MT14 High Sampling Mode
Overview
High Sampling Mode on MT14 allows the sensor to enable faster sampling rate. This can be configured for key metrics that users may be interested in collecting more frequently according to the use case.
High Sampling Mode
The High sampling mode changes the following metrics:
Metric
Sampling Rate (High Sampling Mode Disabled)
Sampling Rate (High Sampling Mode Enabled)
Particulate Matter 2.5 (PM2.5)
5 minutes (USB-C power required)
1 second (USB-C power required)
Ambient Noise
5 minutes
5 seconds
TVOC
90 seconds
90 seconds (remains unchanged)
Temperature
2 minutes
Disabled
Humidity
2 minutes
Disabled
IAQ (Composite Score)
2 minutes
Disabled
Enabling High Sampling Mode
Device Settings
The MT14 Sensor Details page has a new tab available. Here are the steps to enable this feature on an MT14,
  1. Ensure that at least 1 gateway (MR/MV) is within 15 feet of the sensor (for optimum coverage).
Due to the increased amount of data being collected, the number of sensors per gateway has been reduced to 8 when using High Sampling Mode.
Frequently switching High Sampling Mode on and off is not recommended since re-calibrating the sensor between modes takes time.
  1. High Sampling mode can now be enabled on a per sensor basis. This can be configured by navigating to Sensors>Sensors, then selecting the MT14 you wish to use. Under the Settings tab, the PM2.5 High Sampling Mode can be toggled.
Dashboard UI PM2.5 High Sampling Mode toggled to "On"
A warning is displayed before enabling the High Sampling Mode.
Dashboard UI pop-up saying Switching modes requires a calibration period, It is recommended that you choose one mode for the sensor and use it for the remainder of its lifespan, as switching modes will require the sensors to calibrate for accuracy. Toggling on the mode will require up to 1 hour to calibrate, and toggling off the mode will require up to 12 hours to calibrate.
MT14 units must be persistently powered (plugged into a power source) for this mode to work. The toggle shown above will be grayed out if the MT14 is running on battery power alone. Upon loss of external power when this mode is enabled, PM2.5 will not be sampled but other metrics will continue to sample if the AA batteries are installed.
  1. After the High Sampling mode is turned on, the sensor will receive a configuration to modify the metric collection as outlined in the table above.
  2. There is an optional step available to automatically create a new Default Potential Vape Alert Profile and assign it to the sensor in question. Users can simply add Alert Recipients to the profile and start receiving alerts.
    Dashboard UI prompt saying Add MT14 to Default Vape Detection Alert Profile Click Add Device below to add this device to the Default Vape Detection Alert profile. ! Only devices with High Sampling Mode are eligible to send potential vape event alerts. Options are Skip and Add Device
It can take up to 20 minutes for the sensor to receive the new configuration as per the next check in period.
Default Potential Vape Detection Alert Profile
As noted above, while enabling High Sampling Mode for an MT14, a user can create or assign the sensor to a predefined Alert Profile that will help detect potential vape events.
The default value of Alert threshold for PM2.5 is currently set to 80 ug/m3 based on internal testing. However, this threshold can be changed based on the current environment where the sensor is deployed.
While the MT14 sensor directly cannot detect and isolate components of an e-cigarette fumes, PM2.5 is used to potentially indicate the presence of the vape smoke.
Also note that this Alert can also be triggered through a number of other influences such as smoke, fire, construction, etc.
Minimum Firmware Requirements
MT
MR
MV
1.4.1
29.4.1
4.20+
Things to Consider
Use Cases
High Sampling Mode is useful in a number of use cases where continuous sampling is beneficial to record transitory environmental states.
  1. Particulate Matter (PM2.5) - This metric measures dust particles less than 2.5µm in size. PM2.5 comes from many sources including automobiles, construction sites, industrial facilities, fires, smokestacks, and cooking fumes along with vaping fumes from e-cigarettes. When the sampling frequency is increased to 1 second, the sensor detects transitory changes introduced by these sources.
  2. Ambient Noise - Ambient noise is the measurement of noise that’s in the area. To ensure comfort, prolonged exposure is usually measured over a long period of time. However, by sampling it as frequently as once every 5 seconds, users can also get alerted for shorter spikes (which represent loud noises in need of investigation).
Updated Dashboard Charts
With the High Sampling Mode enabled, the data is now collected 300 times more frequently than before. To accommodate this extra data, dashboard charts will now be updated with aggregated data to improve performance.
  • Was this article helpful?
