Channel Bonding
"Legacy" 802.11 clients use 20MHz channels. 802.11n specifies the use of 40MHz wide channels to achieve higher data rates. Channel bonding is supported in 5GHz and commonly uses two contiguous 20MHz channels to create a single 40MHz channel. While channel bonding can provide higher data rates, it will also result in fewer 5GHz channels.
In some high-density client environments with high wireless saturation, having more available 20MHz channels to spread client usage provides better performance than having fewer 40MHz channels. In addition, not all regulatory domains support using a 40-MHz channel.
A wide 5GHz channel comprises "primary" and "secondary" channels. The "primary" channel is used for 802.11n clients that only support 20MHz channel bandwidth (e.g., “legacy: clients). Both primary and secondary channels can be used for clients that support wide channel (40MHz) capabilities.
The location of the primary channel is specified when you manually configure channel selection in 5GHz. The primary channel is either the upper or lower half of the 40MHz channel. For example, if you are using a 40MHz-wide channel in 5GHz and choose channel 36, then channel 36 (lower half) would be the primary channel, and the secondary channel would be channel 40 (upper half). Conversely, if you specified that channel 40 would be selected as the primary (upper half) and the secondary would be channel 36 (lower half).
Note: While achieving higher PHY rates in 2.4GHz is theoretically possible, it requires using 40MHz channels (20 + 20 MHz channel bonding) in 2.4GHz, which Cisco Meraki does not enable because this feature is not recommendable in real-world enterprise deployments due to the following reasons:
The 2.4GHz band is 83.5MHz wide and has three non-overlapping channels (1, 6, and 11) in most regulatory domains worldwide. Channel bonding limits the 2.4GHz band to a 40MHz-wide single non-overlapping channel, making over half of the bandwidth unusable.
With Wi-Fi being an unlicensed spectrum that has to be shared, one company or customer should not monopolize the entire spectrum because this is poor spectrum management in the best case and harmful interference in the worst-case scenario.
Even if we consider only one customer or company, using channel bonding in 2.4GHz would limit the entire site to one access point using 2.4GHz, which is not feasible for any enterprise deployment.
Finally, while some major wireless client vendors support channel bonding in 2.4GHz and recommend using 20MHz channel width for reliability and interference avoidance, supporting such a setting on the wireless infrastructure side could cause compatibility and interoperability issues on the client side
Selectable Channels (5GHz) via Radio Settings in the Meraki Dashboard
| Bonded Channel | Channel | Frequency (Mhz) | UNII | United States (FCC) | Europe (CE) |
| 36+ | 36 | 5180 | UNII-1 | Yes | Yes |
| 38 | 5190 | UNII-1 | No | No | |
| 40- | 40 | 5200 | UNII-1 | Yes | Yes |
| 42 | 5210 | UNII-1 | No | No | |
| 44+ | 44 | 5220 | UNII-1 | Yes | Yes |
| 46 | 5230 | UNII-1 | No | No | |
| 48- | 48 | 5240 | UNII-1 | Yes | Yes |
| 52+ | 52 | 5260 | UNII-2 | No* | Yes |
| 56- | 56 | 5280 | UNII-2 | No* | Yes |
| 60+ | 60 | 5300 | UNII-2 | No* | Yes |
| 64- | 64 | 5320 | UNII-2 | No* | Yes |
| 100+ | 100 | 5500 | UNII-2 | No* | Yes |
| 104- | 104 | 5520 | UNII-2 | No* | Yes |
| 108+ | 108 | 5540 | UNII-2 | No* | Yes |
| 112- | 112 | 5560 | UNII-2 | No* | Yes |
| 116 | 5580 | UNII-2 | No* | No* | |
| 120 | 5600 | UNII-2 | No* | No* | |
| 124 | 5620 | UNII-2 | No* | No* | |
| 128 | 5640 | UNII-2 | No* | No* | |
| 132 | 5660 | UNII-2 | No* | No* | |
| 136 | 5680 | UNII-2 | Yes | Yes | |
| 140 | 5700 | UNII-2 | Yes | Yes | |
| 149+ | 149 | 5745 | UNII-3 | Yes | No |
| 153- | 153 | 5765 | UNII-3 | Yes | No |
| 157+ | 157 | 5785 | UNII-3 | Yes | No |
| 161- | 161 | 5805 | UNII-3 | Yes | No |
| 165 | 5825 | UNII-3 | No* | No |
*Channels are selectable by IEEE 802.11 standards, but unsupported by Meraki
Please always check with the local regulatory body for channel/power support.
