Cisco Meraki
MG41E and MG51E Cellular Dipole Antenna Datasheet
Note - Do not mix MG21E, MG41 and MG51E dipole antennas
The dipole antennas (MA-ANT-C2-A) are included with the MG41E and MG51E. When in use the dipoles have a spherical coverage in comparison to a patch antenna. The dipole antennas will excel at allowing users to place the MG in areas where a directional patch antenna cannot be mounted. The dipoles are directly attached to the MG41E/MG51E and require no additional mounting hardware.
Specifications
Category Specifications
Electrical
Antenna Type
Dipole
Frequency Range
  • 692 (617 - 692) MHz
  • 960 (698 - 960) MHz
  • 1515 (1445 - 1515) MHz
  • 2700 (1710 - 2700) MHz
  • 5000 (3300 - 5000) MHz
  • 6000 (5150 - 6000) MHz
Peak Gain (per range)
  • 692 @ 0.26dBi
  • 960 @ 0.67dBi
  • 1515 @ 2.03dBi
  • 2700 @ 3.37dBi
  • 5000 @ 3.91dBi
  • 6000 @ 4.26dBi
Polarization
Linear, vertical
Physical and Environmental
Dimensions
144mm x 26.5mm x 12.3mm
Material of Radiator
PCB
Material of Plastic
PC
Operational Temperature
-40°C  to +65°C (-40°F to 149°F)
Storage Temperature
-40°C  to +80°C (-40°F to 176°F)
Connector
RP-SMA (female)
Warranty 1 year hardware warranty included
Ordering Information MA-ANT-C2-A
Regulatory
Certified for use with the MG41E and MG51E
MA-ANT-C2-A
MA-ANT-C2-A
  • Was this article helpful?
