How to Attach Files to Dashboard Cases
Overview
When you contact Cisco Meraki support, attach a screenshot or packet capture to illustrate the issue. Screenshots and packet captures give Support the context needed to resolve the case.
Step-by-step instructions
To access an existing case, navigate to ? > Get help & cases > Recent cases.
To create a case, navigate to ? > Get help & cases > Pick a Tile to Contact Support > Submit a case.
To upload a file to the case
- Select the case.
- Under Files, select Upload file.
- In the window that appears, select the file to attach, then select Open.
If you upload a packet capture, limit the capture to relevant information using Display Filters and only save those displayed packets. - The uploaded file appears above the Upload file button.
To add a comment describing the uploaded file
- Select the case.
- Under Comments, select Add comment.
- Describe the uploaded file, including what it illustrates and any relevant details.
- Select Submit.
- The comment appears with the other comments and emails for the case.
