MA-MNT-ANT-1 Installation Guide
Overview
The MA-MNT-ANT-1 is a standard-length (8.7 inches, or 22cm) mounting arm designed for the MA-ANT-3-E* and MA-ANT-3-F* wide patch and narrow patch antennas.
Note: There is a separate, longer mounting arm option with the MA-MNT-ANT-2, which is the same product except the mounting arm length is longer (13 inches, or 33cm).
Package Contents
The MA-MNT-ANT-1 is designed with an articulating arm that allows for mounting the MA-ANT-3-E* and MA-ANT-3-F* patch antennas to wall and ceiling surfaces. The mount comes with 5° mounting marks for precise coverage angles.
Installation
