Meraki Go - Decoding the LED Light
Each Meraki Go WiFi access point is equipped with a multi color light that can be seen on the top right of each device to provide an easy at-a-glance status.
If you don’t see any light being emitted, please ensure that your Meraki Go access point is properly powered with either the included AC adapter, or from a "power over ethernet" (PoE) supported ethernet port.
Access Point Color States
These can also be found from within the Meraki Go App.
Orange |
Booting |
Blinking Orange |
Cannot find uplink Your access point is unable to find a way to the internet. This can occur when there are issues with your connection to your ISP, or if your network is misconfigured |
Rainbow |
Connecting Your access point is initializing and trying to connect to the internet |
Blinking blue |
Updating Your access point is updating to the latest firmware. Firmware updates include new features, and keep your network secure |
Green |
Online Your access point is online and ready for device to connect. It’s good to Go! |
Switch Color States
Rainbow |
Connecting Your switch is initializing and trying to connect to the internet |
Orange |
Cannot find uplink Your switch is unable to find a way to the internet. This can occur when there are issues with your connection to your ISP, or if your network is misconfigured |
Blinking white |
Updating Your switch is updating to the latest firmware. Firmware updates include new features, and keep your network secure |
White |
Online Your switch is online and ready for device to connect. It’s good to Go! |
Security Gateway Color States
Orange |
Booting |
Rainbow |
Connecting Your security gateway is initializing and trying to connect to the internet |
Blinking white |
Updating Your security gateway is updating to the latest firmware. Firmware updates include new features, and keep your network secure |
White |
Online Your security gateway is online and ready for device to connect. It’s good to Go! |
LED Locations
Indoor WiFi Access Point |
Outdoor WiFi Access Point |
Highest rated
(rating)Recently updated
(date updated)Recently added
(date created)
