Meraki Go Switch SFP Overview
Supported Meraki Go SFP modules.
Supported SFP Modules
Fiber Transceivers
The following fiber transceivers are officially supported on the GS110 series switches. Other transceivers may work if the standards are met as per the below table, but will not be supported.
| Meraki Product ID | Standard | Wavelength (nm) | Fiber Type | Fiber Description | Core / Clad Diameter | Jacket Color | Max Distance | Data Rate | Compatibility |
| MA-SFP-1GB-SX | 1000BASE-SX | 850 | MMF | OM1 | 62.5 μm / 125 μm | Orange | 220m | Gigabit | GS110 Series Switches |
| MA-SFP-1GB-SX | 1000BASE-SX | 850 | MMF | OM2 | 50 μm / 125 μm | Orange | 550m | Gigabit | |
| MA-SFP-1GB-SX | 1000BASE-SX | 850 | MMF | OM3 | 50 μm / 125 μm | Aqua | 550m | Gigabit | |
| MA-SFP-1GB-SX | 1000BASE-SX | 850 | MMF | OM4 | 50 μm / 125 μm | Aqua | 1km | Gigabit | |
| MA-SFP-1GB-LX10 | 1000BASE-LX10 | 1310 | SMF | OS1/OS2 | 9 μm / 125 μm | Yellow | 10km | Gigabit | |
| MA-SFP-1GB-LX10 | 1000BASE-LX10 | 1310 | MMF | with LC modeconditioning cable |
N/A | Yellow / Orange | 550m | Gigabit |
What is an SFP port?
The acronym "SFP" stands for small form-factor pluggable, and is the type of connection made by fiber transceivers to network switches.
When to use SFP ports?
SFP ports allow fiber connections to be made to switches, which can exceed the standard 100 meter distance limit imposed by Ethernet cables. A fiber connection can be made very long, depending on the type of module purchased.
An SFP port can also be used to convert from a fiber connection to a standard Ethernet connection.
