BGP routing over IPsec VPN
Click 日本語 for Japanese
BGP Routing over IPsec VPN
BGP peering over IPsec VPN tunnels can be enabled on the Meraki Security Appliance. This unlocks new dynamic routing solutions, including routing between AutoVPN and IPsec VPN peers, in addition to enabling resiliency and redundancy over IPsec VPN peers.
Configuring eBGP over IPsec
Prerequisites
IKEv2 in use
MX 19.1.4 or newer release
MX and Z4/C platforms that support MX 19.1 firmware and above
BGP - TCP port 179 permitted on your VPN firewall
BGP enabled
BGP Multi-hop enabled on BGP neighbor. Multi-hop is not required on 19.2 and above
IPsec VPN peer must support route-based VPN
- BGP is not supported for template networks.
Add IPsec VPN Peer
When you add an IPsec VPN peer, under Routing you have - Static and Dynamic. With Dynamic selected, you can view the following configuration options:
After a BGP over IPsec peer is configured, the details will appear on the Security & SD-WAN > Routing page. The peer will show up grayed out and can only be removed by deleting it via the Site-to-Site VPN page where it was added.
Verifying Connectivity
An IPsec tunnel is formed before the eBGP peering relationship is formed. Hence, to verify BGP neighborship, first verify that the IPsec tunnel is up. We can verify by navigating to Security & SD-WAN > VPN Status – Non Meraki VPN tab.
Here we can see the status of the IPsec tunnel.
VPN status indicator |
Meaning |
Green |
Phase 1 and phase 2 are up. |
Amber |
Phase 1 is up but phase 2 is down |
Red |
Phase 1 and phase 2 are both down. |
A green indicator means the IPsec tunnel is up.
Navigate to the Dynamic Protocol Status page to check if the eBGP peering with the remote peer is up. An Established peer status means the BGP neighbor relationship is active. The “Routes” column shows how many routes have been learned from the BGP neighbor.
Ensure that TCP port 179 (BGP) is configured to be allowed in the Site-to-Site outbound firewall rules if other deny rules are configured.
The exact routes learned can be viewed on the Security & SD-WAN > Monitor > Route Table page.
Note: Statically defined local routes configured on passthrough MX devices are not exported to the eBGP peer over IPsec
