Radios
- 2.4 GHz 802.11b/g/n client access radio
- 5 GHz 802.11a/n/ac client access radio
- Supported frequency bands (country-specific restrictions apply):
- 2.412-2.484 GHz
- 5.150-5.250 GHz (UNII-1)
- 5.250-5.350 GHZ (UNII-2)
- 5.470-5.600, 5.660-5.725 GHz (UNII-2e)
- 5.725 -5.825 GHz (UNII-3)
802.11ac and 802.11n Capabilities
- 2 x 2 multiple input, multiple output (MIMO) with two spatial streams
- SU-MIMO and MU-MIMO support
- Maximal ratio combining (MRC) & Beamforming
- 20 and 40 MHz channels (802.11n), 20, 40, and 80 MHz channels (802.11ac)
- Up to 256 QAM on both 2.4 GHz and 5 GHz bands
- Packet aggregation
- Up to 4 SSIDs
Antenna
- Integrated omni-directional antennas (5.6 dBi gain at 2.4 GHz, 5.3 dBi gain at 5 GHz)
Interfaces
- 1x 10/100/1000 BASE-T Ethernet (RJ45)
- 1x DC power connector (5.5 mm x 2.5 mm, center positive)
Power
- Power over Ethernet: 37 - 57 V (802.3af compatible)
- Alternative 12 V DC input
- Power consumption: 11W max (802.3af)
- Power over Ethernet injector sold separately
Environment
- Operating temperature: -4 °F to 131 °F (-20 °C to 55 °C)
- Humidity: 5 to 95% non-condensing
Physical Dimensions & Weight
- 9.57” x 4.53” x 1.26” (243 mm x 115 mm x 32 mm), not including mount plate.
- Product Weight: 0.86 lb | 0.39 kg
- Package Weight: 2.07 lb | 0.94 kg
Mobility
- PMK and OKC for fast Layer 2 roaming
LED Indicators
- 2 Ethernet status
- 1 power/booting/firmware upgrade status
Compliance
- RoHS
- EN 60601-1-2 EMC requirements for the Medical Directive 93/42/EEC
In the Box
- GR60-HW: Meraki Go Outdoor Access Point
- Wall mount and screw kit
- Quick start guide
- PSU and ethernet cable
Warranty
- 1 year hardware warranty (US and Japan)
- 1 year hardware warranty (UK and EU)
