MX75 Datasheet
Overview
The Meraki MX75 is an enterprise security appliance designed for distributed deployments that require remote administration across Medium branch environments. It is ideal for network administrators who demand both ease of deployment and a state-of-the-art feature set. The Meraki Dashboard allows for simple and easy deployment of the MX75 with minimal pre-configuration in almost any location.
Providing 3 dedicated WAN uplinks, 1 x GbE SFP port and 2 x RJ45 GbE ports. The LAN ports include 10 x RJ45 GbE ports. The MX75 is ready for deployment in a variety of enterprise environments. The MX75 appliance provides the following features:
Image of a MX75 front panel showing the USB port, three internet ports and nine ethernet ports, including two PoE ports.
Features
  • Managed via Cisco Meraki Dashboard
  • Automatic Firmware upgrades
  • WAN Link Balancing
  • Automatic WAN Failover
  • SD-WAN over Meraki AutoVPN
  • L3/L7 Stateful Firewall
  • Geo based firewall rules
  • 1:1 and 1:Many NAT
  • Configurable VLANs / DHCP support
  • Static Routing
  • Client VPN endpoint
  • Meraki AutoVPN and L2TP/IPSec VPN endpoint
  • Active Directory integration
  • Content Filtering
  • Malware Protection (AMP) w/ optional Threat Grid integration
  • IDS/IPS protection
  • Custom Traffic Shaping
  • Historical Client Usage statistics
  • Netflow support
  • Syslog integration
  • Remote Packet Capture tools
Interfaces
  • 1 x 1 Gigabit Ethernet SFP port dedicated for the WAN uplinks
  • 2 x RJ45 / 1 Gigabit Ethernet port dedicated for the WAN uplinks
  • 8 x RJ45 / 1 Gigabit Ethernet LAN ports
  • 2 x RJ45 / 1 Gigabit Ethernet LAN ports with PoE+ capabilities
  • 1 x USB 3.0 port
Technical Breakdown
WAN Interface
  MX75 MX85
WAN Interfaces 1 x Dedicated 1 Gigabit Ethernet SFP
2 x Dedicated 1 Gigabit Ethernet RJ45
2x Dedicated 1 Gigabit Ethernet SFP
2x Dedicated 1 Gigabit Ethernet RJ45
# of WAN Uplinks 3 4
Note: The MX firmware currently supports a maximum of two Active WAN Uplinks. For more information about the interface behaviors, please refer to our WAN behavior on MX75/85/95/105 documentation and MultiWAN_Backup_Uplink.
LAN Interface
MX75 MX85
10 x Dedicated 1 Gigabit Ethernet RJ45 8 x Dedicated 1 Gigabit Ethernet RJ45
2 x Dedicated 1 Gigabit Ethernet SFP
Throughput and Capabilities
  MX75
Recommended Device Count Small branch with up to 200 devices
Max site-to-site VPN Throughput 1 Gbps
Max Concurrent site-to-site VPN Tunnels 75
Max Stateful Firewall Throughput 1 Gbps
Max Next Generation Firewall (Detection) Throughput     1 Gbps
Physical
  MX75 MX85
Mount Type Desktop Rack Mount
Dimensions
(h x d x w)
1.06" x 5.83" x 11.14"
27 x 148 x 283 mm
1.7" x 9.8“ x 19”
43.8 x 250 x 484.6mm
Weight 1.87 lb (0.85kg) 8.2lb (3.7kg)
Input Operating Voltage
90-264VAC
(47-63Hz)
90-264VAC
(47-63Hz)
PSU Model Number MA-PWR-100WAC-A N/A
Power Load (idle/max) 12W / 96W 12W / 55W
Fan Yes No
Operating Temperature
32°F to 113°F
(0°C to 45°C)
32°F to 104°F
(0°C to 40°C)
Humidity 5% to 95% 5% to 95%
Accessories
Accessory Description
MA-PWR-100WAC-A Meraki MX Replacement Power Adapter (100 Watts AC)
MA-PWR-CORD-US 1x AC Power Cable, US plug
MA-PWR-CORD-EU 1x AC Power Cable, EU plug
MA-PWR-CORD-UK 1x AC Power Cable, UK plug
MA-PWR-CORD-AU 1x AC Power Cable, AU plug
Compatible Fiber Transceiver Modules
Product ID Fiber Type
MA-SFP-1GB-SX Multi-Mode Fiber (MMF)
MA-SFP-1GB-LX10 Single-Mode Fiber (SMF)
MA-SFP-1GB-TX N/A (RJ45 Copper SFP)
Note: Please refer to the Meraki SFP Datasheet for additional information about the single-mode and multi-mode fiber transceiver modules
Troubleshooting
Common Event Log Messages
Common event logs exist for wired events. As such, no specific MX75 event log entries are required at this time.
For more general information about navigating the Event Log and the types of Events that could be expected please check out our Event Log documentation.
Warranty
MX Warranty coverage periods are as follows:
Product
Warranty Period
Warranty Information
MX75
Lifetime
Full lifetime hardware warranty with next-day advanced replacement included.
MX75 Accessories
1 Year
The following are considered accessories:
SFP Modules, all mounting kits and stands, interface modules, additional power cords
Additional warranty information can be found on the Return Policy and Requesting a RMA page of the Cisco Meraki website.
If your Cisco Meraki device fails and the problem cannot be resolved by troubleshooting, contact support to address the issue. Once support determines that the device is in a failed state, they can process an RMA and send out a replacement device free of charge. In most circumstances, the RMA will include a pre-paid shipping label so the faulty equipment can be returned.
In order to initiate a hardware replacement for non-functioning hardware that is under warranty, you must have access to the original packaging the hardware was shipped in. The original hardware packaging includes device serial number and order information, and may be required for return shipping.
Meraki MX75 devices have been tested and found to comply with the limits for a Class A digital device, pursuant to part 15 of the FCC rules. A digital device that is marketed for use in a residential environment notwithstanding use in commercial, business and industrial environments.
  • Was this article helpful?
