MR28 Datasheet
Entry Level Cloud Managed Wi-Fi 6 Access Point
The Cisco Meraki MR28 is a dual-band, 802.11ax, 2x2:2, cloud-managed entry-level access point. Designed for basic, medium-density deployments, the MR28 provides enterprise-grade security and simple management.
The MR28 provides a maximum of 1.5 Gbps* aggregate frame rate with concurrent 2.4 GHz and 5 GHz radios.
With the combination of cloud management, high-performance hardware, multiple radios, advanced software features, enterprise-grade security, the MR28 makes an excellent platform to provide reliable Wi-Fi for small business and home office networks that want reliable and secure wireless connectivity.
Note: Only MA-PWR-30W-XX (XX - AU, EU, CN, UK, US) AC adapters are compatible with MR28. Previous generations of AC adapters are not compatible with MR28.
MR28 and Meraki Cloud Management
Management of the MR28 is performed through the Meraki cloud, with an intuitive browser-based interface that enables rapid deployment without time-consuming training or costly certifications. Because the MR28 is self-configuring and managed over the web, it can be deployed at a remote location in a matter of minutes, even without on-site IT staff.
24x7 monitoring via the Meraki cloud delivers real-time alerts if a network encounters problems. Remote diagnostic tools enable immediate troubleshooting over the web so that distributed networks can be managed with a minimum of hassle.
The MR28’s firmware is automatically kept up to date via the cloud. New features, security fixes, and enhancements are delivered seamlessly over the web. This means no manual software updates to download or missing security patches to worry about.
Product Highlights
Features
Dual–radio aggregate frame rate of up to 1.5 Gbps*
5 GHz 2x2:2 and 2.4 GHz 2x2:2 radios offer a combined dual–radio aggregate frame rate of 1.5 Gbps*, with up to 1,201 Mbps in the 5 GHz band and 287 Mbps in the 2.4 GHz band.
* The radio chipset supports an aggregate PHY data rate of 1.7Gbps (1,201 Mbps in the 5 GHz band and 574 Mbps in the 2.4 GHz band).
Note: Achieving a 574 Mbps PHY rate in 2.4GHz requires using 40MHz channels (20 + 20 MHz channel bonding) in 2.4GHz, which Cisco Meraki does not enable because this feature is not recommendable in real-world enterprise deployments. Please review this KB to learn more.
Multi-User Multiple Input Multiple Output (MU-MIMO)
With support for features of 802.11ax, the MR28 offers MU-MIMO and UL/DL OFDMA for more efficient transmission to multiple clients. Especially suited to environments with numerous mobile devices, MU-MIMO enables multiple clients to receive data simultaneously. This increases the total network performance and improves the end-user experience.
Automatic cloud-based RF optimization
The MR28’s sophisticated and automated RF optimization means that there is no need for the dedicated hardware and RF expertise typically required to tune a wireless network. Collected RF data is continuously fed back to the Meraki cloud. This data is then used to automatically tune the channel selection, transmit power, and client connection settings for optimal performance under even the most challenging RF conditions.
Integrated enterprise security and guest access
The MR28 features integrated, easy-to-use security technologies to provide secure connectivity for employees and guests alike. Advanced security features such as AES hardware-based encryption and Enterprise authentication with 802.1X and Active Directory integration provide wired-like security while still being easy to configure. One-click guest isolation provides secure, Internet-only access for visitors. PCI compliance reports check network settings against PCI requirements to simplify secure retail deployments.
Enterprise Mobility Management (EMM) & Mobile Device Management (MDM) integration
Meraki Systems Manager natively integrates with the MR28 to offer automatic, context-aware security. Systems Manager’s self-service enrollment helps to rapidly deploy MDM without installing additional equipment, and then dynamically tie firewall and traffic shaping policies to client posture.
Application-aware traffic shaping
The MR28 includes an integrated layer 7 packet inspection, classification, and control engine, enabling the configuration of QoS policies based on traffic type, helping to prioritize mission-critical applications while setting limits on recreational traffic like peer-to-peer and video streaming. Policies can be implemented per network, per SSID, per user group, or per individual user for maximum flexibility and control.
Voice and video optimizations
Industry standard QoS features are built-in and easy to configure. Wireless MultiMedia (WMM) access categories, 802.1p, and DSCP standards all ensure important applications get prioritized correctly, not only on the MR28 but on other devices in the network. Unscheduled Automatic Power Save Delivery (U-APSD) and new Target Wait Time features in 802.11ax clients ensure minimal battery drain on wireless VoIP phones.
Self-configuring, self-maintaining, always up-to-date
When plugged in, the MR28 automatically connects to the Meraki cloud, downloads its configuration, and joins the appropriate network. If new firmware is required, this is retrieved by the AP and updated automatically. This ensures the network is kept up-to-date with bug fixes, security updates, and new features.
Advanced analytics
Drilling down into the details of network usage provides highly granular traffic analytics. Visibility into the physical world can be enhanced with journey tracking through location analytics. Visitor numbers, dwell time, repeat visit rates, and track trends can all be easily monitored in the dashboard and deeper analysis is enabled with raw data available via simple APIs.
Bluetooth Low Energy (BLE Beacon and scanning)
An integrated Bluetooth radio provides seamless deployment of BLE Beacon functionality and effortless visibility of Bluetooth devices.
Specifications
Category |
Specifications |
Radios |
Antenna |
802.11ax, 802.11ac Wave 2 and 802.11n Capabilities |
Power |
Note: Actual power consumption may vary depending on the AP usage. |
Interfaces |
Physical Security |
Environment |
Reliability |
Physical Dimensions |
Security |
Quality of Service |
Mobility |
Analytics |
LED Indicators |
Regulatory |
Warranty |
Ordering Information |
* Contact Meraki Support to enable
** Software features that can be enabled via firmware updates
Compliance and Standards
Category |
Standards |
IEEE Standards |
Safety Approvals |
Radio Approvals |
EMI Approvals (Class B) |
Exposure Approvals |
*** Denotes a feature that can be enabled for required networks.
Context and Comparisons
MR28 |
MR44 |
MR46 |
MR56 |
DL-OFDMA**, UL-OFDMA**, TWT support**, BSS coloring** |
2 x 2 multiple input, multiple output (MIMO) with two spatial streams |
2.4GHz: 2 x 2 multiple input, multiple output (MIMO) with two spatial streams 5GHz: 4 x 4 multiple input, multiple output (MIMO) with four spatial streams |
8 x 8 multiple input, multiple output (MIMO) with eight spatial streams on 5 GHz 4 x 4 multiple input, multiple output (MIMO) with eight spatial streams on 2.4 GHz |
Maximal ratio combining (MRC) & beamforming |
SU-MIMO, UL MU-MIMO** and DL MU-MIMO support |
20 and 40 MHz* channels (802.11n); 20, 40*, and 80 MHz channels (802.11ac Wave 2); 20, 40* and 80 MHz channels (802.11ax) |
20 and 40 MHz* channels (802.11n); 20, 40*, and 80 MHz channels (802.11ac Wave 2); 20, 40* and 80MHz channels (802.11ax) |
Note: *40MHz channels are supported only in the 5GHz band. |
Up to 1024-QAM on both 2.4 GHz & 5 GHz bands |
Packet aggregation |
Power
MR28 |
MR44 |
MR46 |
MR56 |
Power over Ethernet: 37 - 57 V (802.af compliant) |
Power over Ethernet: 42.5 - 57 V (802.3at) or 37 - 57 V (802.3af) - low power mode |
Power over Ethernet: 42.5 - 57 V (802.3at compliant) |
Alternative: 12 V DC input |
Power consumption: 15W max (802.3af) |
Power consumption: 30W max (802.3at) or 15W max (802.3af) - low power mode ** |
Power consumption: 30W max (802.3at required) |
Power over Ethernet injector and DC adapter sold separately |
Interfaces
MR28 |
MR44 |
MR46 |
MR56 |
1x 10/100/1000 BASE-T Ethernet (RJ45) |
1x 100/1000/2.5G BASE-T Ethernet (RJ45) |
1x 100/1000/2.5G/5G BASE-T Ethernet (RJ45) |
1x DC power connector (5.5 mm x 2.5 mm, center positive) |
Physical Dimensions
MR28 |
MR44 |
MR46 |
MR56 |
7.95” x 4.88” x 1.02” (202 mm x 124 mm x 25.8 mm), not including deskmount feet or mount plate |
12.05" × 5.06" × 1.74" (30.6 cm × 12.84 cm × 4.43 cm), not including desk mount feet or mount plate |
12.05” x 5.06” x 1.74” (30.6 cm x 12.84 cm x 4.43 cm), not including desk mount feet or mount plate |
12.83” x 5.54” x 1.76” (32.6 cm x 14.079 cm x 4.47 cm), not including desk mount feet or mount plate |
Weight: 9.6 oz (272 g) |
Weight: 26.07 oz (739 g) |
Weight: 28.22 oz (800 g) |
Weight: 35.27 oz (1 kg) |
RF Performance Table
2.4 GHz
Operating Band |
Operating Mode |
Data Rate |
TX Power (conducted) |
RX Sensitivity |
2.4 GHz |
802.11b |
1 Mb/s |
20 |
-100 |
2 Mb/s |
20 |
-90 |
5.5 Mb/s |
20 |
-90 |
11 Mb/s |
20 |
-90 |
2.4 GHz |
802.11g |
6 Mb/s |
19 |
-94 |
9 Mb/s |
19 |
-93 |
12 Mb/s |
19 |
-91 |
18 Mb/s |
19 |
-89 |
24 Mb/s |
16 |
-86 |
36 Mb/s |
16 |
-82 |
48 Mb/s |
16 |
-78 |
54 Mb/s |
16 |
-77 |
2.4 GHz |
802.11n (HT20) |
MCS0 |
18.5 |
-95 |
MCS1 |
18.5 |
-92 |
MCS2 |
18.5 |
-90 |
MCS3 |
18.5 |
-87 |
MCS4 |
18.5 |
-83 |
MCS5 |
14.5 |
-79 |
MCS6 |
14.5 |
-78 |
MCS7 |
14.5 |
-76 |
2.4 GHz |
802.11ac (VHT20) |
MCS0 |
18.5 |
-95 |
MCS1 |
18.5 |
-92 |
MCS2 |
18.5 |
-90 |
MCS3 |
18.5 |
-87 |
MCS4 |
18.5 |
-83 |
MCS5 |
14.5 |
-79 |
MCS6 |
14.5 |
-78 |
MCS7 |
14.5 |
-77 |
MCS8 |
14 |
-72 |
2.4 GHz |
802.11ax (HE20) |
MCS0 |
19 |
-93 |
MCS1 |
19 |
-90 |
MCS2 |
19 |
-88 |
MCS3 |
19 |
-85 |
MCS4 |
19 |
-81 |
MCS5 |
14.5 |
-77 |
MCS6 |
14.5 |
-76 |
MCS7 |
14.5 |
-75 |
MCS8 |
14 |
-70 |
MCS9 |
14 |
-68 |
MCS10 |
13.5 |
-65 |
MCS11 |
13.5 |
-63 |
5 GHz
Operating Band |
Operating Mode |
Data Rate |
RX Sensitivity |
5 GHz
802.11a
6 Mb/s |
17.5 |
-92 |
9 Mb/s |
17.5 |
-91 |
12 Mb/s |
17.5 |
-89 |
18 Mb/s |
17.5 |
-87 |
24 Mb/s |
15 |
-83 |
36 Mb/s |
15 |
-80 |
48 Mb/s |
15 |
-76 |
54 Mb/s |
15 |
-76 |
5 GHz
802.11n (HT20)
MCS0 |
17.5 |
-93 |
MCS1 |
17.5 |
-90 |
MCS2 |
17.5 |
-88 |
MCS3 |
17.5 |
-85 |
MCS4 |
17.5 |
-81 |
MCS5 |
13.5 |
-77 |
MCS6 |
13.5 |
-76 |
MCS7 |
13.5 |
-75 |
5 GHz
802.11n (HT40)
MCS0 |
17.5 |
-91 |
MCS1 |
17.5 |
-88 |
MCS2 |
17.5 |
-86 |
MCS3 |
17.5 |
-83 |
MCS4 |
17.5 |
-79 |
MCS5 |
13.5 |
-75 |
MCS6 |
13.5 |
-74 |
MCS7 |
13.5 |
-73 |
5 GHz
802.11ac (VHT20)
MCS0 |
17.5 |
-94 |
MCS1 |
17.5 |
-91 |
MCS2 |
17.5 |
-89 |
MCS3 |
17.5 |
-86 |
MCS4 |
17.5 |
-82 |
MCS5 |
13.5 |
-78 |
MCS6 |
13.5 |
-77 |
MCS7 |
13.5 |
-76 |
MCS8 |
13.5 |
-70 |
5 GHz
802.11ac (VHT40)
MCS0 |
17.5 |
-91 |
MCS1 |
17.5 |
-88 |
MCS2 |
17.5 |
-86 |
MCS3 |
17.5 |
-83 |
MCS4 |
17.5 |
-79 |
MCS5 |
13.5 |
-75 |
MCS6 |
13.5 |
-74 |
MCS7 |
13.5 |
-73 |
MCS8 |
13.5 |
-68 |
MCS9 |
13.5 |
-67 |
5 GHz
802.11ac (VHT80)
MCS0 |
17.5 |
-88 |
MCS1 |
17.5 |
-85 |
MCS2 |
17.5 |
-83 |
MCS3 |
17.5 |
-80 |
MCS4 |
17.5 |
-76 |
MCS5 |
13.5 |
-72 |
MCS6 |
13.5 |
-71 |
MCS7 |
13.5 |
-70 |
MCS8 |
13.5 |
-65 |
MCS9 |
13.5 |
-64 |
5 GHz
802.11ax (HE20)
MCS0 |
17.5 |
-93 |
MCS1 |
17.5 |
-92 |
MCS2 |
17.5 |
-88 |
MCS3 |
17.5 |
-85 |
MCS4 |
17.5 |
-81 |
MCS5 |
13.5 |
-77 |
MCS6 |
13.5 |
-76 |
MCS7 |
13.5 |
-75 |
MCS8 |
13.5 |
-70 |
MCS9 |
13.5 |
-68 |
MCS10 |
12 |
-65 |
MCS11 |
12 |
-60 |
5 GHz
802.11ax (HE40)
MCS0 |
17 |
-91 |
MCS1 |
17 |
-88 |
MCS2 |
17 |
-86 |
MCS3 |
17 |
-83 |
MCS4 |
17 |
-79 |
MCS5 |
13.5 |
-75 |
MCS6 |
13.5 |
-74 |
MCS7 |
13.5 |
-73 |
MCS8 |
13.5 |
-68 |
MCS9 |
13.5 |
-66 |
MCS10 |
12 |
-63 |
MCS11 |
12 |
-62 |
5 GHz
802.11ax (HE80)
MCS0 |
17 |
-88 |
MCS1 |
17 |
-85 |
MCS2 |
17 |
-83 |
MCS3 |
17 |
-80 |
MCS4 |
17 |
-76 |
MCS5 |
13.5 |
-72 |
MCS6 |
13.5 |
-71 |
MCS7 |
13.5 |
-70 |
MCS8 |
13.5 |
-65 |
MCS9 |
13.5 |
-63 |
MCS10 |
12 |
-60 |
MCS11 |
12 |
-59 |
Signal Coverage Patterns
5 GHz - Wireless
2.4 GHz - Wireless
BLE
Installation Guide
For instructions on how to install and configure MR28 access points please refer to the MR28 Installation Guide.
