Overview and FAQ: TLS 1.0 and 1.1 Deprecation
Overview and FAQ
1. What is changing?
Cisco Meraki is implementing Transport Layer Security (TLS) 1.3 and deprecating TLS 1.0 and 1.1. Beginning in February 2026, Meraki will only support TLS 1.2 and 1.3 tunneling protocols to the Meraki cloud.
2. Why is this change happening?
The TLS protocol is one of the primary means of protecting network communications over the internet. In August of 2018, RFC 8446 was published, providing the specifications for TLS 1.3 and some new requirements for TLS 1.2 implementations. Meraki has added TLS 1.3 to our supported protocol versions to keep our security posture aligned with the newest standards.
More information about the compliance standards requiring the addition of TLS 1.3 and the deprecation of TLS 1.0 and 1.1 can be found in our documentation
3. When is this change happening?
The development work required to deprecate TLS 1.0 and 1.1 support is beginning in February 2026.
This will be rolled out across the Meraki cloud architecture in phases, so you may be impacted any time after this point. All Meraki devices that don’t support TLS 1.2 or 1.3 should be expected to no longer be able to communicate with the Meraki dashboard starting in February 2026
4. Which product lines are impacted?
MR Wireless, MS Switching, MX Security & SD-WAN, and Z Teleworker product lines are impacted. Please see question 8 below for a detailed list of impacted devices.
5. What is the impact?
You will need to update your devices’ firmware to a version that supports TLS 1.2 and/or TLS 1.3. Please see question 8 below for a detailed list of impacted devices.
Note: Some older devices may not be able to update to a firmware version that supports TLS 1.2 and 1.3. These devices are End-of-Life (EoL), meaning they are no longer eligible for service or support from Meraki. If you have one of these EoL devices and need to maintain network connectivity, they will have to be replaced with a newer device. Customers with these devices will be contacted directly with instructions on the next steps.
6.  What action do I need to take?
If you are on a version of firmware lower than what you see listed below, you will need to update your firmware to maintain Meraki dashboard connectivity:
  • MR 25.1 for MR access points
  • MX 14 for MX Security & SD-WAN and Z Teleworker appliances
  • MS 8 for MS switches
Legacy devices that have reached their Last Day of Support are no longer eligible for service or support from Meraki. Additionally, these devices cannot receive firmware upgrades to versions that support TLS 1.2 or newer. Therefore, such devices must be replaced with newer models to maintain security and supportability.
Please review this document for more Information and contact Meraki Technical Support if you have any questions. if you have any questions.
7. What happens if I do not take the requested action?
Your devices may continue to operate using the last known configuration retrieved from the Meraki dashboard; however, no additional configuration changes can be pulled by the device. If a device reboots (internal issue, power issue, etc.), it will not be able to reestablish a connection to the Meraki dashboard. It is highly recommended appropriate action be taken for your impacted devices prior to February 2026. Beyond this date, you may experience a service disruption.
8. How do I determine which of my devices are affected?
Device models in blue have firmware that cannot be updated and therefore require a new device to be deployed. Device models in green require a firmware update.
Model
End of Support Date
Maximum Runnable Firmware
Firmware upgrade mitigation available?
Meraki Solar
Dec 31, 2015
MR 20.X
No
Meraki Wall Plug
Dec 31, 2015
MR 20.X
No
Meraki Indoor
Jun 30, 2016
MR 20.X
No
Meraki Mini
Sep 25, 2017
MR 20.X
No
MR11
Aug 30, 2017
MR 20.X
No
MR14
Aug 30, 2017
MR 24.X
No
Meraki Outdoor
Oct 30, 2017
MR 20.X
No
MR58
Oct 30, 2017
MR 24.X
No
MR16
May 31, 2021
MR 26.X
Yes
MR24
May 31, 2021
MR 26.X
Yes
MR12
Oct 24, 2022
MR 26.X
Yes
MR26
May 9, 2023
MR 26.X
Yes
MR34
Oct 31, 2023
MR 26.X
Yes
MR42
Jul 21, 2026
MR 30.X
Yes
MR18
Mar 31, 2024
MR 26.X
Yes
MR66
Jun 9, 2024
MR 26.X
Yes
MR32
Jul 31, 2024
MR 26.X
Yes
MR62
Nov 15, 2024
MR 26.X
Yes
MR72
Apr 30, 2024
MR 26.X
Yes
MR52
Jul 21, 2026
MR 30.X
Yes
MR53
Jul 21, 2026
MR 30.X
Yes
MR84
Jul 21, 2026
MR 30.X
Yes
Z1-HW
Jul 27, 2025
MX 14.X
Yes
MS220-24-HW
Jul 29, 2024
Current version
Yes
MS220-48FP-HW
Jul 29, 2024
Current version
Yes
MS220-48LP-HW
Jul 29, 2024
Current version
Yes
MS220-8P-HW
Sep 21, 2025
Current version
Yes
MS320-24P-HW
Mar 31, 2024
Current version
Yes
MS320-48-HW
Mar 31, 2024
Current version
Yes
MS420-24-HW
Oct 31, 2023
Current version
Yes
MX64-HW*
Jul 26, 2027
MX 18.1
You will be contacted directly
MX64W-HW*
Jul 26, 2027
MX 18.1
*If you have one of these devices and you have not been contacted directly, your device is not affected.
9. Can I still upgrade my firmware after the deprecation date?
Devices listed above where "Firmware upgrade mitigation available?" is true can still be upgraded after the deprecation date. These devices must be unclaimed and removed from any dashboard organization in order for the upgrade to be possible. You can track the device's upgrade process on the local status page.
10. Who do I contact if I have additional questions not covered in this FAQ?
Please contact Meraki Technical Support with any additional questions or concerns, or reach out to your account manager for assistance in purchasing new devices.
  • Was this article helpful?
