How to Enable Run Dark Mode
Overview
Run Dark mode disables the LED lights on all Smart Cameras (MVs) and access points (APs) in your network. Use it when the lights are annoying, distracting, or overly conspicuous. For example, enable Run Dark mode to prevent outdoor APs from drawing attention at night.
Run Dark mode primarily disables the power and status indicator LEDs on Meraki APs and Smart Cameras. On some models, it also disables the Ethernet port LEDs. Cisco Meraki Security Appliances (MXs) and Smart Cameras (MVs) can also use the run_dark tag to disable their power/HA status LED.
This article explains how to configure Run Dark mode in two ways:
- Network-wide: Disable LEDs on all APs and MVs in the network from the Dashboard general settings.
- Per device: Disable LEDs on individual devices with the run_dark tag, or reactivate LEDs on individual APs with the run_lit tag.
Prerequisites
- A Meraki network with access points, or MX Security Appliances or MV Smart Cameras if you plan to use per-device tags
- Dashboard access to Network-wide > Configure > General and to device tags
Step-by-step instructions
Enable Run Dark mode for the whole network
Go to Network-wide > Configure > General.
Set Access point LED lights to Off (run dark).
- For Smart Cameras (MVs), set Camera LED lights to Off (run dark).
Enable Run Dark mode on individual devices
To disable LEDs on a single device without changing the network-wide setting, add the run_dark tag to that device. This tag works on:
- Access points
- MX Security Appliances
- MV Smart Cameras
Reactivate LEDs on individual APs in a Run Dark network
If you set the network to Run Dark (Access point LED lights = Off), add the run_lit tag to any individual AP that needs its LEDs active.
Verification
Confirm the LED state
After you apply the configuration, confirm these outcomes:
- APs in a Run Dark network, or APs with the run_dark tag, show no power/status LED.
- MXs and MVs with the run_dark tag show no power/HA status LED.
- APs with the run_lit tag in a Run Dark network show active LEDs.
Expected Ethernet port LED behavior
Run Dark mode also disables the Ethernet port LEDs on some AP models. On MXs in dark mode, the port LEDs still light up, and you cannot disable them with the tag.
Ethernet port LEDs turn off in Run Dark mode on these models:
| Model | Ethernet Port LEDs off in Run Dark Mode |
| MR18 | Yes |
| MR20 | No |
| MR24 | No |
| MR26 | Yes |
| MR28 | Yes |
| MR32 | Yes |
| MR33 | No |
| MR34 | No |
| MR42 | No |
| MR44 | Yes |
| MR45 | Yes |
| MR46 | Yes |
| MR52 | Yes |
| MR53 | Yes |
| MR55 | Yes |
| MR30H | Yes |
| MR36 | No |
| MR36H | Yes |
| MR56 | Yes |
| MR57 | Yes |
| CW9162 | Yes |
| CW9164 | Yes |
| CW9166 | Yes |
| MR76 | No |
| MR78 | Yes |
| MR86 | Yes |
Troubleshooting
LEDs blink while Run Dark mode is enabled
The Blink LEDs feature on an AP overrides Run Dark mode. When you use it, the AP blinks both the status LED and the Ethernet port LEDs.
Ethernet port LEDs stay lit in Run Dark mode
Some devices keep their Ethernet port LEDs lit by design, including MXs and several AP models. Go to Expected Ethernet port LED behavior to check your model.
