MT15 Datasheet - Indoor Air Quality w/CO2
Overview
Indoor air quality has become increasingly important to schools, businesses, and other organizations as they look to provide safe and comfortable environments.
MT15 is our highest performing air quality sensor, offering carbon dioxide monitoring for student and employee productivity. It monitors real CO2, TVOC, PM2.5, temperature, humidity, and ambient noise. It also offers a LED visual indicator to provide information about the air quality to the people in the room. Finally, the MT15 has flexible power options, including both a USB-C and PoE port on the device, which are positioned so that cables can be hidden.The MT15 can be installed in any space but will be particularly useful for monitoring air quality in classrooms and office settings where students and employees spend a large majority of their time performing activities that require cognitive effort.
Businesses need a complete view of data to make sound decisions. Businesses need visibility into their network availability metrics, capex & opex, and customer satisfaction levels to deliver on their mission. While businesses have a good grip on embracing and utilizing data in the business world, they have yet to visualize the physical world fully.
Current solutions are complicated to install, do not scale and are difficult to use. Hence businesses do not have a simple and reliable way to have visibility into their critical assets to maximize their network uptimes, reduce equipment failure, reduce unnecessary site visits,  and deliver best-in-class customer service.
So, Meraki is introducing a range of sensors to prevent loss and increase operational efficiency with ease. Our sensors are simple, scalable and secure. Our sensors also connect to the dashboard using the MV/MR, removing the need for expensive gateways. Customers can now gain real-time visibility into their critical business environment from a  single pane of glass.
CLOUD MANAGED SENSORS
The Cisco Meraki MT15 sensors provide temperature, humidity, CO2, TVOC, PM2.5 and Ambient Noise monitoring for environments across industries using BLE (Bluetooth Low Energy) beacons on the MR and MV.
Our sensors are built from the ground up to be easy to manage without compromising on power and flexibility.
All Meraki sensors are managed through an elegant, intuitive cloud-based interface.
Meraki’s centralized management gives administrators granular visibility into their network.
INDUSTRY LEADING CLOUD MANAGEMENT
Cloud management has a number of benefits that make it easier to build networks large and small:
Automatic alerts based on customizable thresholds through SMS, Email and Mobile push notifications.
Enterprise-grade security which the Cisco Trustworthy Systems seal of approval.
Role-based administration.
Firmware upgrades and enhancements from the Meraki cloud.
Zero-touch provisioning for rapid deployment across sites.
Product Highlights
  • Visual LED Indicator Ring
  • Single pane of glass for sensor monitoring combined with your existing Meraki dashboard
  • Always-on, real-time visibility (24/7/365 visibility)
  • Flexible alerts via email, SMS, mobile push notifications and webhooks
  • Simple to set up reporting and configuration
  • Data mining APIs for custom development and integrations.
  • Multiple installation options
  • Provision multiple sensors in minutes
  • TAA compliant
Technical Specifications
Sensors
Temperature
Range: 0°C - 55°C / 32F - 131F
Accuracy: +/- 0.5°C
Humidity
Range: 0 - 95 % RH
Accuracy: +/- 3% RH
CO2
Range: 400 ppm – 1’000 ppm; Accuracy: ±(50 ppm + 2.5% of reading)
Range: 1’001 ppm – 2’000 ppm; Accuracy: ±(50 ppm + 3% of reading)
Range: 2’001 ppm – 5’000 ppm; Accuracy: ±(40 ppm + 5% of reading)
Total Volatile Organic Compound
TVOC (MT 1.5 and below):
Range: 160-10000 µg/m³
Accuracy: ± 20 µg/m³  + 15%
PBAQ Algorithm (MT 1.6 or higher):
Range: 1 to 2000 µg/m³
Accuracy: (± 20 µg/m³  + 15%) at 1 to 1000 µg/m³
Particulate Matter (PM 2.5)
Range: 0-100 µg/m³; Accuracy: +/-10 µg/m³
Range: 100 to 1000 µg/m³;  Accuracy: +/-10% measured value
Ambient Noise 20 to 120 dBA
Wireless Capabilities
Bluetooth Low Energy "BLE 4.2" Compatible MV smart cameras and MR access points
Operating Frequency 2.400–2.4835 GHz
IEEE Standard 802.15.1 ( Bluetooth Low Energy 4.2)
Data Logging
Data sampling
Sample Polling:
Temp/Humidity - 30 seconds
CO2 - 30 seconds
TVOC - 3 seconds
PM 2.5 - 1 second
Ambient Noise - 5 seconds
Data reporting to gateway: 20-minute interval, threshold violation
Security Secure Bluetooth Low Energy  "BLE" messaging using LTK(Long-Term Key)
Physical Characteristics
Dimensions
115.0(L)x125(W)x33.5(H)mm
Weight 216g
Power Ratings
USB-C: 5V;0.2A
PoE: 802.3af (Power Only)
Operating Environment
Temperature: 0°C - 55°C(32F - 131F)
Relative Humidity: 0 - 95 % RH
Hardware
Multicolor, multifunction status LED Ring
General purpose button
Reset button
USB-C Port for External Power
Ordering Information
MT15-HW Meraki Indoor Air Quality with CO2 Sensor
LIC-MT-XYR Meraki MT Enterprise License (X = 1, 3, 5, 7, 10 years)
Accessories
External Power Adapter(Sold Separately):
MA-PWR-USB-US
MA-PWR-USB-UK
MA-PWR-USB-EU
MA-PWR-USB-AU
Note: Each Meraki MT sensor requires a license to operate, however every dashboard organization comes standard with five free MT licenses to get started.
In the Box
Unit MT15-HW
Guides QIGs
Mounting equipment Backplate, 2 mounting screws, 2 drywall anchors
  • Was this article helpful?
