MS150 Series Installation Guide
About This Guide
This guide provides instruction on how to install and configure your MS150 series switch. This guide also provides mounting instructions and limited troubleshooting procedures. For more switch installation guides, refer to the switch installation guides section on our documentation website.
Product Overview
Physical Specifications
  24T-4G 24P-4G 24T-4X 24P-4X 48T-4X 48LP-4X
1Gbe RJ45 24 24 24 24
48
48
mGbe RJ45 - - - - - -
1 Gbe SFP
4 4 - - - -
10Gbe SFP+ - - 4 4 4 4
Dedicated Mgmt Interface 1 1 1 1 1 1
PoE Type - 802.3bt - 802.3bt - 802.3bt
PoE Port Budget - 30W - 30W - 30W
PoE Switch Budget - 370W - 370W - 370W
Stacking Ports 2 2 2 2 2 2
Power Input 100-240VAC 100-240VAC 100-240VAC 100-240VAC 100-240VAC 100-240VAC
Power Load (idle/max)
13.7W/32.4W 22.9W/422.2W 13.7W/32.4W 22.9W/422.2W 23.1W/49.8W 36.2W/460.6W
Operating Temperature 32°F - 113 °F
0°C - 45°C
32°F - 113 °F
0°C - 45°C
32°F - 113 °F
0°C - 45°C
32°F - 113 °F
0°C - 45°C
32°F - 113 °F
0°C - 45°C
32°F - 113 °F
0°C - 45°C
Storage and Transportation Temperature
-4°F - 158 °F
-20°C - 70°C
-4°F - 158 °F
-20°C - 70°C
-4°F - 158 °F
-20°C - 70°C
-4°F - 158 °F
-20°C - 70°C
-4°F - 158 °F
-20°C - 70°C
-4°F - 158 °F
-20°C - 70°C
Humidity 5% to 95% 5% to 95% 5% to 95% 5% to 95% 5% to 95% 5% to 95%
Mounting Integrated 1U Rack Mount Integrated 1U Rack Mount Integrated 1U Rack Mount Integrated 1U Rack Mount Integrated 1U Rack Mount Integrated 1U Rack Mount
  48FP-4X 48T-4G 48LP-4G 48FP-4G 24MP-4X 48MP-4X
1Gbe RJ45 48 48 48 48 16 32
mGbe RJ45 - - - - 8 x 5G* 16 x 5G*
1Gbe SFP - 4 4 4 - -
10Gbe SFP+ 4 - - - 4 4
PoE Type 802.3bt - 802.3bt 802.3bt 802.3bt 802.3bt
PoE Port Budget 30W - 30W 30W 60W** 60W**
PoE Switch Budget 740W - 370W 740W 370W 740W
Power Load (idle/max) 44.6W/891.4W 23.1W/49.8W 36.2W/460.6W 44.6W/891.4W 43W/454W 76W/933W
0°C - 45°C
32°F - 113 °F
0°C - 45°C
32°F - 113 °F
0°C - 45°C
32°F - 113 °F
0°C - 45°C
32°F - 113 °F
0°C - 45°C
32°F - 113 °F
0°C - 45°C
Storage and Transportation Temperature -4°F - 158 °F
-20°C - 70°C
-4°F - 158 °F
-20°C - 70°C
-4°F - 158 °F
-20°C - 70°C
-4°F - 158 °F
-20°C - 70°C
-4°F - 158 °F
-20°C - 70°C
-4°F - 158 °F
-20°C - 70°C
Note:
* mGig available on ports 17-24 for 24MP-4X and ports 33-48 for 48MP-4X models.
** UPoE up to 60W available on ports 17-24 for 24MP-4X and ports 33-48 for 48MP-4X models.
Product View and Physical Features
Front Panel
MS150-24T-4G Series front panel
MS150-24T-4X Series front panel
MS150-24P-4G Series front panel
MS150-24P-4X Series front panel
MS150-24MP-4X Series front panel
MS150-48T-4G Series front panel
MS150-48T-4X Series front panel
MS150-48LP-4G Series front panel
MS150-48LP-4X Series front panel
MS150-48FP-4G Series front panel
MS150-48FP-4X Series front panel
MS150-48MP-4X Series front panel
Back Panel
MS150 Series back panel
Factory Reset Button
There is a factory reset button on the front panel. A brief, momentary press deletes the downloaded configuration and reboots the switch, which will then download a new copy of the config. If the button is pressed and held for at least five seconds and then released, the switch will reboot and be restored to its original factory settings by deleting all configuration information stored on the unit.
Ports and Status Indicators
The MS uses LEDs to inform the user of the device's status. Functions are described below, from left to right. For fixed Ethernet ports, the status LED is on the top left or bottom right depending on port orientation. There is also a traffic LED which flashes orange as traffic is sent/received through that port.
Function
LED Status
Meaning
Power
Solid orange
Switch is unable to connect to the Meraki cloud
Flashing white
Firmware upgrade in process
Solid white
Switch is fully operational and connected to the Meraki cloud
Off
Switch does not have power
Restore N/A Restore button to clear switch IP and local configuration settings
Switch Ports
Off
No link is detected on this port
Solid orange
10/100 Mbps (1 Gbps on SFP+)
Solid green
Port is operating at full speed
  • 1GE on 1GE ports
  • 5GE on 5GE ports
  • 10GE on SFP+
In addition, there is a RESTORE button available on the front panel.
Insert a paperclip if a restore is required.
  • A brief, momentary press: To delete a downloaded configuration and reboot.
  • Press and hold for more than 10 sec: To force the unit into a full factory restore.
Back Panel Components
Function
LED Status
Meaning
Management Interface
Green
Connected, used for easy access to the local status page
Stack Ports
Green
QSFP28 stacking cable is connected
  Off No link is detected on this port
Package contents
In addition to the MS switch, the following are provided:
Screenshot of Rack Mounting kit.
Note: The MS150 does not include stacking cables.  Stacking cables sold separately.
Safety and Warnings
These operations are to be taken with respect to all local laws. Please take the following into consideration for safe operation:
  • Power off the unit before you begin. Read the installation instructions before connecting the system to the power source.
  • Before you work on any equipment, be aware of the hazards involved with electrical circuitry and be familiar with standard practices for preventing accidents.
  • Read the mounting instructions carefully before beginning installation. Failure to use the correct hardware or to follow the correct procedures could result in a hazardous situation to people and damage to the system.
  • This product relies on the building’s installation for short-circuit (overcurrent) protection. Ensure that the protective device is rated not greater than: 15 A, 125 Vac, or 10A, 240 Vac.
  • Please only power the device with the provided power cables to ensure regulatory compliance.
Pre-install Preparation
Configure your Dashboard Network
The following is a brief overview only of the steps required to add a switch to your network. For detailed instructions about creating, configuring and managing Meraki networks, refer to the online documentation (documentation.meraki.com).
  1. Navigate to http://dashboard.meraki.com.
  2. Log in with your credentials. [Note: Create a new account and log in, If you are a first time user].
  3. Locate the network where you plan to add your switches, or create a new network.
  4. Add your switches to your network by using your Meraki order number from your invoice or the serial number of each switch, which is located on the bottom of the unit (Qxxx-xxxx-xxxx). Enter the Enterprise license key you received via email.
  5. Navigate to the map / floor plan view and place each switch on the map by clicking and dragging it to the location where you plan to mount it.
Check and Set Firmware
To ensure your switch performs optimally immediately following installation, it is recommended that you facilitate a firmware upgrade prior to mounting your switch.
  1. Attach your switch to power and a wired Internet connection.
  2. The switch will turn on and the power LED will glow solid orange.
  3. If the unit requires an upgrade, the power LED will begin blinking white until the upgrade is complete, at which point the LED will turn solid white. You should allow at least a few minutes for the firmware upgrade to complete, depending on the speed of your internet connection.
Check and Configure Upstream Firewall Settings
If a firewall is in place, it must allow outgoing connections on particular ports to particular IP addresses. The most current list of outbound ports and IP addresses for your particular organization can be found on the firewall configuration page in your dashboard.
Assigning an IP Address
All switches must be assigned routable IP addresses. These IP addresses can be dynamically assigned via DHCP or statically assigned.
Dynamic Assignment
When using DHCP, the DHCP server should be configured to assign a static IP address for each MAC address belonging to a Meraki switch. Other features of the network, such as 802.1X authentication, may rely on the property that the switches have static IP addresses.
Static Assignment
Static IPs are assigned using the local web server on each switch. The following procedure describes how to set the static IP:
  1. Using a client machine (e.g., a laptop), connect to the switch over a wired connection.
  2. Using a web browser on the client machine, access the switch’s built-in web server by browsing to http://my.meraki.com. Alternatively, browse to http://1.1.1.100
  3. Click on the “Uplink Configuration” tab. Log in. The default login is the serial number (e.g. Qxxx-xxxx-xxxx), with no password (e.g., Q2DD-551C-ZYW3).
  4. Configure the static IP address, net mask, gateway IP address and DNS servers that this switch will use on its management connection.
  5. If necessary, reconnect the switch to the LAN.
Instead of associating to each Meraki switch individually to configure static IP addresses, an administrator can assign static IP addresses on the upstream DHCP server. Through “DHCP reservations,” IP addresses are “reserved” for the MAC addresses of the Meraki switches. Please consult the documentation for the DHCP server to configure DHCP reservations.
Installation Instructions
Note: Each switch comes with a graphical instruction pamphlet within the box. This pamphlet contains detailed step by step guides and images to assist in the physical install of the switch.
1. Install the mounting cage nuts in the rack being used for the switch.
2. Attach the switch face plate to the cage nuts on the rack.
3. Connect power to the power supply unit.
4. (Optional) Install additional SFP+ units as needed, depending on the compatibility of your model.
Mounting hardware
The mounting hardware includes a rack mount kit for standard 1U racks. When installing the device, make sure that there is sufficient space between the rear of the rack and other obstacles to ensure adequate airflow.
Optional Mid-Mount bracket
MS150-48 port models are designed for an optional MA-MNT-MID-1 mid-mount bracket when using 2-post racks.
Basic Troubleshooting
The following steps can be used for troubleshooting basic connectivity issues with your switch.
  • Reset the switch
  • Factory reset the switch by holding the factory reset button for 5 seconds
  • Try switching cables, or testing your cable on another device
If your switch still does not connect, the following instructions may be useful, depending on your issue: Troubleshooting an MS Switch.
Reference https://documentation.meraki.com/MS for additional information and troubleshooting tips.
If you are still experiencing hardware issues, please open a case via Meraki dashboard, click the ? icon in the top right of the menu bar and select Support Center. Select the relevant Product or Platform tile, then follow the prompts to enter your case details and submit. For full steps, see Ways to Contact Meraki Support.
Bringing your Stack Online
MS150 switches can be connected in a physical stack using dedicated stacking ports and cables. Configuration steps and additional information about stacking can be found here.
Warranty
MS Warranty coverage periods are as follows:
  Time Period Comments
MS150 Lifetime
MS Accessories 1 Year
The following are considered accessories:
SFP Modules, twinax/SFP+ cables, stacking cables, all mounting kits and stands, antennas, interface modules, additional power cords, PoE injectors
Note: The above table is a general guideline for warranty terms and is not final. Warranty terms are subject to printed warranty information on the relevant online Meraki data sheets.
If your Cisco Meraki device fails and the problem cannot be resolved by troubleshooting, contact support to address the issue. Once support determines that the device is in a failed state, they can process an RMA and send out a replacement device free of charge. In most circumstances, the RMA will include a pre-paid shipping label so the faulty equipment can be returned.
Note: In order to initiate a hardware replacement for non-functioning hardware that is under warranty, you must have access to the original packaging the hardware was shipped in. The original hardware packaging includes device serial number and order information, and may be required for return shipping.
Meraki MS150 devices have been tested and found to comply with the limits for a Class A digital device, pursuant to part 15 of the FCC rules. These limits are designed to provide reasonable protection against harmful interference in a residential installation. This equipment generates, uses and can radiate radio frequency energy and, if not installed and used in accordance with the instructions, may cause harmful interference to radio communications. However, there is no guarantee that interference will not occur in a particular installation.
Additional warranty information can be found on: https://meraki.cisco.com/support#process:warranty
If issues are encountered with device installation or additional help is required, contact Meraki Support by logging in to dashboard.meraki.com and opening a case by visiting the Get Help section.
For additional information on Meraki hardware and for other installation guides, please refer to documentation.meraki.com.
