MG41E and MG51E Cellular Dipole Antenna Datasheet
Note - Do not mix MG21E, MG41 and MG51E dipole antennas
The dipole antennas (MA-ANT-C2-A) are included with the MG41E and MG51E. When in use the dipoles have a spherical coverage in comparison to a patch antenna. The dipole antennas will excel at allowing users to place the MG in areas where a directional patch antenna cannot be mounted. The dipoles are directly attached to the MG41E/MG51E and require no additional mounting hardware.
Specifications
| Category | Specifications |
| Electrical |
Antenna Type Dipole |
Frequency Range
Peak Gain (per range)
Polarization Linear, vertical |
| Physical and Environmental |
Dimensions 144mm x 26.5mm x 12.3mm Material of Radiator PCB Material of Plastic PC Operational Temperature -40°C to +65°C (-40°F to 149°F) Storage Temperature -40°C to +80°C (-40°F to 176°F) Connector RP-SMA (female) |
| Warranty | 1 year hardware warranty included |
| Ordering Information | MA-ANT-C2-A |
| Regulatory |
Certified for use with the MG41E and MG51E MA-ANT-C2-A |
MA-ANT-C2-A
