FIPS 140 Devices and Firmware for Cisco Meraki
Overview
The Federal Information Processing Standard (FIPS) 140 is a US government standard that establishes minimum security requirements for cryptographic modules in information technology products. If your devices and firmware are on the list, you are connecting to Meraki's cloud with FIPS 140 validated cryptography. Read more about Meraki's Device to Cloud communications for FIPS.
If you do not find your device on this list, is not FIPS 140 Compliant.
Your devices may run on firmware that is considered FIPS 140 Compliant or FIPS 140 Interim Compliant and may either meet FIPS 140-2 or FIPS 140-3 criteria. The designation of each firmware version is shown in the table below and the specifics of each can be found in their compliance letters. Please note that in our Meraki Cloud for Government, a FedRAMP compliant cloud service, only FIPS 140 Compliant versions of firmware are available.
Note: The FIPS 104-2 program with NIST is Sunsetting in September of 2026. Many version of firmware use Cisco's FIPS 140-2 modules which have moved to the CMVP NIST Historial list on January 5th 2026. We recommend that you update your networks to FIPS 140-3 compliant versions of firmware as soon as possible. For more information, please see the notice here.
Each major firmware release has a minimum minor version which is considered FIPS 140 compliant. Any higher minor version is considered also compliant in that major release train. The major release may be represented by 1 or 2 numbers separated by a dot. The minor release is always the last number in this list.
Meraki FIPS 140 Compliant Security & SD-WAN Devices
| SKU | Firmware - FIPS 140-2 Historical Compliance | Firmware - FIPS 140-3 Compliance |
| MX67-HW | MX17.10.2+, MX18.1.5+, and MX18.205+ | MX19.1.1+, MX19.2.1+ |
| MX67C-HW-NA | MX17.10.2+, MX18.1.5+, and MX18.205+ | MX19.1.1+, MX19.2.1+ |
| MX67W-HW | MX17.10.2+, MX18.1.5+, and MX18.205+ | MX19.1.1+, MX19.2.1+ |
| MX68-HW | MX17.10.2+, MX18.1.5+, and MX18.205+ | MX19.1.1+, MX19.2.1+ |
| MX68CW-HW-NA | MX17.10.2+, MX18.1.5+, and MX18.205+ | MX19.1.1+, MX19.2.1+ |
| MX68W-HW | MX17.10.2+, MX18.1.5+, and MX18.205+ | MX19.1.1+, MX19.2.1+ |
| MX75-HW | MX17.10.2+, MX18.1.5+, and MX18.205+ | MX19.1.1+, MX19.2.1+ |
| MX85-HW | MX17.10.2+, MX18.1.5+, and MX18.205+ | MX19.1.1+, MX19.2.1+ |
| MX95-HW | MX17.10.2+, MX18.1.5+, and MX18.205+ | MX19.1.1+, MX19.2.1+ |
| MX105-HW | MX17.10.2+, MX18.1.5+, and MX18.205+ | MX19.1.1+, MX19.2.1+ |
| MX250-HW | MX17.10.2+, MX18.1.5+, and MX18.205+ | MX19.1.1+, MX19.2.1+ |
| MX450-HW | MX17.10.2+, MX18.1.5+, and MX18.205+ |
VMX-S |
N/A | MX19.1.1+, MX19.2.1+ |
| VMX-M | N/A | MX19.1.1+, MX19.2.1+ |
| VMX-L | N/A | MX19.1.1+, MX19.2.1+ |
Any Meraki MX/Z Series devices not included in the list above is not FIPS compliant.
Meraki FIPS 140 Compliant Gateway Devices
| MG41 | MG3.1 and MG3.2+ | MG4.1+ |
| MG41E | MG3.1 and MG3.2+ | MG4.1+ |
| MG51 | MG3.1 and MG3.2+ | MG4.1+ |
| MG51E | MG3.1 and MG3.2+ | MG4.1+ |
| MG52 | MG3.2+ | MG4.1+ |
| MG52E | MG3.2+ | MG4.1+ |
Meraki FIPS 140 Compliant Wireless Devices
| MR36-HW | MR29.5+ | MR30.6+ and MR31.1+ |
| MR36H-HW | MR29.5+ | MR30.6+ and MR31.1+ |
| MR44-HW | MR29.5+ | MR30.6+ and MR31.1+ |
| MR46-HW | MR29.5+ | MR30.6+ and MR31.1+ |
| MR46E-HW | MR29.5+ | MR30.6+ and MR31.1+ |
| MR56-HW | MR29.5+ | MR30.6+ and MR31.1+ |
| MR57-HW | MR29.5+ | MR30.6+ and MR31.1+ |
| MR76-HW | MR29.5+ | MR30.6+ and MR31.1+ |
| MR86-HW | MR29.5+ | MR30.6+ and MR31.1+ |
| CW9166I | MR29.5+ | MR30.6+ and MR31.1+ |
| CW9164I | MR29.5+ | MR30.6+ and MR31.1+ |
| CW9162I | MR29.5+ | MR30.6+ and MR31.1+ |
| CW9166D1 | N/A | MR30.6+ and MR31.1+ |
| CW9163E | N/A | MR30.6+ and MR31.1+ |
| CW9178I | N/A | MR31.1+ |
| CW9176I | N/A | MR31.1+ |
| CW9176D1 | N/A | MR31.1+ |
| CW9172I | N/A |
MR31.1.6+ |
| CW9172H | N/A | MR31.1.6+ |
Meraki FIPS 140 Compliant Switching Devices
| MS120-24-HW | MS16.1+ | MS17.1+, MS18.1+ |
| MS120-24P-HW | MS16.1+ | MS17.1+, MS18.1+ |
| MS120-48-HW | MS16.1+ | MS17.1+, MS18.1+ |
| MS120-48FP-HW | MS16.1+ | MS17.1+, MS18.1+ |
| MS120-48LP-HW | MS16.1+ | MS17.1+, MS18.1+ |
| MS120-8-HW | MS16.1+ | MS17.1+, MS18.1+ |
| MS120-8FP-HW | MS16.1+ | MS17.1+, MS18.1+ |
| MS120-8LP-HW | MS16.1+ | MS17.1+, MS18.1+ |
| MS125-24-HW | MS16.1+ | MS17.1+, MS18.1+ |
| MS125-24P-HW | MS16.1+ | MS17.1+, MS18.1+ |
| MS125-48FP-HW | MS16.1+ | MS17.1+, MS18.1+ |
| MS125-48-HW | MS16.1+ | MS17.1+, MS18.1+ |
| MS125-48LP-HW | MS16.1+ | MS17.1+, MS18.1+ |
| MS130-12X-HW | MS16.1+ | MS17.1+, MS18.1+ |
| MS130-24-HW | MS16.1+ | MS17.1+, MS18.1+ |
| MS130-24P-HW | MS16.1+ | MS17.1+, MS18.1+ |
| MS130-24X-HW | MS16.1+ | MS17.1+, MS18.1+ |
| MS130-48-HW | MS16.1+ | MS17.1+, MS18.1+ |
| MS130-48P-HW | MS16.1+ | MS17.1+, MS18.1+ |
| MS130-48X-HW | MS16.1+ | MS17.1+, MS18.1+ |
| MS130-8-HW | MS16.1+ | MS17.1+, MS18.1+ |
| MS130-8P-HW | MS16.1+ | MS17.1+, MS18.1+ |
| MS130-8P-I-HW | MS16.1+ | MS17.1+, MS18.1+ |
| MS130-8X-HW | MS16.1+ | MS17.1+, MS18.1+ |
| MS130R-8P-HW | MS16.1+ | MS17.1+, MS18.1+ |
| MS150-24T-4G | N/A | MS17.1+, MS18.1+ |
| MS150-24P-4G | N/A | MS17.1+, MS18.1+ |
| MS150-48T-4G | N/A | MS17.1+, MS18.1+ |
| MS150-48LP-4G | N/A | MS17.1+, MS18.1+ |
| MS150-48FP-4G | N/A | MS17.1+, MS18.1+ |
| MS150-24T-4X | N/A | MS17.1+, MS18.1+ |
| MS150-24P-4X | N/A | MS17.1+, MS18.1+ |
| MS150-48T-4X | N/A | MS17.1+, MS18.1+ |
| MS150-48LP-4X | N/A | MS17.1+, MS18.1+ |
| MS150-48FP-4X | N/A | MS17.1+, MS18.1+ |
| MS150-24MP-4X | N/A | MS17.1+, MS18.1+ |
| MS150-48MP-4X | N/A | MS17.1+, MS18.1+ |
| MS355-24X2-HW | MS16.1+ | MS17.1+, MS18.1+ |
| MS355-24X-HW | MS16.1+ | MS17.1+, MS18.1+ |
| MS355-48X2-HW | MS16.1+ | MS17.1+, MS18.1+ |
| MS355-48X-HW | MS16.1+ | MS17.1+, MS18.1+ |
| MS390-24-HW | CS16.1+ , IOS-XE 17.15.1+ | CS17.1+, IOS-XE 17.18.1+ |
| MS390-24-HW= | CS16.1+ , IOS-XE 17.15.1+ | CS17.1+, IOS-XE 17.18.1+ |
| MS390-24P-HW | CS16.1+ , IOS-XE 17.15.1+ | CS17.1+, IOS-XE 17.18.1+ |
| MS390-24P-HW= | CS16.1+ , IOS-XE 17.15.1+ | CS17.1+, IOS-XE 17.18.1+ |
| MS390-24U-HW | CS16.1+ , IOS-XE 17.15.1+ | CS17.1+, IOS-XE 17.18.1+ |
| MS390-24U-HW= | CS16.1+ , IOS-XE 17.15.1+ | CS17.1+, IOS-XE 17.18.1+ |
| MS390-24UX-HW | CS16.1+ , IOS-XE 17.15.1+ | CS17.1+, IOS-XE 17.18.1+ |
| MS390-24UX-HW= | CS16.1+ , IOS-XE 17.15.1+ | CS17.1+, IOS-XE 17.18.1+ |
| MS390-48-HW | CS16.1+ , IOS-XE 17.15.1+ | CS17.1+, IOS-XE 17.18.1+ |
| MS390-48-HW= | CS16.1+ , IOS-XE 17.15.1+ | CS17.1+, IOS-XE 17.18.1+ |
| MS390-48P-HW | CS16.1+ , IOS-XE 17.15.1+ | CS17.1+, IOS-XE 17.18.1+ |
| MS390-48P-HW= | CS16.1+ , IOS-XE 17.15.1+ | CS17.1+, IOS-XE 17.18.1+ |
| MS390-48U-HW | CS16.1+ , IOS-XE 17.15.1+ | CS17.1+, IOS-XE 17.18.1+ |
MS390-48U-HW= |
MS390-48UX-HW |
| MS390-48UX-HW= | CS16.1+ , IOS-XE 17.15.1+ | CS17.1+, IOS-XE 17.18.1+ |
| MS390-48UX2-HW | CS16.1+ , IOS-XE 17.15.1+ | CS17.1+, IOS-XE 17.18.1+ |
| MS390-48UX2-HW= | CS16.1+ , IOS-XE 17.15.1+ | CS17.1+, IOS-XE 17.18.1+ |
| MS450-12-HW | MS16.1+ | MS17.1+, MS18.1+ |
C9200L-24T-4X |
IOS-XE 17.15.2+ | IOS-XE 17.18.1+ |
C9200L-24P-4X |
C9200L-48T-4X |
C9200L-48P-4X |
C9200L-48PL-4X |
C9200L-24PXG-4X |
C9200L-48PXG-4X |
C9200L-24PXG-2Y |
C9200L-48PXG-2Y |
C9200L-24T-4G |
C9200L-24P-4G |
C9200L-48T-4G |
C9200L-48 PL-4G |
C9200-24T |
N/A | IOS-XE 17.18.1+ |
C9200-24P |
C9200-24PB |
C9200-24PXG |
C9200-48T |
C9200-48P |
C9200-48PL |
C9200-48PB |
C9200-48PXG |
C9200CX-12T-2X2G |
C9200CX-12P-2X2G |
C9200CX-8P-2X2G |
C9200CX-8UXG-2X |
C9200CX-12P-2XGH |
C9200CX-8P-2XGH |
C9200CX-8P-2XGH |
C9200CX-8UXG-2XH |
| C9300-24T | CS16.1+ , IOS-XE 17.15.1+ | CS17.1+, IOS-XE 17.18.1+ |
| C9300-24P | CS16.1+ , IOS-XE 17.15.1+ | CS17.1+, IOS-XE 17.18.1+ |
| C9300-24U | CS16.1+ , IOS-XE 17.15.1+ | CS17.1+, IOS-XE 17.18.1+ |
| C9300-48T | CS16.1+ , IOS-XE 17.15.1+ | CS17.1+, IOS-XE 17.18.1+ |
| C9300-48P | CS16.1+ , IOS-XE 17.15.1+ | CS17.1+, IOS-XE 17.18.1+ |
| C9300-48U | CS16.1+ , IOS-XE 17.15.1+ | CS17.1+, IOS-XE 17.18.1+ |
| C9300-24UX | CS16.1+ , IOS-XE 17.15.1+ | CS17.1+, IOS-XE 17.18.1+ |
| C9300-48UXM | CS16.1+ , IOS-XE 17.15.1+ | CS17.1+, IOS-XE 17.18.1+ |
| C9300-48UN | CS16.1+ , IOS-XE 17.15.1+ | CS17.1+, IOS-XE 17.18.1+ |
| C9300-24S | CS16.1+ , IOS-XE 17.15.1+ | CS17.1+, IOS-XE 17.18.1+ |
| C9300-48S | CS16.1+ , IOS-XE 17.15.1+ | CS17.1+, IOS-XE 17.18.1+ |
C9300-24UB |
C9300-24UXB |
C9300-48UB |
C9300-24H |
C9300-48H |
| C9300L-24T-4X | CS16.1+ , IOS-XE 17.15.1+ | CS17.1+, IOS-XE 17.18.1+ |
| C9300L-24P-4X | CS16.1+ , IOS-XE 17.15.1+ | CS17.1+, IOS-XE 17.18.1+ |
| C9300L-48T-4X | CS16.1+ , IOS-XE 17.15.1+ | CS17.1+, IOS-XE 17.18.1+ |
| C9300L-48P-4X | CS16.1+ , IOS-XE 17.15.1+ | CS17.1+, IOS-XE 17.18.1+ |
| C9300L-48PF-4X | CS16.1+ , IOS-XE 17.15.1+ | CS17.1+, IOS-XE 17.18.1+ |
| C9300L-24UXG-4X | CS16.1+ , IOS-XE 17.15.1+ | CS17.1+, IOS-XE 17.18.1+ |
| C9300L-48UXG-4X | CS16.1+ , IOS-XE 17.15.1+ | CS17.1+, IOS-XE 17.18.1+ |
C9300L-24T-4G |
C9300L-48T-4G |
C9300L-24P-4G |
C9300L-48P-4G |
C9300L-48PF-4G |
C9300L-24UXG-2Q |
C9300L-48UXG-2Q |
C9300LM-48UX-4Y |
C9300LM-48U-4Y |
C9300LM-24U-4Y |
C9300LM-48T-4Y |
| C9300X-24HX | CS16.1+ , IOS-XE 17.15.1+ | CS17.1+, IOS-XE 17.18.1+ |
| C9300X-48HX | CS16.1+ , IOS-XE 17.15.1+ | CS17.1+, IOS-XE 17.18.1+ |
| C9300X-48HXN | CS16.1+ , IOS-XE 17.15.1+ | CS17.1+, IOS-XE 17.18.1+ |
| C9300X-48TX | CS16.1+ , IOS-XE 17.15.1+ | CS17.1+, IOS-XE 17.18.1+ |
| C9300X-12Y | CS16.1+ , IOS-XE 17.15.1+ | CS17.1+, IOS-XE 17.18.1+ |
| C9300X-24Y | CS16.1+ , IOS-XE 17.15.1+ | CS17.1+, IOS-XE 17.18.1+ |
C9350-48HX |
N/A |
IOS-XE 17.18.1+ |
C9350-48TX |
C9350-48U |
C9350-48P |
C9350-48T |
C9350-24U |
C9350-24P |
C9350-24T |
C9350-NM-8Y |
C9350-NM-2C |
C9350-NM-4C |
C9350-48HX-RTG |
C9350-24U-RTG |
C9500-48Y4C |
C9500-24Y4C |
C9500-32C |
C9500-32QC |
