C8455-G2-MX Data Sheet
Overview
The Meraki C8455-G2-MX a Cisco Secure Router that provides Security and SD-WAN, firewall services for large campus environments, and VPN concentration for large VPN networks. Network administrators can deploy it easily and quickly using the Meraki dashboard, with minimal pre-configuration required in most locations.
The C8455-G2-MX includes 2x 25G SFP28 WAN Interfaces, 2x 10G SFP+ LAN Interfaces, and 8x SFP 1GbE dedicated LAN interfaces. The C8455-G2-MX is ready for deployment in a variety of enterprise environments. C8455-G2-MX appliances provides the following features:
Image showing the Meraki C8455-G2-MX Security & SD-WAN Appliance, highlighting its advanced routing, firewall, and VPN features for large campus networks.
Throughput and Capabilities
  C8455-G2-MX
Maximum NGFW Throughput 20 Gbps
Maximum Site-to-Site VPN Throughput 10 Gbps
Advanced Security Throughput 8 Gbps
Recommended Device Count 15,000
Maximum Recommended Tunnels 3,500
Recommended Use Case Large Campus & VPN Concentrator
Technical Breakdown
Interfaces
WAN
  • 2x SFP28 / 25 Gigabit Ethernet WAN Port
  • 2x SFP+ 10 Gigabit Ethernet
  • 8x SFP / 1 Gigabit Ethernet LAN Ports
  • 1x RJ45 Console Port
  • 1x RJ45 Management Interface
Physical
Mount Type
Rack mount (19" included)
Dimensions
(h x w x d)
1.73 in x 17.50 in x 12 in
Weight
12.5 lbs
Input operating voltage
85 to 264 Vac
47 to 63 Hz
Power Supply Unit
2 x 250W AC are included by default
Operating temperature
32° to 104°F
(0° to 40°C)
Humidity
10 to 85% non-condensing
Accessories
Accessory Description
MA-PWR-CORD-US 1x AC power cable, U.S. plug
MA-PWR-CORD-EU
1x AC power cable, EU plug
MA-PWR-CORD-UK
1x AC power cable, UK plug
MA-PWR-CORD-AU
1x AC power cable, AU plug
MA-PWR-CORD-BR
1X AC power cable, BR plug
Compatible Fiber Transceiver Modules
The following SFP modules are supported on the C8455-G2-MX:
SFP28/ SFP+/ SFP Module 25Gbps ports 10Gbps ports 1Gbps ports
SFP-25G-SR-S
Supported
SFP-10/25G-CSR-S
Supported
SFP-10/25G-LR-S
Supported
MA-SFP-10GB-SR
Supported
Supported
MA-SFP-10GB-LR
Supported
Supported
MA-SFP-10GB-LRM
Supported
Supported
MA-SFP-10GB-ER
Supported
Supported
MA-SFP-1GB-TX   Supported Supported
MA-SFP-1GB-LX10
Supported
Supported
Compatible SFP and Twinax Cables
SFP28/ SFP+/ SFP Cable 25Gbps ports 10Gbps ports 1Gbps ports
SFP-H25G-CU1M/3M/5M
Supported
SFP-25G-AOC1M/3M/5M
Supported
MA-CBL-TA-1M
Supported
Supported
MA-CBL-TA-3M
Supported
Supported
Warranty
MX Warranty coverage periods are as follows:
Product Warranty Period Warranty Information
C8455-G2-MX 2 Year Cisco 8400 Series Secure Routers come standard with a Cisco Limited 2-Year Return To Factory Hardware Warranty.
Additional warranty information can be found on the Cisco Limited Hardware Warranty Terms page of the Cisco website.
If your Cisco Meraki device fails and the problem cannot be resolved by troubleshooting, contact support to address the issue. Once support determines that the device is in a failed state, they can process an RMA and send out a replacement device free of charge. In most circumstances, the RMA will include a pre-paid shipping label so the faulty equipment can be returned.
To start a hardware replacement for non-functioning equipment under warranty, use the original packaging the hardware came in. The original packaging contains the device serial number and order details, which may be needed for return shipping.
Troubleshooting
Common Event Log Messages
Common event logs exist for security appliance events. As such, no specific C8455-G2-MX event log entries are required at this time.
For more general information about navigating the Event Log and the types of Events that could be expected refer to Event Log documentation
