Cisco Meraki Dashboard API
Overview
Learn more with these free online training courses on the Meraki Learning Hub:
The Meraki dashboard Application Programming Interface (API) is an interface for software to interact directly with the Meraki cloud platform and Meraki-managed devices. The API contains a set of tools known as "endpoints" for building software and applications that communicate with the Meraki dashboard. Use cases include provisioning, bulk configuration changes, monitoring, and role-based access controls. The dashboard API is a modern, RESTful API using HTTPS requests to a URL and JSON as a human-readable format. The dashboard API is an open-ended tool that can be used for many purposes. Here are some examples of how it is used today by Meraki customers:
- Add new organizations, admins, networks, devices, VLANs, Service Set Identifiers (SSIDs)
- Provision thousands of new sites in minutes with an automation script
- Automatically onboard and off-board new employees' teleworker device(s)
- Build your own dashboard for store managers, field techs, or unique use cases
Note: API call volume is rate-limited to ten calls per second, per organization.
API Documentation
For more information on Meraki's APIs, please visit our dedicated API documentation website: Meraki Developer Hub.
The API reference documentation is provided in a Postman collection accessible at our Meraki Developer Hub > Resources > Postman Collections website. The Postman collection can be imported into the Postman application to test API calls.
Generate API Key
After ensuring that the Organization > Settings > API Access option is set to “Enable access to the Cisco Meraki Dashboard API”, proceed to the avatar icon (on the top-right of the green ribbon) > My profile page to generate an API key. This API key will be associated with the dashboard administrator account which generates it, and will inherit the same permissions as that account. You can generate, revoke, and regenerate your API key on your profile.
Note: Keep your API key safe as it provides authentication to all of your organizations with the API enabled. Dashboard does not store API keys in plaintext for security reasons, so this is the only time you will be able to record it. If you lose or forget your API key, you will have to revoke it and generate a new one.
Note: there is a limit of only two API keys per profile. After generating two keys, the "Generate API key" disappears from the dashboard view. You need to revoke one of the generated keys before you can generate a new one.
Note: SAML dashboard administrators cannot view or generate API keys. Please note that this means that Single Sign On (SSO) users will not be able to generate API keys.
API & Webhooks Dashboard page
API keys and Webhooks can also be configured via the dedicated API & Webhooks Dashboard UI page. Navigate to Organization → Configure → API & Webhooks.
Note: This page is currently visible only to organization administrators.
Using the Dashboard API
API Requests
Every request must specify an API key via a request header. Furthermore, the API key must be specified in the URL. The API will return 404 (rather than a 403) in response to a request with a missing or incorrect API key in order to prevent leaking the existence of resources to unauthorized users.
X-Cisco-Meraki-API-Key: <secret key>
The API version must be specified in the URL:
https://api.meraki.com/api/v1/<resource>
Note: For organizations hosted in the China dashboard, use api.meraki.cn
For organizations hosted in the Canada dashboard, use api.meraki.ca
Once an API version is released, we will make only backwards-compatible changes to it. Backwards-compatible changes include:
- Adding new API resources
Adding new optional request parameters to existing API methods
Adding new properties to existing API responses
Changing the order of properties in existing API responses
Identifiers in the API are opaque strings. A <network_id>, for example, might be the string “126043”, whereas an <order_id> might contain characters, such as “4S1234567”. Client applications must not try to parse them as numbers. Even identifiers that look like numbers might be too long to encode without loss of precision in Javascript, where the only numeric type is IEEE 754 floating point.
Verbs in the API follow the usual REST conventions:
- GET returns the value of a resource or a list of resources, depending on whether an identifier is specified.
- GET of /v1/organizations returns a list of organizations
- GET of /v1/organizations/<org_id> returns a particular organization
- POST adds a new resource
- POST to /v1/organizations/<org_id>/admins
- POST performs other non-idempotent changes
- PUT updates a resource
- PUT is idempotent; it updates a resource, creating it first if it does not already exist
- PUT should specify all the fields of a resource; the API will revert omitted fields to their default value
- DELETE removes a resource
Note: Call volume is limited to ten calls per second, per organization.
POST /api/v1/organizations/{organizationId}/inventory/claim
POST /api/v1/organizations/{organizationId}/claim
POST /api/v1/networks/{networkId}/devices/claim
These API endpoints will now be subject to a stricter rate limit of 10 requests over a 5 minute period, per IP address. When this rate limit has been reached, similar to the existing Dashboard API rate limiting, an HTTP 429 error will be returned and the Retry-After response header will be set to the number of seconds required to wait to access the endpoint again.
Status and Error Codes
Responses from the API generally use standard RFC 9110 HTTP Status Codes. Some examples:
- 400: Bad Request - You did something wrong, for example, a malformed request or missing parameter
- 401: Unauthorized - Invalid API Key
- 403: Forbidden - You don't have permission to do that
- 404: Not found - No such URL or you don't have access to the API or organization at all
- 429: Too Many Requests - You submitted more than ten calls in one second to an organization, triggering rate limiting. This also applies for API calls made across multiple organizations that triggers rate limiting for one of the organizations.
If the response code is not specific enough to determine the cause of the issue, error messages will be included in the response in JSON format, for example:
"errors": [
"VLANs are not enabled for this network"
Read only administrators will only be allowed to make GET requests. Any other requests will result in 403: Forbidden
Examples
Below is a list of example requests and responses. Please note that these are not comprehensive; for a comprehensive list of API endpoints and their details, please see the online documentation here: Meraki Developer Hub.
Organizations
Retrieve the list of organizations for the API key specified in X-Cisco-Meraki-API-Key:
GET https://api.meraki.com/api/v1/organizations
Response code: 200
Response body: [{"id":"<org_id>","name":"<org_name>" }]
Retrieve metadata about a specific organization:
GET https://api.meraki.com/api/v1/organizations/<org_id> Response code: 200 Response body: { "id": <org_id>, "name": "Test Organization" }
Most HTTP libraries and clients will only follow a redirect with the HTTP verb GET. If using other HTTP verbs, they may still follow the redirect, but they will substitute the other HTTP verb with GET. As a result, you may find a redirect on DELETE, POST, or PUT will look as though a GET was requested. To avoid this, follow the steps below:
- Perform a GET on the organization you are working with
- Store the URL you are working with
- Use the URL for subsequent requests (particularly those that modify state).
Create a new organization:
POST https://api.meraki.com/api/v1/organizations
Request body: { “name”: “Second Test Organization” }
Response code: 201
Response body: { "id": <new_org_id>, name: "Second Test Organization" }
The new organization will be unconfigured. However, the admin who created it will have full organization write access. Clients of the API can add additional admins and then remove the creating admin from the new organization if desired.
Note: The API will not allow clients to remove the last remaining admin with full organization write access. Doing so could lead to an unconfigurable organization.
Networks
List the networks in an organization:
GET https://api.meraki.com/api/v1/organizations/<new_org_id>/networks
Response code: 200
Response body: [ { "id": <network_id>, "name": "Test Network", "organization_id": <new_org_id>, "type": "wireless",
"timeZone": "America/Los_Angeles", "tags": " test "}]
Create a new network:
POST https://api.meraki.com/api/v1/organizations/<org_id>/networks
Request body: { “name”: “Test Network 2”, “organizationId”: <org_id>, “type”: “appliance”}
Response code: 201
Response body: { “id”: <network_id>, “name”: “Test Network 2”, “organization_id”: <org_id>, “type”: “appliance”, “tags”: null }
Valid network types are appliance, switch, wireless, systemsManager or camera. Use a combination of these to create a combined network. For example, “type”: “appliance wireless”.
Licenses and Devices
Claim a device, license key, or order into an organization. When claiming by order, all devices and licenses in the order will be claimed. Licenses will be added to the organization and devices will be placed in the organization's inventory. These three types of claims are mutually exclusive and cannot be performed in one request. The licenseMode parameter can be either renew or addDevices. addDevices will increase the license limit while renew will extend the amount of time until expiration. This parameter is required when claiming by licenseKey. Please see this article for more information.
POST https://api.meraki.com/api/v1/organizations/<org_id>/ claim
Request body: { "order": "4CXXXXXXX" }
Response code: 200
Response body: <empty>
Simple Network Management Protocol (SNMP) Settings
Set the SNMP settings for an organization. The community string for SNMPv2 is in the response. It can also be retrieved via a GET to this same URL.
GET https://api.meraki.com/api/v1/organizations/<org_id>/snmp
Request body: { "v2cEnabled": true, "v3Enabled": true, "v3AuthMode": "SHA", "v3AuthPass", <secret>, "v3PrivMode": "AES128", "v3PrivPass": <secret>, "allowedIPs": ["5.6.7.8"] }
Response code: 200
Response body: { "v2Enabled": true, “v2CommunityString”: <secret>, "v3Enabled": true, "authMode": "SHA", "authPass", <secret>, "privMode": "AES128", "privPass": <secret>, "allowedIPs": ["5.6.7.8"] }
Administrators
List the administrators for an organization:
GET https://api.meraki.com/api/v1/organizations/<org_id>/admins
Response code: 200
Response body: [ { "name": "Jane Doe", "email": "jane@doe.com", "orgAccess": "full","id": <admin_id> } ]
Organization access can be full, read-only, or none.
Add a new administrator with rights to only one network:
POST https://api.meraki.com/api/v1/organizations/<org_id>/admins/
Request body: { "name": "John Doe", "email": "john@doe.com", "orgAccess": "none", "networks": [{ "id": <network_id>, "access": "full" }
Response code: 201
Response body: { “id”: <admin_id>, "name": "John Doe", "email": "john@doe.com", "orgAccess": "none", "networks": [{ "id": <network_id>, "access": "full" }]
Valid access levels for networks are full, read-only, monitor-only, and guest-ambassador. Clients can also give administrators access by tag by substituting the networks field for tags such as:
"tags": [{ "tag": "foo", "access": "read-only" }],
Valid access levels for tags are the same as for networks. Clients can update administrators using PUT and specifying an admin_id.
Delete an administrator:
DELETE https://api.meraki.com/api/v1/organizations/<org_id>/admins/<admin_id>
Response code: 204
