- Keep in mind the following logo best practices
- Color
- Logo and/or logotype should be all white or light colored. Background outside the logo should be transparent.
- Logo size and composition
- Logo will be scaled to 36px in height. Header is 56px in height.
- The image should have appropriate clear space built in around the logo or logotype to make sure logo appears in a reasonable size within header.
- For PNGs, this clear space appears as transparent pixels around the logo. For SVGs, a bounding box or viewBox should be defined with spacing around the vector path of the logo.
- We will not be cropping the logo image, but only scaling the height to be 36px.
- File format
- PNG and SVG are preferred and recommended, as these support transparent background
- Resolution and quality:
- For PNGs and non-vector formats, the logo image should be exported as at least 72px in height to ensure the logo appears crisp.
- Color
- Click Upload file and browse for the image to use.
- Once uploaded, click on the image to highlight and then click Choose.
- When finished with the policy, click Update.
- Then click Save to save any changes to the policies.
To create additional policies for different user groups or behaviors, repeat these steps as needed.
Any logos that are applied to Dashboard should be the logo of the MSP and not of the end customer.
How Branding Policies are Applied
Policies are applied from the top down, with policies lower on the list taking priority. If multiple policies match for a given user, then they will be applied in sequence, with lower policies potentially overriding earlier ones.
If a field is set to "Default or inherit", the policy will not modify that page/content's behavior. If it was the first policy to be matched, then the default behavior will be used. If a higher policy modified the behavior, such as hiding a subtab, then that behavior will be inherited.
Example Policies
In this example, an MSP provides 3 levels of access to administrators of an organization. Customers are always made admins at the network level, with either read-only (RO) or read-write/full (RW) access. MSP admins are granted organization-level permissions. Because of this, 3 branding policies have been created.
- RO Customer Admins - Applied to all network administrators. Hides the entire 'Help' tab and applies a custom Dashboard logo.
Who it matches: All customer admins. Since all customer admins are granted permissions at the network level.
- RW Customer Admins - Applied to only specific administrators. Shows the 'Help' tab, but hides the 'Cases' subtab, and provides custom content for contacting support.
Who it matches: Only certain customer admins that have been explicitly added.
- MSP Admins - Applied to only organization administrators. Assumes defaults and overrides nothing. Created as a placeholder.
Who it matches: All organization-level admins. These would be employees of the MSP.
In the image below, notice the settings for each policy, and what the actual behavior would be for a user in that group (shown in red).
If evaluating the 'Help' tab option, each administrator type would be processed as follows:
- RO network admin
Show/Default/Inherit -
Policy Applied? Policy Action Behavior RO Customer Admins Yes Hide Hide RW Customer Admins No Hide MSP Admins No Hide - RW network admin (assuming they are selected)
Default/Inherit -
Policy Applied? Policy Action Behavior RO Customer Admins Yes Hide Hide RW Customer Admins Yes Show Show MSP Admins No Show - Organization admin
Hide/ShowPolicy Applied? Policy Action Behavior RO Customer Admins No Show (Default) RW Customer Admins No Show (Default) MSP Admins Yes Default/Inherit Show (Default)
Best Practices
Since Dashboard branding is enabled and configured on a per-organization basis, newly created organizations will require branding policies to be re-enabled and re-configured. In order to avoid needless repeating this process, new organizations should be created using the clone org tool. Cloned organizations will retain the branding settings configured on the source organization.
