Meraki Go Outdoor WiFi Access Point - GR60 Datasheet
GR60: Dual-band, 802.11ac Wave 2 2x2:2 MU MIMO
Radios
  • 2.4 GHz 802.11b/g/n client access radio
  • 5 GHz 802.11a/n/ac client access radio
  • Supported frequency bands (country-specific restrictions apply):
    • 2.412-2.484 GHz
    • 5.150-5.250 GHz (UNII-1)
    • 5.250-5.350 GHZ (UNII-2)
    • 5.470-5.600, 5.660-5.725 GHz (UNII-2e)
    • 5.725 -5.825 GHz (UNII-3)
802.11ac and 802.11n Capabilities
  • 2 x 2 multiple input, multiple output (MIMO) with two spatial streams
  • SU-MIMO and MU-MIMO support
  • Maximal ratio combining (MRC) & Beamforming
  • 20 and 40 MHz channels (802.11n), 20, 40, and 80 MHz channels (802.11ac)
  • Up to 256 QAM on both 2.4 GHz and 5 GHz bands
  • Packet aggregation
  • Up to 4 SSIDs
Antenna
  • Integrated omni-directional antennas (5.6 dBi gain at 2.4 GHz, 5.3 dBi gain at 5 GHz)
Interfaces
  • 1x 10/100/1000 BASE-T Ethernet (RJ45)
  • 1x DC power connector (5.5 mm x 2.5 mm, center positive)
Power
  • Power over Ethernet: 37 - 57 V (802.3af compatible)
  • Alternative 12 V DC input
  • Power consumption: 11W max (802.3af)
  • Power over Ethernet injector sold separately
Environment
  • Operating temperature: -4 °F to 131 °F (-20 °C to 55 °C)
  • Humidity: 5 to 95% non-condensing
Physical Dimensions & Weight
  • 9.57” x 4.53” x 1.26” (243 mm x 115 mm x 32 mm), not including mount plate.
  • Product Weight: 0.86 lb | 0.39 kg
  • Package Weight: 2.07 lb | 0.94 kg
Mobility
  • PMK and OKC for fast Layer 2 roaming
LED Indicators
  • 2 Ethernet status
  • 1 power/booting/firmware upgrade status
Compliance
  • RoHS
  • EN 60601-1-2 EMC requirements for the Medical Directive 93/42/EEC
In the Box
  • GR60-HW: Meraki Go Outdoor Access Point
  • Wall mount and screw kit
  • Quick start guide
  • PSU and ethernet cable
Warranty
  • 1 year hardware warranty (US and Japan)
  • 1 year hardware warranty (UK and EU)
Cisco Systems, Inc. | 500 Terry A. Francois Blvd, San Francisco, CA 94158 | (415) 432-1000 | help@meraki-go.com
  • Was this article helpful?
