Configuring Cisco 2811 router for Site-to-site VPN with MX Series Appliance using the Command Line Interface
This article will outline the process for configuring a Site-to-site VPN between a MX Security Appliance and a Cisco 2800 series router using the command line interface.
The diagram below shows the connection between the 2 sites participating in the site to site VPN
Configuration
  • Configure the MX side as explained here
  • Configure the Cisco 2811 router as shown below
1b01e704-c732-4b33-bbdd-2d79ddbdd831
Configure ISKAMP Policy
   crypto isakmp policy 10
   encr 3des
   authentication pre-share
   hash sha
   lifetime 28800
   group 2
Configure IPsec Transform Set
  crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
Specifies the interesting traffic to be encrypted
   ip access-list extended outgoing_to_MX
   permit ip 192.168.10.0 0.0.0.255 192.168.11.0 0.0.0.255
Specifies the pre-shared key "secretkey" which should be identical at both peers
  crypto isakmp key secretkey address 1.1.1.1
Configure the Ipsec-isakmp
  crypto map 2800-isakmp 1 ipsec-isakmp
  set peer 1.1.1.1
  set transform-set ESP-3DES-SHA
  match address outgoing_to_MX
Apply the Ipsec-isakmp to interface
  interface FastEthernet0/1
  ip address 2.2.2.2 255.255.255.248
  ip nat outside
  duplex auto
  speed auto
Once the MX and the ASA are successfully configured, the network configured for VPN access will be able to access each other's resources. To initialize the VPN tunnel, it is necessary to generate interesting traffic and send it to the VPN peer. This can be done by initiating a ping across the tunnel.
Troubleshooting 3rd party VPN on MX can be found here
  • Was this article helpful?
