Modem Firmware Versions
Introducing Modem Firmware Version Visibility on Meraki Dashboard.
Modem firmware version visibility is now available on the Meraki Dashboard! This feature provides transparency for ensuring the cellular devices are compliant to carrier approved firmware version and optimal performance. It is available on MG4.1 and MX 19.2 release onwards.
For the below models, modem firmware version won’t appear on dashboard
MG21/21E
Z3C
MX67C/68CW
What’s New?
Modem Firmware Version Display: You can now view the current firmware version of your cellular modem directly in the Meraki Dashboard.
Improved Visibility & Control: Gain insights into firmware versions across your devices for better management.
Simplified Troubleshooting: Easily identify outdated firmware that may require updates to resolve connectivity issues or improve performance.
Where to Access
On MG
Log in to your Meraki Dashboard.
Navigate to Cellular Gateway > Celluar Gateways > Summary
Locate the Modem Firmware Version under the Modem Firmware section.
On Z4C
Navigate to Teleworker Gateway > Appliance Status
Fields Displayed on Dashboard
When viewing modem firmware details on the Meraki Dashboard, the following fields will be displayed:
Version: Displays the current firmware version installed on the modem.
Host Version: Indicates the firmware version running on the host device
Carrier PRI version: Shows the version number of the carrier-specific configuration profile installed on the modem.
Carrier Profile: Displays the active carrier profile being used by the modem.
Recommended Firmware Versions
To ensure the best performance and stability, we recommend the following firmware versions for your Meraki Cellular SKUs:
MG41: 32.00.118
MG51: M0H.030202
MG52: M0R.015003
Z4C: M0L.000002
Why Does This Matter?
Proactive Network Management: Stay informed about the firmware version running on your modems to ensure stability and security.
Faster Issue Resolution: Quickly check if firmware updates are needed to troubleshoot connectivity concerns.
