Product Firmware Version Restrictions
日本語版はこちら
Overview
Each Cisco Meraki product has a minimum firmware version it can run. This version may differ from the firmware set in the dashboard network. The device will run the minimum firmware it supports, which can be higher than the network's configured firmware. This article lists each supported product and its minimum firmware version.
Cisco Meraki is committed to delivering customers industry-leading capabilities through seamless firmware updates. For some legacy, end-of-sale devices, the current Recommended Release firmware version may not be compatible. In such instances, firmware for end-of-sale devices is limited to the maximum runnable firmware version supported by the legacy hardware. Customers should refer to the Cisco Meraki Support Policies for information regarding product lifecycle milestones, support eligibility, and software maintenance considerations for end-of-sale products.
To review the firmware version and release notes in the Meraki dashboard, navigate to Organization > Monitor > Firmware Upgrades. Check the Legacy products notice section of the release notes to compare your current firmware version against the older firmware these nodes will run. For example, an MX84 appliance configured to run MX 18.211.6 will instead run MX 18.107.13. Use the Firmware Upgrades page as your primary reference rather than individual device messages to ensure you have the most recent build.
This image is displayed to show that devices at end-of-sale have maximum firmware versions they can run, which may be lower than the network-configured firmware, as illustrated by the MX84 example.
Learn more with these free online training courses on the Networking Learning Hub:
MG
Product Minimum Runnable Firmware Maximum Runnable Firmware
MG21 MG 1.9 4.x
MG41 MG 2.0 Current
MG51 MG 3.0 Current
MG52 MG 3.200 Current
MR/CW
MR12
MR16
MR24
MR62
MR66
MR 20 MR 26
MR18
MR26
MR34
MR 22 MR 26
MR32
MR72
MR 23 MR 26
MR42
MR52
MR53
MR84
MR 24 MR 30
MR30H
MR33
MR74
MR 25.1 MR 30
MR42E
MR53E
MR20
MR70
MR 26 MR 30
MR45
MR55
MR 26.3 MR 31
MR36
MR46
MR56
MR46E
MR76
MR86
MR 26.7 Current
MR44 MR 27.5 Current
MR36H MR 28.5 Current
MR57 MR 28.6.1 Current
CW9166I and CW9164
MR28
MR78
MR 28.7.1 Current
CW9162 MR 29.5 Current
CW9166D1 MR 30.5 Current
CW9163E MR 30.5 Current
CW9171 MR 32.1.5 Current
CW9172I MR 31 Current
CW9174 MR 32.1.5 Current
CW9176I MR 31 Current
CW9176D1 MR 31 Current
CW9178I MR 31 Current
CW9179F MR 31.1.8 Current
Ensure that MR44 is connected to an 802.3at-capable (PoE+) switch/power injector during the initial installation OR ensure that the network the MR44 is added to is set to MR 27.6 or newer firmware.
This is because the default MR44 firmware image has support for the low-power mode, however, MR 27.5/27.5.1 or lower firmware does not have low power mode support. Using 802.3af switch/power injector with MR44 set to 27.5/27.5.1 or lower firmware might result in unexpected behaviors including but not limited to reboots or degraded performance.
Due to the reasons stated above, please do not downgrade the network with MR44 APs to 27.5/27.5.1 or lower firmware if they are being powered on by 802.3af (PoE) switch/power injector.
MS
MS420
MS 5 MS 15.23
MS220 MS 5
MS 16.9
MS 17 is not available for these devices and in networks configured for MS 17 or above they will display the firmware status as: Not running configured version
MS22
MS42
MS320
MS 5 MS 17.2.2
MS 17.2.1 is not available for these devices and in networks configured for MS 17.2.1, they will display the firmware status as: Not running configured version
MS350 MS 5 Current
MS210
MS225
MS250
MS 9
Current
MS120
MS 9.36
Current
MS125
MS 11.22
Current
MS130
MS 15.23*
Current
MS150 MS 17.1.4 Current
MS410
MS425
MS 8 Current
MS355 MS 11 Current
MS450 MS 11 Current
MS390 MS 11.29.1
Current
C9300-M/L CS 16.3 Current
* MS130 devices on firmware MS 17.2.1 or higher cannot downgrade to firmare releases before MS 17.2.1.
Cisco Catalyst
24 port models ( C9300-24P,  C9300-24T, C9300-24U, C9300-24UX ) CS 15.21.11 Current
48 port models ( C9300-48P, C9300-48T, C9300-48UXM ) CS 15.21.11 Current
48 port model (C9300-48UN) CS 16.3 Current
Fiber models ( C9300-24S, C930048S, C9300X-24Y, C9300-24Y, C9300X-12Y ) CS 16.3 Current
C9350 models IOS-XE 17.18.1 Current
IE3500 (Rugged Series Switch) IOS XE 26.1.1 Current
MV
Gen 1 (MV21, MV71)
MV 1.0
MV 4.15
Gen 2 (MV2, MV12, MV22, MV32, MV52, MV72)
MV 3.2* MV 7.2.x
Gen 3 (MV13, MV23, MV53X, MV63, MV73, MV93) MV 5.0 Current
Gen 4 (MV84X) MV 6.3 Current
* One-way firmware upgrades prevent downgrading to any version below 5.0, once an upgrade to version 5.x+ has been performed. Similarly, one-way firmware upgrades prevent downgrading to any version below 4.0, once an upgrade to version 4.x+ has been performed.
Cisco Secure Router
C8110L-G2-MX MX 26.2 Current
C8111-G2-MX
C8111-C-G2-MX
C8121-G2-MX
C8121-W-G2-MX
C8121-CW-G2-MX
MX 19.2
Current
C8355-G2-MX MX 26.1 Current
C8455-G2-MX MX 19.2 Current
MX
MX60/W
MX80
MX90
Z1
MX 10
MX 14*
MX400
MX600
MX 10 MX 16
MX100 MX 10 MX 18.1***
MX64/W
MX65/W
MX84
MX 12.1.2 MX 18.1***
MX250
MX450
MX 14.19
Current
Z3
MX 14.16**
MX 19.2
MX67/W/C
MX68/W/CW
MX 14.32, MX 15.11 Current
Z3C MX 14.33, MX 15.11 MX 19.2
MX75
MX85
MX 16.8 Current
MX95
MX105
MX 16.9 Current
Z4 MX 18.107.2 Current
Z4C MX 18.206 Current
VMX-100 MX 15.37 MX 18.1
VMX-S/M/L MX 15.37 Current
UMB-SIG MX 15.37 MX 18.2
* Z1s, MX60/Ws, MX80s and MX90s cannot upgrade to MX 15 firmware, or any newer major release versions. If networks containing these devices are configured to run newer firmware revisions, they will run the newest MX 14 maintenance release instead.
** The Z3 once updated to MX 14.31 or 15.8 and beyond will not be able to run any older firmware than MX 14.31 or 15.8
*** The MX64/W, MX65/W, MX84, MX100 and vMX100 devices cannot be upgraded to MX 18.2 firmware or any newer major release versions. If networks with these devices are set to run newer firmware versions, they will automatically use an MX 18.1 firmware version instead. The specific MX 18.1 firmware version that will be used is detailed in the release notes of each firmware version. For instance, if a network with an MX100 device is upgraded to MX 18.211.2, it will run MX 18.107.13.
