Meraki Go GS110 Network Switch Datasheet
Meraki Go Network Switches
GS110-8/24/48
Overview
With Meraki Go network switches, you can have port availability to securely connect the other technologies you rely on and as your business grows to include more technology, Meraki Go easily scales with your business. Important advantages of the Meraki Go network switches include:
- Easy setup in <10 minutes without any technical expertise
- No added costs or installation wires needed with PoE (Power over Ethernet) switches
- Affordable price point with no licensing or subscription required
- View alerting ports and enable or disable them remotely
- Apply bulk settings to all ports for time and cost savings
- See the connectivity status and power consumption of all devices plugged into your switches
- Complete IT solution for business and guest needs (WiFi, security, switches)
- Automatic firmware updates to keep your network up to date and secure
- Remote cloud management via the mobile app and web portal
- Built-in free customer support (email and in-app)
Technical Specifications
Ethernet Switching Capabilities
Switching Capacity
Interface
Mounting
Power
Available PoE / PoE+ Power
Physical Dimensions
Environment
LED Indicators
Compliance
In the Box
Warranty
Model List
XX = US/UK/EU |
Accessories
