Z3 Installation Guide
Please note that this document has been deprecated in favor of the following replacement document: https://documentation.meraki.com/Mer...allation_Guide
This document describes how to install and set up the Z3 teleworker gateway. Additional reference documents are available online at: www.meraki.com/library/products.
Z3 Overview
The Meraki Z3 is 802.11a/b/g/n/ac Wireless Security Appliance designed for telecommuting employees and IT staff. It is also a great all-in-one device to test the capabilities of Meraki's cloud-managed networking. This gateway provides the following features:
  • Support for four LAN connections
  • Dual-concurrent 802.11ac radios for wireless connections
  • Wall screws and anchors for mounting to a drywall surface, either vertically or horizontally
Package contents
In addition to the Z3, the following are provided.
Image of accessories contained in box shipped to the customer. Image shows a power adapter, CAT 5 ethernet cable, wall screws and anchors.
The Z3 Front Panel
Image of the front panel of the Z3 unit. Image shows a rectangular device, with a LED indicator on the left-hand side corner.
Status Indicator
The Z3 uses a single LED to inform the user of the device's status.
LED Status
Meaning
Solid orange
Power is applied but the appliance is not connected to the Meraki Dashboard
Rainbow Colors The appliance is attempting to connect to Meraki Dashboard
Flashing White
Firmware upgrade in progress
Solid White
Fully operational
The Z3 Back Panel
Image of back panel of the Z3 device. Image shows a rectangular box with the USB port, followed by a pin hole used for the reset to the far left, five ethernet ports and finally, the power inlet.
Additional functions on the back panel are described below, from left to right.
USB port
USB 3.0 for 3G/4G wireless cards. Traffic status is indicated by the USB LED.
Reset button
Insert a paper clip if a reset is required.
  • Press for 1 second to delete a downloaded configuration and reboot.
  • Press and hold for more than 10 seconds to force a full factory reset.
WAN / Internet port [Far left Ethernet port] This port provides connectivity to the WAN.
LAN ports
These 4 ports provide connectivity to computers, printers, access points, or Ethernet switches.
A steady green LED indicates bidirectional connectivity, and flashing green indicates traffic.
PoE Port
[Far right Ethernet port] One of the LAN port provides PoE for connectivity to computers, printers, access points, or Ethernet switches, up to 15W of PoE power.
Power input Designed for use only with the unit’s power supply.
The Z3 Bottom Panel
Image of the bottom panel of the Z3 unit showing the mounting bracket and the available notches.
Please note that the serial number is located on the product label on the bottom panel of the Z3
Mounting Hardware
The supplied wall screws and anchors allow you to mount the gateway on a drywall surface, either vertically or horizontally.
  • For mounting on drywall, use a ¼-in drill bit, then insert the plastic and screw assemblies.
  • For mounting on wood or a similar surface, use only the screws.
  • Allow the heads of the screws to stick out far enough to be inserted securely into the back of the gateway.
Connecting to WAN
Note: Z3 has One dedicated WAN/Internet port and does not support a secondary WAN port by toggling a LAN port.
All Meraki Z3 devices must have an IP address. This section describes how to configure your local area network before you deploy it. A local management web service, running on the gateway, is accessed through a browser running on a client PC. This web service is used for configuring and monitoring basic ISP/WAN connectivity.
Setting up a Static IP Address
Note: To ensure that the client PC is redirected to the local web service in the following step, you must disable all other network services (ex: Wi-Fi) on your client machine.
Do the following to configure basic connectivity and other networking parameters:
  1. Using a client machine such as a laptop, connect to one of the four LAN ports of the Z3.
  2. Using a browser on the client machine, access the gateway's built-in web service by browsing to http://setup.meraki.com. (You do not have to be connected to the Internet to reach this address)
  3. Click Uplink configuration under the Local status tab. The default credentials use the device serial number as the username, with a blank password field.
  4. Choose Static for the IP Assignment option.
  5. Enter the IP address, subnet mask, default gateway IP and DNS server information.
Setting up a DHCP IP Address
By default, all Z3 devices are configured to DHCP from upstream WAN / ISP servers. Simply plug the Z3's WAN / Internet port to your upstream circuit and wait a few minutes for the unit to negotiate a DHCP address. If your Z3 device was configured to have a static address (and not attempt to negotiate DHCP), you can hold the reset button while the device is powered until the lights on the device turn off. Doing so will return the Z3 device to its default DHCP settings.
Note: When the WAN connection is fully enabled, the device's front LED will be solid white.
Additional Settings
Setting VLANs
If your WAN uplink is on a trunk port, choose VLAN tagging > Use VLAN tagging and enter the appropriate value for VLAN ID for your network.
Setting PPPoE
PPPoE authentication may be required if you are connecting Z3 device to a DSL circuit. You need to know your authentication option and credentials (supplied by your ISP) in order to complete these steps.
  • Choose Connection Type > PPPoE.
  • Select your Authentication option.
  • If you select Use authentication, enter appropriate values for Username and Password.
Web Proxy Settings
These settings take effect if the Z3 device has to fall back to using HTTP to contact the Cloud Controller. By default, web proxy is disabled. To enable web proxy, do the following:
  • Choose Web proxy > Yes.
  • Enter values as appropriate for Hostname or IP and Port.
  • If you require authentication, choose Authentication > Use authentication, and enter appropriate values for Username and Password.
To apply all configuration settings to the gateway, be sure to click Save Settings at the bottom of the page.
Configuring Physical Link Settings
To configure physical link settings on the Ethernet ports, click Local status > Ethernet configuration. You can enable half duplex, full duplex, and autonegotiation, as well as set 10- or 100-Mbps data rates.
Power Efficiency Modes
The Meraki Z3 Teleworker Appliance has an off mode and a networked standby or efficient idle mode, both with power consumption less than 12W.
In off mode, the power consumption is a measured 0.3W. In the networked standby or efficient idle mode, the power consumption is under that of full operation mode, which is a measured 6.6W. This mode is initiated after treating the last payload packets.
To activate and/or deactivate wireless network ports, you may use the physical on/off switch or deactivate through the Meraki Dashboard.
  • Was this article helpful?
