Integrating Cisco Umbrella or Secure Access with Meraki Networks
Overview
Integrating the Meraki dashboard and Umbrella or Secure Access DNS allows clients connected behind Meraki security appliances or access points to have their DNS traffic filtered through Cisco's SSE DNS service.
This integration allows administrators to apply and modify DNS-based filtering rules to multiple groups of clients on their network by assigning a filtering policy to a specific Meraki group policy or SSID. Once assigned, all DNS requests from clients included under that policy will be automatically redirected to Cisco's SSE DNS service where it will be checked against the appropriate policy configured for the network device in the Umbrella or Secure Access dashboard.
Note: This document was original written for DNS integration with Umbrella. At later time we have extended this to Secure Access services as well. In the document you will find reference to Umbrella, but note that the process to connect and configuration to Secure Access is identical unless otherwise specified in the document.
Note: This feature is not supported for MX or Z-series devices running in passthrough mode.
umbrella overview dual box2 scaled
Firmware Requirements
  • MX Platform requires MX firmware version 15.10+.
  • MR Platform requires MR firmware version 26.1+.
  • MX Platform connecting to Secure Access should run firmware version 19.2+
Licensing Requirements
  • MX Platform
    • This feature is available for an MX with Advanced Security license
    • Z3 with an Enterprise license (as Z3 does not support Advanced Security license).
  • MR Platform
    • Manual Integration: Enterprise License
    • Automatic Integration: Advanced licenses
  • **An existing license to use Cisco Umbrella
Configuring SSE DNS Integration
This integration is mutually exclusive with Automatic Umbrella integration on MR, which requires MR Advanced licenses. If you wish to use the manual MX or MR Umbrella integration in your Meraki organization, please follow the steps below before claiming any MR Advanced or MR Upgrade licenses in your organization or adding the organization to your Enterprise Agreement.
Linking the Meraki and Umbrella Dashboards
Integrating Umbrella DNS with a Meraki network is a simple process that requires only a few steps. For Umbrella filtering policies to be applied successfully, the Meraki and Umbrella dashboards must first be linked via the Umbrella network devices API key. Once the dashboards have been linked, the Umbrella policies can be properly assigned to the appropriate Meraki SSID or group policy.
Follow the same steps when integrating with Secure Access. The only difference is the scope of the API key. For Secure Access DNS integration create secure Access API key with scope of:
  • Admin/Organizations : Read/Write  AND
  • Deployments/ Network Devices: Read/Write
  • Deployments/Policies : Read/Write (Required for enabling DNS under group policy. If group policies are not used this scope element can be  omitted. )
It is recommend to run firmware 19.2+ when connecting to Secure Access.
Generate the Umbrella API Key
Before linking the two dashboards, the Umbrella API key and associated secret must first be created on the Umbrella dashboard. This can be done by selecting Admin > API Keys > Legacy Keys > Umbrella Network Devices > Generate Token.
The Umbrella dashboard will only display the API secret when it is first generated, make sure that you've saved both the key and secret before closing the page.
If there are no keys, select Umbrella Network Devices and click the blue plus sign (+) labeled Generate Token. Generating new Token example screenshot:
Once the key and secret pair has been generated, copy both so they can be entered in your Meraki dashboard. Make sure to save the secret in a secure place because you will only see it once. Key and Secret example screenshot below:
New key and secret
If the Umbrella Network Devices API key and secret pair have already been generated, you can use the existing key information to in conjunction with its respective secret. Example screenshot:
Existing Umbrella API key example
Apply the Umbrella API Key to a Meraki Network
Once the Umbrella API key and secret have been generated, they need to be added to the Meraki dashboard to properly link the Meraki network and the Umbrella dashboard:
  • Go to the Network-wide > Configure > General page
  • Scroll down to the bottom of the page and click New credentials under the Cisco Umbrella account header
  • Paste the Umbrella API key and secret in the appropriate fields and click Save Changes
Once this information has been saved, the Meraki and Umbrella dashboards should now be properly linked, allowing Umbrella policies to be applied to Meraki SSIDs or group policies within the current Meraki network.
Note: Umbrella integration is linked on a per-network basis to the Meraki dashboard, so the Umbrella API key and secret must be entered on every Meraki network that requires Umbrella integration. Additionally, the Umbrella network devices API can be linked on a template parent network so that children networks bound to the template can easily leverage the same policies. Meraki networks that are cloned will also retain the API key for easy linking.
Meraki API Entry.
Unlinking a Meraki Network and Cisco Umbrella
Once the Meraki and Umbrella dashboards have been linked successfully the currently linked API Key will be displayed at the bottom of the Network-wide > Configure > General page. There is also a checkbox to delete the link between the selected Meraki network and the Umbrella dashboard.
To unlink a Meraki network from Umbrella, check the Delete linked account box and select Save Changes on the Meraki dashboard. Deleting this link between accounts will clear any objects in the Umbrella dashboard that were sourced from this network in addition to any Umbrella policies applied to SSIDs or group policies in the network.
Meraki API Delete
Linking and Applying an Umbrella Policy
Linking an SSID or group policy to an Umbrella policy is straightforward once the dashboards have been linked. When a Meraki SSID or group policy is linked to Umbrella, a unique device ID is generated for that Meraki object. An Umbrella policy is then linked to that device ID on the Umbrella dashboard. This device ID is included in any DNS traffic sent to Umbrella and used to specify which Umbrella policy that traffic should be checked against.
Note: These Meraki objects can be viewed on the Umbrella dashboard by going to Deployments > Core Identities  > Network Devices. Umbrella Network Devices are automatically created when linking a Meraki SSID or group policy and use the following naming format: <SSID/Group_Policy_name>__<Network name>_-_wireless
Linking a Meraki Group Policy to an Umbrella Policy (MX & MR)
Create the Group Policy
Before linking an Umbrella policy to a Meraki group policy, the group policy must first exist in the Meraki dashboard. Group policies can be created by going to Network-wide > Configure > Group policies. Ensure the group policy is set to use Custom network firewall & shaping rules. For more guidance on creating group policies on the Meraki dashboard, check out our more detailed documentation.
Note: Before attempting to link the group policy with Umbrella, ensure that the group policy is completely saved on the Meraki dashboard first.
Link the Meraki Group Policy with Umbrella
From the Network-wide > Configure > Group policies page, select the group policy that should be linked, then select the Link Umbrella policies button located under the layer 7 firewall rules. The Meraki dashboard will then automatically create the appropriate network device on the Umbrella dashboard and apply the default policy to the group policy.
Note: Group policies must be set to use Custom network firewall & shaping rules to link an Umbrella policy.
If creating a new group policy then the policy must first be saved before it can be linked to Umbrella.
Pre Link Policy to Group Policy
Apply an Umbrella Policy to the Group Policy
When first linking a group policy to Umbrella, the default policy is automatically applied. To apply a different Umbrella policy to the Meraki group policy, select the appropriate Umbrella policy from the drop-down menu on the group policy details page, then select Save at the bottom of the page.
If the Umbrella policy does not yet exist, it must first be created from the Umbrella dashboard:
  • Navigate to Policies > Management > All Policies on the Cisco Umbrella dashboard
  • Click Add in the top-right corner and follow through with the necessary policy creation steps
Once the Umbrella policy has been created, it can be applied to the appropriate Meraki group policy from the Meraki dashboard.
Post Link Policy to Group Policy
Note: The order that policies are listed in Umbrella is important. This can be viewed by logging into the Umbrella dashboard and navigating to Policies > Policy list. When a Meraki group policy is initially linked it will inherit the default Umbrella policy, which will be the last policy in Umbrella's ordered list. This shows in the Meraki dashboard as Default Policy (indirectly applied) because the default Umbrella policy was not specifically selected from the Meraki dashboard. If, for example, an admin were to assign a different policy to a network device (read: Meraki group policy or SSID) in the Umbrella dashboard, that change would be reflected in the Meraki dashboard, however, the policy would still show as indirectly applied because it was not applied from the Meraki dashboard.
Once a policy is assigned to a network device (SSID/group policy) in the Umbrella dashboard, any policies below the one selected for the network device will not be checked against. The policy list in Umbrella is read in a top-down order and once a match is found for the device ID, no other policies will be evaluated. More information can be found in Cisco Umbrella's Policy Precedence documentation.
Applying the Group Policy to Clients
Apply the Group Policy to Specific Clients (MX & MR)
To apply the Umbrella filtering policy to specific end clients, assign the Meraki group policy to the client from the Meraki dashboard. Group policies can be applied to clients in various ways, including utilizing an Active Directory integration, or by manually assigning a policy from the Network-wide > Monitor > Clients page. Filter the client list down to the intended client, select the checkbox to the left for that client, then use the Policy drop-down menu to apply the appropriate group policy containing the Umbrella policy to the client.
Refer to our group policy documentation for a more detailed overview of applying a group policy to a specific client.
Apply the Group Policy to a Subnet (MX Only)
When MX Umbrella integration is available, an Umbrella-enabled Meraki group policy can be applied to a subnet of clients. In this configuration, any traffic that passes through the MX with a source IP contained within that subnet will be subject to Umbrella filtering for the Umbrella policy selected in the relevant Meraki group policy.
To apply a group policy to a subnet of clients:
  • Go to Security & SD-WAN > Configure > Addressing & VLANs
  • Select the appropriate subnet from the Subnets list
  • In the accompanying dialog box, use the group policy drop-down menu to select the appropriate group policy and associated Umbrella Policy to apply
  • Select Update, then Save to apply the changes
Refer to our group policy documentation for more detailed information.
Note: If Walled Garden is used in your MX configuration, please be sure to add an Umbrella DNS domain exclusion for the required domain(s). This can be configured by navigating to Security & SD-WAN > Configure > Threat protection.
Linking an SSID to an Umbrella Policy (MR Only)
Create the SSID
Before linking an Umbrella policy to a Meraki SSID, the SSID must first exist in the Meraki dashboard. SSIDs can be enabled by going to Wireless > Configure > SSIDs. For more guidance in creating and configuring an SSID on the Meraki dashboard, refer to the documentation on enabling SSIDs and client IP assignment modes for SSIDs.
Note: Ensure that the SSID is completely saved in the Meraki dashboard before attempting to link an SSID with Umbrella.
Link the SSID to Umbrella
Linking an SSID to Umbrella is done from the Wireless > Configure > Firewall & traffic shaping page, under the Block Applications and Content Categories header for the appropriate SSID. Select Link Umbrella Policies on the appropriate SSID and the Meraki dashboard will automatically create the appropriate network device on the Umbrella dashboard and apply the default policy to the SSID.
Note: Umbrella integration with MR is currently supported for all client addressing types found under the Access Control page.
Link Policy to SSID
Apply an Umbrella Policy to the SSID
After linking an SSID to Umbrella, the default policy is automatically applied. To apply a different Umbrella policy, select the appropriate Umbrella policy from the drop-down menu on the Firewall & traffic shaping page, then select Save at the bottom of the page.
If the Umbrella policy does not yet exist, it must first be created from the Umbrella dashboard. This can be done by navigating to Policies > Management > All Policies on the Cisco Umbrella dashboard, then clicking Add in the top-right corner and follow through with the necessary policy creation steps. Once the policy has been created it can be applied to the appropriate Meraki SSID from the Meraki dashboard.
Post Linking SSID
Note: The order that policies are listed in Umbrella is important. This can be viewed by logging into the Umbrella dashboard and navigating to Policies > Policy list. When a Meraki SSID is initially linked, it will inherit the default Umbrella Policy, which will be the last policy in Umbrella's ordered list. This shows in the Meraki dashboard as Default Policy (indirectly applied) because the default Umbrella policy was not specifically selected from the Meraki dashboard. If, for example, an admin were to assign a different policy to a network device (read: Meraki group policy or SSID) in the Umbrella dashboard, that change would be reflected in the Meraki dashboard, however the policy would still show as indirectly applied because it was not applied from the Meraki dashboard.
Removing an Umbrella Policy from an SSID or a Group Policy
To remove an Umbrella policy from an SSID or group policy, navigate to the Wireless > Configure > Firewall & traffic shaping page for SSIDs or the Network-wide > Group policies > Group policy details page for the appropriate group policy. Under the currently applied Umbrella policy, click Disconnect from Cisco Umbrella followed by Yes in the confirmation pop-up.
Disconnecting an SSID or group policy from Umbrella will delete the associated object from the Umbrella dashboard and unlink any policies applied to that SSID or group policy in the Meraki dashboard.
Remove Policy
DNS Traffic Flow
This section of the article describes the expected traffic flow of DNS traffic from clients after an SSID or group policy has been successfully linked to an Umbrella filtering policy.
DNS traffic flow
  1. Client sends a DNS query.
  2. Meraki intercepts the DNS query and attaches an identifier to identify which Umbrella policy this request should be checked against.
  3. Meraki then encrypts the DNS query using DNSCrypt, source NAT's the packet to the MR management IP, and redirects it to the appropriate Umbrella endpoint.
  4. After arriving at the Umbrella endpoint, the DNS query is decrypted and checked against the appropriate Umbrella policy (based on the attached identifier) to determine if it should be allowed or not.
  5. If the request is allowed, Umbrella will return an encrypted DNS response with the appropriate IP.
  6. If the request should be blocked, Umbrella will return an encrypted DNS response pointing to the Umbrella block page.
  7. The client is sent the requested web page based on applied policy.
Note: HTTPS Blocking Just like Meraki's content filtering, blocked requests for HTTPS content will not load the Umbrella blocked page correctly. Instead, users will be presented with a generic "Webpage is not available" error.
 Note:  Meraki will send encrypted DNS traffic to 208.67.220.220/32. Make sure that bi-directional connectivity to this address is permitted to/from UDP 443 on any upstream devices.
 Note: Expected Routing Behavior when Default Route is over VPN (Auto VPN or Non-Meraki) When an MX has Umbrella protection enabled and a VPN (Auto VPN or Non-Meraki VPN) default route, it forwards the DNS requests rewritten by Umbrella over the VPN default route even though the subnet via which the request was generated doesn't participate in VPN. This will be sourced using an internal 6.x.x.x IP address.
Note: When enabling Umbrella on MRs with an MX upstream, DNS-snooping-related features on the MX, such as Youtube filtering and L3 FQDN rules, will stop working since Umbrella DNS requests from an MR are encrypted. This is especially the case if you have Umbrella running on the MX as well. The clients connected to MRs will not follow the MX's Umbrella policies. Consider this in your GP and SSID integration design with Umbrella Policies.
DNS Exclusion
DNS requests for excluded domains will not be redirected to Umbrella and will instead be forwarded to the DNS server specified by the client. This is extremely useful for preventing DNS requests for local resources from being redirected to Umbrella and instead allowing them to reach internal DNS servers to resolve correctly. Below are specifics on using DNS exclusions with the MR and MX.
MR
When an SSID is configured in Bridge Mode, the option to configure DNS Exclusion will be available under the policy selection drop-down menu. This allows administrators to specify domains that should be excluded from Umbrella filtering. When configuring, please note the following:
  • DNS exclusion is only available for SSIDs configured in Bridge Mode.
  • DNS exclusions are not available for configuration on group policies that are linked to Umbrella policies. The domain exclusions for group policies will adhere to the configuration of the SSID. For example, if the employee SSID is excluding meraki.com from Umbrella lookups, and a client with an assigned group policy linked to a different Umbrella policy connects, then meraki.com will still be excluded from DNS lookups sourced from that client.
  • MRs automatically adds the .local and in-addr.arpa domains to be excluded from Umbrella redirection by default.
MX
By enabling Umbrella Protection at Security & SD-WAN > Configure > Threat protection all client devices will be subject to Umbrella filtering. It is a setting that applies to the whole network unless overridden by a Group Policy.
For DNS exclusions on the MX, you can specify one or more domain names (one per row) to be excluded from being routed to Cisco Umbrella by going to Security & SD-WAN > Configure > Threat protection, and scroll down to Umbrella protection section. When configuring, please note the following:
  • MX supports DNS exclusion per network.
  • The configuration is only visible once Umbrella protection is enabled.
  • New to Firmware release 26.1 - By default the MX excludes DNS traffic from going to Umbrella for local DNS names (with .local suffixes) and reverse DNS lookup for private IP addresses. However, if user specifies any domain name(s) to be excluded, this will override the default exclusion of ".local". Therefore, the user must explicitly configure any specific local domain(s) they wish to exclude from being sent to Umbrella
DNS exclusion on MX
Best Practices
  • Enable the DNS integration on both MX and MR platforms for the broadest protection
  • TCP DNS is not supported on the MX on firmware versions earlier than 19.2. If you are using an earlier version, please upgrade to the latest firmware if possible.
    • If upgrading is not an option, review and consider implementing the steps below:
      • Under normal circumstances, TCP DNS requests account for ~.02% of DNS requests. If TCP DNS is a concern steps to secure this type of traffic the following steps can be taken.
      • Add an L3 Firewall Rule (Security & SD-WAN > Configure > Firewall) which blocks TCP port 53
      • Add a Content Filtering Rule (Security & SD-WAN > Configure > Content Filtering) to block DoH/DoT Traffic. This category is intended to identify and block encrypted TCP DNS traffic which will force the client back to unencrypted lookups and continued security coverage.
      • Update to Chrome 113 or newer on Windows clients.
        • A bug that impacted Windows clients caused frequent DNS queries over TCP. This has been fixed in Chrome 113 (released 5/2)
  • For DNS Policy best practices please see this Umbrella article.
Troubleshooting
General Troubleshooting Steps
  • Ensure that the Umbrella and Meraki dashboards are properly linked via API from Network-wide > Configure > General (Section 2.1)
  • Ensure that the SSID/group policy has been linked to Umbrella in the Meraki dashboard and has an Umbrella policy applied from either Network-wide > Configure > Group polices or Wireless >  Configure > Firewall & traffic shaping respectively (section 3.1 & 3.2)
  • Ensure that the appropriate identity exists under Deployments > Core Identities  > Network Devices on the Umbrella dashboard (section 3)
  • Ensure that the correct policy is assigned to the correct network device in the Umbrella dashboard from Policies > Policy List
  • Ensure that bi-directional UDP 443 traffic is allowed to the Umbrella endpoint of 208.67.220.220/32 (section 4)
  • Was this article helpful?
