MA-MNT-ANT-2 Installation Guide
Overview
The MA-MNT-ANT-2 is an extra-long (13 inches, or 33cm) mounting arm designed for the MA-ANT-3-E* and MA-ANT-3-F* wide patch and narrow patch antennas.
Note: There is a separate, standard mounting arm option with the MA-MNT-ANT-1, which is the same product except the mounting arm length is the standard length (8.7 inches, or 22cm).
Package Contents
The MA-MNT-ANT-2 is designed with an articulating, extended-length arm that allows for mounting the MA-ANT-3-E* and MA-ANT-3-F* patch antennas to wall and ceiling surfaces. The mount comes with 5° mounting marks for precise coverage angles.
Installation
