How to Enable, Disable, and Rename SSIDs
Overview
This article explains how to enable, disable, and rename SSIDs in Cisco Meraki dashboard. You can update the basic properties of a Cisco Meraki wireless network, such as the network name and SSID name, from the SSIDs page in dashboard. This is useful when you want to create additional SSIDs for separate departments or update the SSID you currently use.
SSID naming conventions
Under 802.11 standards, such as 802.11-2020 Section 9.4.2.2 SSID Element, an SSID name can be any alphanumeric, case-sensitive text entry from 2 to 32 characters. Every deployment varies, but Cisco Meraki recommends SSID names that are reasonably short but descriptive.
Spaces are allowed in an SSID name, except as the first or last character. However, spaces tend to cause issues or confusion, so use hyphens or underscore characters instead. For example, the Ikarem widget company might use these SSID names:
  • Ikarem-Employee
  • Ikarem-BYOD
  • Ikarem-Guest
You can use other special punctuation characters with discretion if required, but they are generally avoided in practice.
Some customers prefer to assign more cryptic SSID names to mask their purpose or prevent abuse. This approach is acceptable if proper user training or guest messaging is in place to avoid confusion.
You can also turn off SSID broadcast by using the Hide SSID checkbox on the Wireless > Configure > Access Control page. However, hiding the SSID is not a security mechanism.
Step-by-step instructions
Enable an SSID
  1. Navigate to Wireless > Configure > SSIDs.
  1. Select the three-dot (...) menu for the SSID to open the drop-down menu.
  1. Select Enable.
Disable an SSID
  1. Select the three-dot (...) menu for the enabled SSID.
  1. Select Disable.
Rename an SSID
Renaming an SSID requires all of your wireless clients to re-associate with the SSID. Before you choose a new name, go to SSID naming conventions in this article.
  1. Select the three-dot (...) menu for the SSID, and then select Edit. The SSID Edit page opens.
  1. In the Basic Info section, enter the new name in the SSID (name) field.
Verification
After you enable an SSID, the three-dot (...) menu for that SSID shows Disable instead of Enable.
Troubleshooting
Bandwidth limit shows a per-client value
The bandwidth limit on the Wireless > Configure > SSIDs overview page is the per-client limit, not the per-SSID limit.
Locate the client LAN blocking setting
You can find the configuration that blocks clients from using the LAN under Wireless > Configure > Firewall & traffic shaping.
Additional resources
For help with configuring other aspects of your SSID, refer to:
