EAP-TLS Client Configuration
This article provides instructions on configuring Windows 10, Apple macOS, and Apple iOS client devices for certificate-based authentication (EAP-TLS) and obtaining authorization such as VLAN, Group Policy, Adaptive Policy, etc. based on Access Manager rules.
The instructions in this article are intended as a reference to assist organizations in understanding the network settings, which can be useful when configuring network settings through a unified endpoint manager (UEM) or Meraki Group Policy (GP) update.
Refer to EAP-TLS Certificate-based Authentication with Entra ID Lookup to view instructions on how to configure Entra ID integration, wired/wireless networks and Access Manager rules.
Download RADIUS CA Certificate From Access Manager
Download Access Manager's Root Certificate Authority certificate for installation on the endpoints' Trusted Certificate Authority (CA) certificate store:
- Navigate to Access Manager > Configure > Certificates
- Click on Download RADIUS CA certificates
- This downloads a ZIP file, RADIUS-CA-certificates.zip, to your computer
- Unzip RADIUS-CA-certificates.zip to see two files that will need to be deployed to your endpoints to trust Access Manager for establishing secure EAP tunnels:
| Filename | Description |
| Access-Manager-Root-CA.cer | The Access Manager certificate (eap.meraki.com) chain |
| Readme.txt | Instructions for using the certificate |
Microsoft Windows 10/11
Root Certificate Installation
| 1. Open the downloaded RADIUS certificate from previous step and click open again |
| 2. Select Install Certificate to install the IdenTrust Commercial Root CA 1 certificate. | ![]() |
| 3. Select Next > Next > Finish to continue installing certificate successfully |
Enable Windows Wired AutoConfig Service
1. In your Windows client, navigate to the System Services Control Panel. |
| 2. Scroll down to the Wired AutoConfig service and ensure the Status is Running by selecting Start | ![]() |
Assign Trusted CA Certificate to an SSID
Manually define which SSID(s) you want to trust with the installed CA certificate.
| 1. In windows, navigate to the Network and Sharing Center > click on Set up a new connection or network | ![]() |
| 2. Choose Manually connect to a wireless network and click Next | ![]() |
| 3. Enter the Network name that exactly matches the SSID configured for this use case, and choose WPA2-Enterprise as the security type. Click Next. | ![]() |
| 4. Your network is successfully created. Click on Change connection settings | ![]() |
| 5. Click on Security > choose Microsoft: Smart Card or other certificate as the authentication method > click on Settings | ![]() |
6. Choose the following selections then select OK:
7. Click Ok again on the main properties window
8. The windows client is now successfully configured to connect to the wireless network using a certificate (EAP-TLS).
Apple macOS
| 1. In macOS, open Keychain Access > Click on File > Import items > select the downloaded RADIUS CA certificate and click open | ![]() |
| 2. Find the installed certificate (IdenTrust Commercial Root CA 1) from the list and open it > select Always Trust and close the window | ![]() |
Provision the Certificate with Apple Configurator
For Apple macOS, you will need to download, install, and open the Apple Configurator application from the App Store.
| 1. Click on File > New Profile | |
| 2. Enter the Name and Identifier for the profile | ![]() |
| 3. Click on Certificates > Configure > Select downloaded RADIUS CA certificate and click Open | ![]() ![]() |
| 4. Click on + icon > Select Endpoint/User Certificate to be used for this authentication | ![]() |
5. Click on Wi-Fi and set the following values:
6. Select Trust under Enterprise Settings and set these values:
| 7. Click File > Save | |
| 8. Open the saved profile - this action will download the profile | |
| 9. Navigate to Settings > Device Management > Double click on the profile > Install | ![]() ![]() |
| 10. Click Install | ![]() |
The macOS client is now successfully configured to connect to the wireless network using a certificate (EAP-TLS).
Apple iOS
- On iOS, follow the same steps from macOS section:
- Copy the downloaded RADIUS CA certificate to iPhone and click open
- Navigate to Settings > Profile downloaded
- Click Install > Install again > Done
- Copy the Profile created on Apple Configurator in the macOS section to iPhone and click open
- Click Install > Install > Done
- The iOS client is now successfully configured to connect to the wireless network using a certificate (EAP-TLS).
Android
- Copy the downloaded RADIUS CA certificate to the Android device.
- Open up Settings>Security & Privacy>More security & privacy>Encryption & credentials>Install a Certificate , select CA certificate, then click Install anyway:
- Go to Settings>Network & internet and select SSID for authentication:
- Settings for EAP-TLS should configured as below:
- EAP Method - TLS
- CA certificate - Use system certificates
- TLS Version - TLS v1.2 or greater
- Domain - eap.meraki.com
- CA Certificate - your installed certificate
- Identity - Can be any string
EAP-TLS also requires a client certificate to be installed on the end device as well.
- Navigate to Settings>Security & Privacy>More security & privacy>Encryption & credentials>Install a Certificate , select WiFi certificate.
- Choose your certificate from storage - most likely Google Drive. Needs to be a *.pfx or *.p12 certificate file.
- Note: You will want to sync any certs on cloud storage to the device before connecting with the certificate!
- Enter the private key password.
- You can choose to give the certificate a friendly name.
The Android client is now successfully configured to connect to the wireless network using a certificate (EAP-TLS).
Chromebook
- To install client certificate, open Chrome, and type chrome://settings/certificates on the browser or open Settings > Security and Privacy and click certificates.
- Click on import and bind
- Select your .p12 or .pfx file and click open.
- Enter the certificate password and click on OK. On the certificate Manager, it will show the selected client certificate.
- Click on local certificates to install/Import the CA certificates.
- Click on import under Trusted Certificates.
- Select the downloaded Radius CA certificates and click on Open. On the Certificate Manager window, you will see the Root CA certificate.
- To Configure SSID for EAP-TLS, go to Settings > Network > WiFi and select SSID for authentication.
- Setting for EAP-TLS should configure as below
- EAP Method: TLS
- Server CA certificate: Downloaded CA certificates previously.
-User Certificate: select the one installed previously.
- Click on Save.
