MX84 Datasheet
By Jonathan Roszkowski
Note - The MX18.1 firmware release will be the maximum running build for MX64, MX64W, MX65, MX65W, MX84, MX100, and vMX100 platforms. These platforms will not run MX 18.2 and above firmware builds. We recommend you stay up to date with all the latest features with the next-generation hardware platforms. Please consult your sales representative for more information on the latest hardware and software releases. Thank you
Overview
The Meraki MX84 is an enterprise security appliance designed for distributed deployments that require remote administration across Medium branch environments. It is ideal for network administrators who demand both ease of deployment and a state-of-the-art feature set. The Meraki Dashboard allows for simple and easy deployment of the MX84 with minimal pre-configuration in almost any location. Providing 2 dedicated WAN uplinks, 8 GbE RJ45 ports, and 2 SFP ports, the MX84 is ready for deployment in a variety of enterprise environments.
MX84 front panel image
Features
  • Managed via the Cisco Meraki Dashboard
  • Automatic Firmware upgrades
  • WAN Link Balancing
  • Automatic WAN Failover
  • SD-WAN over Meraki AutoVPN
  • L3/L7 Stateful Firewall
  • Geo-based firewall rules
  • 1:1 and 1:Many NAT
  • Configurable VLANs / DHCP support
  • Static Routing
  • Client VPN endpoint
  • Meraki AutoVPN and L2TP/IPSec VPN endpoint
  • Active Directory integration
  • Content Filtering
  • Malware Protection (AMP) w/ optional Threat Grid integration
  • IDS/IPS protection
  • Custom Traffic Shaping
  • Historical Client Usage statistics
  • Netflow support
  • Syslog integration
  • Remote Packet Capture tools
Hardware Features
  • Dual Dedicated WAN uplinks
  • A built-in USB port for failover cellular support
  • 2 SFP ports
Configuration
The basic initial configuration of the MX84 is just as simple as any other MX models. The links below provide additional information and instructions relating to each step in getting the device setup and configured for the first time.
  1. Claim the device to an Organization on the Meraki Dashboard
    1. If a Dashboard Organization does not yet exist, Create one
  2. Add the device to a Dashboard Network
    1. If a Network does not yet exist, Create one first
  3. Physically connect the device to the local network
    1. Ensure the wireless antennas are connected correctly (Wireless models only)
    2. Power on the device and let it check in to the Dashboard
    3. If necessary, configure a Static IP on the WAN interface through the Local Status Page to allow it to check in.
  4. Finish configuring the device from the Meraki Dashboard
    1. Manage local VLANs
    2. Modify Firewall rules
    3. Configure VPN connectivity
Context and Comparisons
Description MX65 MX84
Dual WAN Uplinks Yes Yes
Backup Cellular Uplink Via 3rd Party USB Modem Via 3rd Party USB Modem
Stateful Firewall Throughput 250 Mbps 500 Mbps
Maximum VPN Throughput 100 Mbps 250 Mbps
Advanced Security Throughput 200 Mbps 320 Mbps
Maximum Concurrent VPN Tunnels 50 100
PoE Capabilities  Yes, 2x GbE RJ45 LAN Ports -
Recommended Device Count 50 200
Technical Breakdown
Physical Interfaces
WAN interface 2x Dedicated GbE RJ45
Cellular interface 1x Cellular uplink via 3rd party USB Modem
LAN Interface 8x Dedicated GbE RJ45 ports, 2x Dedicated GbE SFP ports
Management Interface 1x Dedicated management port.
Throughput and Capabilities
Description MX84
Recommended Device Count 200
Max Stateful Firewall Throughput in NAT mode 500 Mbps
Max VPN Throughput 250 Mbps
Max Concurrent VPN Tunnels (Site-to-Site or Client VPN)
100
Physical
Description MX84
Mount Type 1U Rack
Dimensions
(h x d x w)
 1.75in x 10in x 19in
 (44mm x 254mm x 483mm)
Weight 9 lb (4.1kg)
Power Supply Internal 100-220V
Power Load (idle/max) 26W / 32W
Operating Temperature
32°F - 104 °F
0°C - 40°C
Humidity 5% to 95%
Accessories
Accessory Description
MA-SFP-1GB-SX Cisco Meraki 1 GbE SFP SX Fiber Module (1000BASE-SX, range: 550m)
MA-SFP-1GB-TX Cisco Meraki 1 GbE RJ45 Copper Module (1000BASE-T for twisted pair)
MA-PWR-CORD-US 1x AC Power Cable, US plug
MA-PWR-CORD-EU 1x AC Power Cable, EU plug
MA-PWR-CORD-UK 1x AC Power Cable, UK plug
MA-PWR-CORD-AU 1x AC Power Cable, AU plug
Warranty
MX Warranty coverage periods are as follows:
Product
Warranty Period
Warranty Information
MX84
Lifetime
Full lifetime hardware warranty with next-day advanced replacement included.
MX84 Accessories
1 Year
The following are considered accessories:
SFP Modules, all mounting kits and stands, interface modules, additional power cords
Additional warranty information can be found on the Return Policy and Requesting an RMA page of the Cisco Meraki website.
If your Cisco Meraki device fails and the problem cannot be resolved by troubleshooting, contact support to address the issue. Once support determines that the device is in a failed state, they can process an RMA and send out a replacement device free of charge. In most circumstances, the RMA will include a pre-paid shipping label so the faulty equipment can be returned.
In order to initiate a hardware replacement for non-functioning hardware that is under warranty, you must have access to the original packaging the hardware was shipped in. The original hardware packaging includes device serial number and order information, and may be required for return shipping.
Common Event Log Messages
There are currently no MX84 specific Event Log entries, for more general information about navigating the Event Log and the types of Events that could be expected please check out our Event Log documentation.
  • Was this article helpful?
