EAP-TTLS Client Configuration
This article provides instructions on configuring Microsoft Windows 10/11, Apple macOS, and Apple iOS client devices to authenticate against Microsoft Entra ID using username and password (EAP-TTLS+PAP) and obtain authorization (such as SGT, VLAN, Group Policy, etc.) based on Access Manager rules.
The instructions in this article are intended as a reference to assist organizations in understanding the network settings, which can be useful when configuring network settings through an MDM or Group Policy (GP) update.
Please refer to Securing Managed Endpoints - Username/Password Authentication against Entra ID to view instructions on how to configure Entra ID integration, wired/wireless networks and Access Manager rules.
Download RADIUS CA Certificate From Access Manager
In EAP-TTLS/PAP flows,  Access Manager presents its certificate during authentication, enabling the client to validate it before connecting. It is recommended to install the root CA certificate that signed the Access Manager certificate on your endpoints to ensure the Access Manager certificate is trusted automatically, without requiring user intervention.
Download Access Manager's RADIUS CA certificate for installation on the endpoints' Trusted Certificate Authority (CA) certificate store:
  1. Navigate to Access Manager > Configure > Certificates
  2. Select Download RADIUS CA certificates
  3. This downloads a ZIP file, RADIUS-CA-certificates.zip, to your computer
  4. Unzip RADIUS-CA-certificates.zip to see two files:
    Access-Manager-Root-CA.cer
    Readme.txt
Root Certificate Installation
Open the downloaded RADIUS certificate from previous step and select open again cert install.png
Select Next > Next > Finish to continue installing certificate successfully
Assign Trusted CA Certificate to an SSID
In windows, navigate to the Network and Sharing Center
Select Set up a new connection or network
Choose Manually connect to a wireless network.
Select Next.
Enter the Network name that exactly matches the SSID configured for this use case.
Choose WPA2-Enterprise as the security type.
Select Next.
Your network is successfully created.
Select Change connection settings
Select Security
Choose Microsoft: EAP-TTLS as the authentication method
Select Settings
Make sure following selections are made:
  • Enable identity privacy is checked (to ensure the true username is not shared in the initial EAP exchange)
  • Connect to these servers:
    • eap.meraki.com ensures the client only connects to RADIUS servers with the Common Name (CN) 'eap.meraki.com' signed by one of the Trusted Root Certificate Authorities - not a rogue device advertising the same SSID
  • Trusted Root Certificate Authorities: Identity Trust Commercial Root CA 1 - this is the Access Manager root CA installed in the previous step
  • Select a non-EAP method for authentication: Choose Unencrypted password (PAP). Please note that while the password is unencrypted, it is transmitted over an encrypted TLS tunnel.
  • Select OK
The windows client is now successfully configured to connect to the wireless network using a username and password (EAP-TTLS+PAP).
Apple macOS
  1. In Apple macOS, open Keychain Access
  2. Select File > Import items... and  select the RADIUS CA certificate downloaded from Access Manager
  3. Select Open
  1. Find the installed certificate (IdenTrust Commercial Root CA 1) from the list
  2. Open it and select Always Trust
  3. Close the window
Provision the Certificate with Apple Configurator
For Apple macOS, you will need to download, install, and open the Apple Configurator application from the App Store.
In macOS, open Apple Configurator application (you will need to download it from the App Store if you do not already have it)
Select File > New Profile
Select Certificates > Configure
Select downloaded RADIUS CA certificate and Open it
Click on Wi-Fi and use the following values:
  • Service Set Identifier (SSID): SSID that exactly matches the SSID configured for this use case
  • Security Type: WPA2/WPA3 Enterprise
  • Accepted EAP Types: TTLS
  • Inner Authentication: PAP
Select Trust under Enterprise Settings and Set the following values
  • Trusted Certificates: Choose the certificate that was added in Certificates tab - Identity Trust Commercial Root CA 1
  • Trusted Server Certificate Names: Add eap.meraki.com
    to ensure the client only connects to Meraki's server and no other rogue device advertising an SSID.
Select File > Save
Open the saved profile - this action will download the profile
Navigate to Settings > Device Management
Select (double-click) the downloaded profile
Select Install ...
The macOS client is now successfully configured to connect to the wireless network using a username and password (EAP-TTLS+PAP).
Apple iOS
On Apple iOS, follow the same steps from macOS section:
  1. Copy the downloaded RADIUS CA certificate to iPhone and click open
  2. Navigate to Settings > Profile downloaded
  3. Click Install > Install again > Done
  4. Copy the Profile created on Apple Configurator in the macOS section to iPhone and click open
  5. Navigate to Settings > Profile downloaded
  6. Click Install > Install > Install > Done
  7. The iOS client is now successfully configured to connect to the wireless network using a username and password (EAP-TTLS/PAP).
Android
  1. Copy the downloaded RADIUS CA certificate to Android device.
  2. Open up Settings>Security & Privacy>More security & privacy>Encryption & credentials>Install a Certificate , select CA certificate, then click Install anyway::
    Step 1 - Android TTLS - Access Manager     Step 1.a - Android TTLS - Access Manager     Step 1.b - Android TTLS - Access Manager
  3. Go to Settings>Network & internet and select the SSID for authentication:
    Step 3 - Android TTLS - Access Manager
  4. Setup should be the below
    • EAP Method - PAP
    • CA certificate - Use system certificates
    • TLS Version - TLS v1.2 or greater
    • Domain - eap.meraki.com
    • Identity - Enter RADIUS username and password
      Step 4 - Android TTLS - Access Manager
  5. The Android client is now successfully configured to connect to the wireless network using a username and password (EAP-TTLS/PAP).
