Axis Integration Support Guide
Introduction
This guide outlines the support procedures and contact information for Axis devices integrated with Cisco Meraki. To ensure the fastest resolution, please review the troubleshooting flow chart to identify the appropriate support channel and and the "Quick Fixes" section for the most common issues.
60-Second Health Check
Step
Action
How to Verify If Failed
1 Camera has power  Look for LED lights on camera Verify the PoE switch port is active; try a different port
2 Network connection Can you ping the camera IP from a device on the local network? Check cable connections; verify VLAN settings
3 Camera accessible locally  Open http://<camera-IP> in browser  If the camera is not accessible, check the network/firewall settings
4 Meraki Dashboard shows camera  Check Cameras page in Dashboard-> Search via mac address  Verify camera is claimed in the correct network
5 Firmware is current  Verify firmware version on device to latest firmware available here   Update if significantly outdated
Who Should I Contact?
Issue
Things to try first
If Unresolved, Contact
Camera won't power on
Check cables, switch port, PoE budget
Axis Support
Camera is not claimable in Dashboard
Check ACAP status under System>Apps on Local Status Page(LSP) and Network connectivity
Meraki Support
Can't view live video
Test stream on device via LSP, Check bandwidth
Meraki Support (if local works) / Axis Support (if local fails)
Poor image quality
Clean lens, Adjust settings
Axis Support
Configuration not syncing
Refresh page, reboot device
Meraki Support
Export not working
Try a smaller clip, follow guidance based on error
Meraki Support
Physical/hardware damage
Visual inspection
Axis Support
MySystems/account issues
Verify credentials, check LSP
Axis Support
Licensing questions
Review Dashboard license status
Meraki Support
Camera feature questions
Check Axis documentation
Axis Support
Network/firewall issues
Verify port configuration, Check firewall rules on dashboard under Help>Firewall info are allowed
Meraki Support
Contact Information
Support Team
Best For
Contact Method
Availability
Axis Support
Camera hardware, image quality, camera settings, physical issues
axis.com/support/helpdesk
24/5 (Phone during business hours, Chat 24/5)
Meraki Support
Dashboard, cloud connectivity, video streaming in dashboard, licensing
Meraki Dashboard > Help > Get Help
24/7 (Phone & Email)
How to Open a Support Case
Opening a Case with Meraki Support
  1. Log into dashboard.meraki.com
  2. Click the "?" help icon in the top-right corner
  3. Select "Support Center"
  4. Click on the “Cameras/IoT” tile
  5. Describe your issue with as much detail as possible
  6. Include your camera serial number and any error messages
Note:  Once the case is created, continue the support discussion via the created e-mail thread, comments added on the dashboard are not shared with both teams.
Opening a Case with Axis Support
  1. Go to axis.com/support/helpdesk
  2. Sign in with your MyAxis account (create one free if needed)
  3. Click "Create new case"
  4. Fill in camera model, serial number, and issue description
  5. Upload any relevant files (screenshots, server report)
Video Guide: How to Create an Axis Support Case
Essential Data for Troubleshooting
Information
Where to Find It
Camera Model
Physical label on camera, or Dashboard > Cameras. If device is not claimed on Dashboard->Device LSP
Serial Number
Firmware Version
Dashboard > Cameras > Select camera > Details. If device is not claimed on Dashboard->Device LSP
Description of Issue
When did it start? What were you trying to do? Any error messages?
Screenshots
Capture any error messages or unexpected behavior
Server Report
Download from Local camera interface > System > Logs. Video guide here
Unified Support Experience
For issues involving both Axis hardware and the Meraki cloud platform, a collaborative support model is utilized to ensure efficient resolution. The process includes the following features:
  • Internal Escalation: If an issue requires expertise from multiple departments, internal routing is managed by support staff to prevent the need for redundant explanations.
  • Integrated Case Tracking: All involved support teams maintain full visibility into case history, communication logs, and progress updates.
  • Dual Case Referencing: In some instances, separate case identifiers may be generated for administrative tracking. These cases remain linked, and no additional management is required to monitor the progress of both.
  • Was this article helpful?
